Replacement battery group
Forum Name: 505/508
URL: https://www.myhanse.com/forum_posts.asp?TID=10477
Topic: Replacement battery group
Posted By: chillios
Subject: Replacement battery group
Date Posted: 08 October 2017 at 14:39
Hi. After some additional troubleshooting of my house batteries, or looks like They are dead.   Does anyone know the battery group number of our house batteries?
I have 4x 165ah AGM for my house batteries.
Thanks,
-Chris
Posted By: bovine
Date Posted: 08 October 2017 at 17:07
Hi Chris
If I was you I would change batterie type,I've changed mine to 6volt deep cycle wired in series to get back to 12 volts.
The brand I used was U S Battery I had to modify the battery box though, they have been excellent .
David
Posted By: chillios
Date Posted: 29 October 2017 at 01:18
After a bit of searching, I have found a direct replacement. Victron energy makes a 4d battery that is able to use the same copper bars for linking the batteries.   The terminals are copper blades and not the lead posts seen on most batteries. I purchased through jamestown distributors. They are 165 amp hour each.   I have the extended set of 4 x165 for 660 amp hours total.    This was a straight drop in replacement.
Posted By: Rubato
Date Posted: 30 October 2017 at 16:25
Chris
I hope I'm stating the obvious but is your new set AGM also? If not, you likely need to change the setting on the battery charger. In fact, it's probably a good idea to double check what the charger is set to.
Hanse 400e, #168
Posted By: chillios
Date Posted: 07 November 2017 at 00:03
The replacement set was a direct drop-in with AGM batteries.
part number is VIC-BAT412151080 .  I did specify that I was looking for the blade style vs. the posts for terminals.
Picture of Battery here:
https://images.jamestowndistributors.com/images/marine_batteries_battery_cable_switches_and_accessories/large/vic-51856-3.jpg
