Continuous line furler?
Forum Name: 505/508
URL: https://www.myhanse.com/forum_posts.asp?TID=10640
Topic: Continuous line furler?
Posted By: chillios
Subject: Continuous line furler?
Date Posted: 21 February 2018 at 18:21
I'm in the process of fitting a new top down furler on our 505.  Has anyone done the same?
If so, how did you route your furling line?  (how long did you make the loop?)
Details on the setup:
Ubi Maior FR150RW with a top-down adapter.
Future Fibers Engineered cable.
Doyle APC
Posted By: STEVE MCINNIS
Date Posted: 22 February 2018 at 01:00
We put on the Selden furler. It has several leads attached to the stanchions (has a spring mechanism to take the lines out/install them) and led back to a double cam block which is attached to the gate stanchion with a soft shackle.
S
