  New Posts New Posts RSS Feed - Reefing windspeeds
Reefing windspeeds
grumpydatagit View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote grumpydatagit Quote  Post ReplyReply Direct Link To This Post Topic: Reefing windspeeds
    Posted: 30 May 2016 at 18:28
Hello All,
I was wondering what wind speeds do other people start to putting the first and second reefs in ?
D0bbies View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote D0bbies Quote  Post ReplyReply Direct Link To This Post Posted: 30 May 2016 at 19:43
For me and depending on the sea state and heel:-
Steady wind above 15kts I'd roll in the jib first 25/30%, then if necessary reef #1 in the main.
Steady wind above 20kts I'd roll in the jib further 35/40%, then if necessary reef #2 in the main.
Tomorrow is forecast upto 25kts NNW Falmouth so I'll start double reefed.
2005 312, Tiller, Engine 2GM20, SD20 Saildrive. Facnor SD 130 Furler.
Ilkhanse View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ilkhanse Quote  Post ReplyReply Direct Link To This Post Posted: 31 May 2016 at 00:05
True or apparent?
sailkoop View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote sailkoop Quote  Post ReplyReply Direct Link To This Post Posted: 31 May 2016 at 07:08
The Windspeed for reefing is normally TWS and Upwind!
best regards
Bjoern
Post Options Post Options   Thanks (0) Thanks(0)   Quote samuel Quote  Post ReplyReply Direct Link To This Post Posted: 31 May 2016 at 08:35
I always use the ST jib unless racing. I never sail with the self tacker part furled unless it is very windy. ie F8+ although I have not used my current laminated jib in anything above F7 yet & it does seem very powerful compared with my last 3 dacron STs so I may have to re think that one some time.
If it is flat water & up wind the 1st reef at 20kts apparent. If rough then a little earlier 15-17kts & I then tend to bear off a bit.
Second reef in flat water 23kts rough water 19kts
Down wind add 3-5 kts to those wind speeds plus a bit for any increase in boat speed
Really depends on angle of wind, sea state & how I feel as nearly always sailing SH I prefer to be comfortable. I also tend to set the boat up for my Aeries self steering so in some cases i have to reef earlier as it seems to have a mind of its own.
It also depends on sail shape. My old baggy main would not flatten very well, whilst my Hyde main can be flattened quite well & backstay hardened right up to reduce a lot of heeling first. I have my rig set to allow quite a bit of bend in the mast & the Cunningham can be applied as well as a bit more halyard etc. I tend not to sail with the main hard in.
A lot depends on sailing style as well as boat trim, sail set & sea state
Edited by samuel - 31 May 2016 at 08:38
Ta'I Miti 2 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ta'I Miti 2 Quote  Post ReplyReply Direct Link To This Post Posted: 08 January 2021 at 14:45
Hello
I'm answering this old post
I always start reefing the main
If I roll the jib first, she's really too nervous.
12kn - 15 kn: playing with the mainsail rail (I have one)
15KN - 1st reef - playing with the rail
20Kn - 2d reef - - playing with the rail
25kn - 2d reef and partly rolled jib - playing with the rail
30kn - 2d reef - no jib - playing with the rail
35kn - 3rd reef - playing with the rail
40kn - Not playing but praying. Never had to pray till now
Since I have new sails, I hav to say that she behaves much better
Not only those who wander are lost
I've learn that the best way to learn about people is to sail with them
Speedy Nice View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Speedy Nice Quote  Post ReplyReply Direct Link To This Post Posted: 14 January 2021 at 15:54
TWS
1st reef at 18-20kn with 140% genoa
1st reef at 20-22kn with 90% jib
2nd reef at 25-30kn with 90% jib
I have a rail intalled
I try not to use the genoa half-furled because my standard furler doesn't seem to be strong enough for that
Edited by Speedy Nice - 14 January 2021 at 15:57
José Pires
