In theory you should not let the halyard off so much that the block touches the aligner. (difficult to see the block because of the lazy cover). If you cannot get the sail down far enough at that point you might see if you can shorten the spectacle on the sail (if you have webbing spectacles) If you find that the luff is low enough with the block just clear of the mast aligner then the jamming problem is because you have let the halyard off too much in the first place whilst setting the reef. The block has to be just above the aligner so that the line feeds through neatly
To prevent this put the reef (on a light wind day in the marina) in with the block just clear of the aligner & the halyard fully tensioned. Then note where the lowest batten comes against the mast. At this point place some coloured tape (I use some red spinnaker repair tape 50mm wide) on the mast either side of the luff groove. Do not bother with marks on the halyard if you have a stretchy halyard as it will be different every time even with dynema. This is because the distance from a halyard mark to the block would be 30 metres & liable to a variety of stretch, but the distance from the batten to the block is 1 metre so less liable to differing stretch; hence more consistency
Then as you tension the reef lines when doing the reef in anger do not release too much halyard at once but release it in stages with the kicking strap eased. When the batten is about 150mm above the mark (how much will be determined by experience) you can really harden in the reef line which will get the leech in tight & the block will not catch on the mast aligner. Then if the halyard has not already stretched (ie if you have dynema) you can ease it the last little bit until the batten & tape line up. This will stop the problem of pulley jamming on the aligner- It should also stop the aligner cutting into the rope.
In my opinion you do need the aligner if you want to tension the outhaul properly You can cobble ways round it but they are not so neat If you find that the corners of the aligners dig into the reef line you may find that if you can find a shackle to fit into the aligner then let the rope run through the shackle rather than the aligner the rope will not actually catch into the sharp corners
