Water Tank sensor - SOLVED
Category: General
Forum Name: Chit Chat
URL: https://www.myhanse.com/forum_posts.asp?TID=11193
Printed Date: 01 June 2023 at 02:37
Topic: Water Tank sensor - SOLVED
Posted By: richz
Subject: Water Tank sensor - SOLVED
Date Posted: 26 January 2019 at 11:50
Hi All,
I have replaced the original diesel and water tanks sender sensors with new and more effective Philippi sensors. It was something I wanted to do for a long time as the original sensors were not working properly.
With the diesel sensor I had no problem; it was a plug and play trick as the original sensor was connected via a 2 wire (30 to 180 ohm) sensor as the philippi one.
With the water sensor instead I am having difficulties.
The original sensor was connected to the main switchboard through a 5 wire cable.
From the instruction manual of the DC Panel TEV0605 I read:
Coding Plug
The water level can be read over a 5-wire sensor or a 2 wire 3...180 ohm sensor. By default a 5-wire sensor is assumed. If the 100% value of the 5-wire sensor of the connector will be reconnected to the ground, is no longer the 5-wire sensor in use but the 2 wire 3... 180 ohm sensor. This accounts for both water sensors, independently from each other. Additionally, it is possible to completely configure water sensor out of the display and alarm handling (see 3 Configuration).
So I connected the philippi sensor to the white and the grey cable (see picture below)
On the other side of the cable, I have tried connecting it to the different slots of the main switchboard hoping to find the Water Tank one, with no luck.
I believe the connection is ok and the sensor works perfectly and the evidence of that is that if I use the second diesel tank slot the sensor is giving me the right reading (see picture below).
It would be nice to be able to reconfigure the DC Panel in order to replace the “Diesel 2” tag with “Water Tank”; does anyone know if this is at all possible?
Alternatively, does anyone know where the Water Tank slot is on the main switcboard and/or if I made some mistake in the connection?
Many thanks for your help!
Richz
Posted By: richz
Date Posted: 26 January 2019 at 11:56
I am afraid I have uploaded a less relevant photo.
Perhaps the following ones are more relevant to my post.
Best,
Richz
Posted By: richz
Date Posted: 27 January 2019 at 11:31
I might have found the answer to my question.
Enclosed is snapshot from the TEV 0605 panel where I have circled the section showing how the slots are displaced.
It also show that ground wire should be connected on the right plug where instead I have done the opposite.
Next time I am on board I will give it a try.
Still unsure about how the diesel 2 slot works ...
Date Posted: 27 January 2019 at 16:31
Hi Rich,
your photo shows a two pin plug. This will work, when you connect it to 2 pin sensor like a diesel sensor.
Reading your circuit picture, the sensor should be connected to the uppermost 5 pin position. Try to repeat what you have done on the other sensor end, only connect the white on Pin 1 and the grey on Pin 5.
Posted By: richz
Date Posted: 27 January 2019 at 19:24
Thank you Frank,
My understanding is that I should connect the Philippi sensor to the 3-180 ohm slot dedicated to the water tank.
On the main switchboard there are two slot 1-5 pins and two slots 3-180 ohm.
I attach an enlarged picture to better explain myself.
I think I need to connect the two pins plug to the second last from the bottom.
As I said, I will give it a try the next time I am on board.
It it doesn’t work I will read the water tank sensor from the Diesel 2 slot as shown in my picture (unless someone knows how to program the DC Panel and change the description from “Diesel 2” to “water”.
Richz
Date Posted: 27 January 2019 at 20:47
Ciao Rich,
afaik you can not change the description in the menu of the dreaded WE panel. I was not aware of the two lower 6.1 and 6.2 water connectors, as I went straight to my Philippi TCM tank monitor when i upgraded the tank sensors for Diesel, Water and Waste tanks.
I simply removed them from the WE menu, I only have the voltages for Starter, House and Bow Thruster batteries now.
Good luck and cordiali saluti della Svizzera
Posted By: ariette
Date Posted: 29 January 2019 at 16:01
I've had to replace my wurth panel due to a lightning strike and the water/diesel connectors have now been changed to mini-molex connectors. Replacing the diesel is ok as there are only two wires but I can't work out the order for the water tanks. Do all wires have to be connected or just the white and the grey?
secondly- does anyone know the name/type of the previous connectors (as featured in the photographs above) Thanks
Lyra. Hanse 415 in the Med
Date Posted: 29 January 2019 at 17:07
Hello Ariette,
if you have not replaced the crappy 5 wire Hanse sensor by something more reliable( like RichZ did) you need to connect all 5 wires for the water tank sensor.
BR
Posted By: richz
Date Posted: 29 January 2019 at 22:36
Hi Ariette,
They are produced by STOCKO and the model of the connector is RFK 2 MFK 13260, 2-pins.
I found them on eBay.
If you see from the diagram I posted above you should also be able to find the order of the different slots on the main board.
I have connected the two pins connector to the diesel 2 slot and it works perfectly.
I now want to try on the Water 1 slot by inverting the two wires in order to have the ground on the correct side and see if I am able to have it work also on the Water tank slot.
Richard
Posted By: richz
Date Posted: 02 February 2019 at 18:38
I have now got to the bottom of it!
I have bridged the first and the last pin of the 5 pins water slot and connected the two wires 3-180 ohm connection from the Philippi water sensor to the Water 2 slot: eureka! It works
Below the bridge described above:
Posted By: sailkoop
Date Posted: 03 February 2019 at 10:54
Thx for sharing the Experience! Good to know.....
best regards
Bjoern
Posted By: richz
Date Posted: 03 February 2019 at 13:56
Pleasure!
And BTW inverting white and grey wires is completely irrelevant.
What you need to have the 2 wires 3-180 ohm slot working is bridging the first and the last pins on the correspondent 5 pins water slot.
I have also tried the same with water slot nr 1, which did not work correctly (I guess it is a problem related to my own panel) as it was continously and swifly switching from zero to accurate reading.
Posted By: CrocDundee
Date Posted: 03 February 2019 at 16:20
Much appreciated, this seems very useful progress.
Could you summarise the new gauge (type and length), the wiring at the gauge end that eventually worked, and the wiring at the panel end that eventually worked? We are in a 345 that needs this enhancement, but some of the gauges and panel on ours are different, so understanding what worked for you will be invaluable. We have the similar 5 cable connection as you show.
Ta.
Posted By: richz
Date Posted: 03 February 2019 at 22:13
I used the TGW 300 made by Philippi (as suggested by Fendant).
If you look at the photos you can see the wires at both ends; I used the white and the grey and ignored the others.
What really made the trick was the bridge I have made to connect the first and the fifth pins in the 5 pins water slot.
If your panel is arranged differently then you should get the updated handbook.
Rich
Posted By: Schjoto
Date Posted: 12 May 2019 at 22:53
Thank you for this useful information. For supply reasons, I plan to use the Wema sensor ( https://wema.co.uk/products/fuel-sender?variant=29703058311" rel="nofollow - https://wema.co.uk/products/fuel-sender?variant=29703058311 ) which can be used for both water and diesel - I have a H345 as well. A few questions:
1. On the water tank, did you use the same spot to mount the new sensor or did you drill a new hole? If you used the original spot, did it fit well with the flange? If you drilled a new hole in the tank, did you then remove the “sensor pins” from the original sensor? Any pictures?
2. RICHZ wrote that he bridged the first and the last pin of the 5 pins water slot. I will follow this, but why is it necessary since another slot is being used?
3. The Wema sensor can be used also for diesel. What length did you select and is it being screwed or bolted in the diesel tank?
Thanks in advance :-)
Posted By: richz
Date Posted: 13 May 2019 at 22:41
hi Tom,
Below my replies:
1) I used the same spot; you have to remove the old sensor (I used a pipe wrench piers to unscrew it) and then I made a new hole which fitted the size of the sensor flange
2) you need to bridge the two pins (as shown in my photo) to ‘instruct’ the board to read the new slot
3) I used the TGT250 from Philippi. This Philippi sensor is bolted but you ned the SAE adapter to use the existing holes.
I hope this helps
Richz
Posted By: Schjoto
Date Posted: 13 May 2019 at 23:02
Thank you very much Richard!
Posted By: Nelson01
Date Posted: 10 June 2019 at 06:31
Hi Richz
We have same problem.''Fresh water 1........0%. ''
We have 130-145 Ohm at panel on the 2 wires (xb6.1 sensor water tank) and plugged in at 2 nd connector from bottom.
We have only 2 wire/pin system.
Is problem panel or programm.....were do I search next?
Marc
Marc
H508#11 UNEVIE
Posted By: oj_knut
Date Posted: 14 March 2023 at 14:08
Can you explain to me how you removed this from the WE menu?  I want to remove all tank levels and battery voltage if possible.
Date Posted: 14 March 2023 at 15:43
Knut, my boat is still on the hard 2 hrs away. So I hope to recall the procedure right from memory.
You have 3 button below the LED display: up, down, menu ( to switch to the levels )
The 1st menu tree has three different levels.
Level 1 shows the sensor, Level 2min and max alarms, Level 3 is for setting the alarms
Level 1 is the from top engine, service, bow, stern batteries
Then follows fuel tank 1 and 2
Then folllows fresh water tank 1 and 3
Then follow a couple ( 3 or 4 ? ) pf grey and black water tanks
Finally I think you can switch from German to English
When you are on this menu level press and hold together ( here I am not so sure =
a) up and down arrow simultaneously
b) up, down and menu button simultaneously
This will bring you to another level where you have the list of all sensors and you can enable/disable via the menu button each sensor.
Finally you have only the list in the display of your enabled sensors ( in my  case only engine,service and bow battery ). All tank sensors are wired to my Philippi tank monitor.
Good Luck!
Posted By: richz
Date Posted: 14 March 2023 at 16:09
well done, Frank! Very good memory.
The right sequence to enter the configuration menu (i.e. to  ‘enable/disable’ items from the menu) is press in sequence and hold the three buttons (arrows up, down and enter).
Posted By: oj_knut
Date Posted: 14 March 2023 at 21:05
Good Luck!
Thanks for your help.
Posted By: oj_knut
Date Posted: 15 March 2023 at 12:55
Originally posted by richz richz wrote:
Can you tell me a bit about how you changed the fresh water sensor?? Mine has a sensor hole, but it appears to be filled with epoxy. How did you proceed??
Date Posted: 15 March 2023 at 13:03
Knut, I left the crappy sensor in place and drilled a new hole adjacent to the inspection fitting. The I used two wires of the existing cable to connect the new sensor it is simple resistance measurement.
Just connect these two wires to one of the resistance sensor junctionson the Würth panel and you are done.Hug
Posted By: oj_knut
Date Posted: 15 March 2023 at 13:47
Thanks, I'll leave it in then
Posted By: richz
Date Posted: 16 March 2023 at 20:34
If you use a pliers wrench you should be able to unscrew the whole thing. Then you need to widen the hole using a hole saw drill bit with matching size. This way you avoid making a second hole in the tank
