Placement putting on foredeck?
Forum Name: 320
URL: https://www.myhanse.com/forum_posts.asp?TID=11242
Topic: Placement putting on foredeck?
Posted By: mystudio
Subject: Placement putting on foredeck?
Date Posted: 24 February 2019 at 09:43
Can anyone confirm that there is a metal (aluminium) plate on the foredeck at this position? (the position where the metaldetector lays down) I have to place a putting here for the spinnaker pole, so I am looking for the best position. Any insights are appreciated! Also insights on how wide this reinforcement is.
#004|Jefa DD1|ACU200|EV1|P70|Raymarine E7|Axiom Pro9s|B&G displays|Emtrak transponder|Lewmar traveller|Dyneema|Flexofold|Carbon pole|ball bearing genoacars|Membrame sails|Spi and asym spi|N2K->Wifi
Posted By: Peter-Blake
Date Posted: 24 February 2019 at 18:26
Try to get a drawing with the reinforcements in the deck. On my 370 there is on this spot a metalplate.
look here and try to pm CharlesP (see last post in this thread)
http://www.myhanse.com/deck-reinforcements-h320-h350-h370-h405-h43_topic3060.html?KW=deck+drawing+hanse+320" rel="nofollow - http://www.myhanse.com/deck-reinforcements-h320-h350-h370-h405-h43_topic3060.html?KW=deck+drawing+hanse+320
Blake 370
Posted By: FTK
Date Posted: 24 February 2019 at 19:56
Hi mystudio,
I could send you a plan about reinforcement positions, but this is a .pdf file, I can't upload it. I found it somewhere on the net, maybe in this forum.
If you give me an e-mail address I send it to you.
320 #145
Posted By: CharlesP
Date Posted: 24 February 2019 at 21:08
hi Peter Blake. I’ve offered to email the drawing to Marco.
Charles
'MERIDIAN LADY'
320 Nr 536 2010
Medway
Posted By: mystudio
Date Posted: 26 February 2019 at 07:48
Thx for the drawings! This is really helpful. I also found someone on this forum with a probably factory bowsprit. Hope he will be able to answer my question where he got it.
Posted By: FTK
Date Posted: 26 February 2019 at 08:16
Please keep me updated! I am planning a bow sprit on my boat as well Smile
320 #145
Posted By: mystudio
Date Posted: 28 February 2019 at 15:41
Too bad Hanse didn't center the reinforcement alu plate. Now it's guessing where it is :-( 3 bad holes already and counting. Hanse, don't mess these things up please please!
Posted By: StavrosNZ
Date Posted: 01 March 2019 at 00:33
Buy a cheap metal detector which will save you all of these holes and problems
Stephen
Posted By: mystudio
Date Posted: 02 March 2019 at 19:20
Unfortunally, it doesn't. I have one. It's not precise enough to detect EXACTLY where the aluminium plate starts end ends. So, I bought another one, a really expensive one. Same problem. So, too bad, but, you can't solve this by a metal detector alone The plate is smaller than the described 10x10, otherwise it would have worked out because you have enough room for interpretation.
