545 skin fittings and valves
Forum Name: 545/548
URL: https://www.myhanse.com/forum_posts.asp?TID=10754
Topic: 545 skin fittings and valves
Posted By: Cam
Subject: 545 skin fittings and valves
Date Posted: 03 May 2018 at 14:27
We’re proud to join the Hanse community just now, and spend the Mediterranean summer in the Spain, the Balearics and Sardinia on our 2012 H545.
But I need to replace those corroding brass skin fittings and valves, so would appreciate any assistance on the exact dimensions of all hull through fittings, seacocks and one way valves. There are 14 below the waterline.
Does anyone have a hold of a spec list, or know a contact at Hanse to provide? I’ve struggled to muster a response.
Thanks!
Posted By: seileren1
Date Posted: 09 May 2018 at 19:00
On my 545 I had all of mine changed, except the intake to the Engine. The old onces were coroded and two of them were coroded to a dangerous level. I changed to trudesign composits. I spend a bit of time figuring out both the dimensions and correct parts. As soon as I get to the boat I can take some pic and post them here with the meassurments If that would help you.
Posted By: Cam
Date Posted: 13 May 2018 at 03:48
Thanks for that, and I’ve chosen the Trudesign fittings too after more research and discussing it with my techs in Tenerife. I suspected these are the new standard, being hesitant to return to bronze. Regards!
Date Posted: 13 May 2018 at 08:27
I just send you a PM, Cam
