Self Tacking end Stops
Forum Name: 400
URL: https://www.myhanse.com/forum_posts.asp?TID=10544
Topic: Self Tacking end Stops
Posted By: neilbay
Subject: Self Tacking end Stops
Date Posted: 28 November 2017 at 21:15
We have just returned to New Zealand after sailing from Southampton.
The rubber end stops for the self tacking jib were only lasting a few days, esp sailing across Biscay
I found some 'feet' at a $1 type shop in Portugal and these have lasted for over a year.
I used the old broken rubber end stop pieces to fit the new feet.
See photo's
Cheers Neil
Hanse 400 2007 - Back in NZ
Posted By: StavrosNZ
Date Posted: 28 November 2017 at 21:31
great idea and welcome home, how did your 400 fare in this epic journey?
Stephen
Posted By: neilbay
Date Posted: 28 November 2017 at 21:55
Thanks, good to be back
No major issues with the boat or during the passage ( we chose our weather well ( lucky))
We used a hydrovane and have a watt&sea generator, so no power issues during passages.
We had a fixed length forestay, was causing the mast foot to push up against the base, so had that changed in Canaries
Anchor roller got bent over, completely mangled when chop developed and anchor stuck in coral.
Had an inner forestay fitted and a storm jib ( never used )
Date Posted: 28 November 2017 at 22:00
i guess you must have Sparcraft rig? thankfully my Selden rig has adjustable forestay.
i had same issue with my bow roller, use double bridle snubber of deck cleats in strong winds to take all load off the roller.
Stephen
Posted By: neilbay
Date Posted: 29 November 2017 at 01:12
Yes, I created a double bridle and use the cleats. Using that I managed to bend a wichard chain hook, again in coral and building winds.
BTW : The single snubber rope snapped after bending the anchor roller.
Posted By: Silver lining
Date Posted: 05 December 2017 at 20:33
Neilbay, excellent achievement ! - how long was your journey ? Time / miles / journey . We also have a 400e hull no. 199 called silver lining , so I'm glad to here these boats are built to last !!
'Silver Lining' 400e #199
Posted By: neilbay
Date Posted: 05 December 2017 at 21:13
Thanks,
We left Southampton on the 30th May 2016, cruised to Falmouth then across to Spain, Portugal, Madeira, Canaries, Barbados, Some other Caribbean Islands, Panama, San Blas, Galapagos, Marquesas, Tuamoto, Society Islands(Tahiti), Suwarrow, Niue, Tonga, New Zealand.
I think it was about 20,000nm
Our boat has a Grey Hull and was called the Red Pearl when we purchased it in Scotland. Hence the renaming to Silver Lining.
We spent quite a bit of time (and money) getting her ready for the trip
Date Posted: 05 December 2017 at 22:29
That's great - were you happy with the overall performance of the boat on the voyage ? We also purchased silver lining in Scotland, hull is light grey .
Posted By: Alesea
Date Posted: 17 March 2018 at 13:38
Hi Neil,
We have a 505 in Greece and will be doing the ARC in November, then hopefully sailing home to NZ. We are getting a hydrovane fitted. We also have an autopilot. Did you use the hydrovane as your main autopilot? Thinking of also getting a spinnaker pole - did you use one and run flat off in the trade winds or did you just sail the angles?
Ian and Kate
Alesea Hanse 505 NZL9464
Posted By: neilbay
Date Posted: 17 March 2018 at 20:40
Hi Ian and Kate
How exciting, we really enjoyed out trip home.
We used the hydrovane as the main autopilot for all the passages. If the sea got confused we occasionally had both autopilots going for short periods. We also have a watt&sea generator and did not have to supplement charging when sailing the long passages.
We did the Atlantic Odyssey from Teneriffe to Barbados. Fitted a spinnaker pole in Teneriffe, it was used extensively and highly recommended. We also have a third reef and spent many days sailing with the 3rd reef and a poled out jib. The pole would be set with fore and aft lines to hold it firm, the we could furl the jib for squalls. The other essential item is a boom brake or preventer that is easy to set.
My wife kept a blog of our travels https://www.sailblogs.com/member/seaescape
Let me know if you have any other queries.
Cheers Neil
Posted By: Alesea
Date Posted: 17 March 2018 at 23:37
Thanks Neil - really helpful info! We’ll check out your blog.
Cheers!
Posted By: SausalitoDave
Date Posted: 18 March 2018 at 04:21
Ian and Kate:
I have a 505 as well and will be doing the ARC in November (although in a Swan 54 that I have purchased in Europe). Let's connect at the start and swap 505 stories.  I have had my 505 for 3+ years here in Sausalito, California.
Festina Lente
Posted By: Alesea
Date Posted: 18 March 2018 at 12:37
Hi Dave,
Sounds great. We’re cruising the med this summer, starting back in Greece in late April, Turkey then westwards. Where are you picking up the Swan?
K & I.
Date Posted: 19 March 2018 at 22:34
K & I:
We bought her at the yard in Finland last year.  She is currently on the hard in Barcelona.
Starting July 15, you should see her on "vessel traffic".
Festina Lente
