445 facelift wiring diagram
Forum Name: 445/455/458
URL: https://www.myhanse.com/forum_posts.asp?TID=11426
Topic: 445 facelift wiring diagram
Posted By: Konstantin
Subject: 445 facelift wiring diagram
Date Posted: 15 June 2019 at 14:45
Can anyone please share a wiring diagram for 445 (2014 facelift version)?
I'm considering switching to Lithium with only changing my AGMs to Victron SuperPack's - the ones with built-in BMS and would like to understand what to do with engine AGM battery, thrusters batteries which are also AGM so should have difference charging settings.
Posted By: Matt
Date Posted: 17 June 2019 at 04:14
Hi Konstantin,
Albion is also a 2014 445. I only have the bow thruster but can say with certainty that it’s battery is charged from the house bank via a Victron 12v to 24v converter.
I do have some of the electrical diagrams around and if you send me a private message i’ll be happy to email them to you. Because of Hanse copyright they cannot be posted to the forum.
HANSE 445 #231 "ALBION"
Posted By: yacht1255
Date Posted: 19 June 2019 at 12:39
Cool boat
I want to buy a boat crownline 270 cr
something like this https://2yachts.com/models/1768-crownline-270-cr
Date Posted: 28 June 2019 at 15:04
PM sent, thx!
Posted By: OptiMystic
Date Posted: 20 December 2022 at 19:26
I Realize this is an old post but I have a 2014 445 that we are installing lithium on. Is it possible to pm me the wiring diagram. I haven’t found one online and it’s not included in the ships papers. Thanks in advance.
2539252020 text
markbertolin@me.com email
Posted By: G8WVW
Date Posted: 20 December 2022 at 21:38
Just emailed Hanse 445 wiring diagrams. Know 445 inside-out after 4-years of ownership. Also converted to LiFePO4 ... left me know if you're short of any info.
Cheers.
Andrea & Ian
Aboard SV Gabrielle (H445 #164)
Portishead, SW England.
Posted By: Etre Jeune
Date Posted: 29 December 2022 at 00:38
hello Ian,
I have hull number 5 in Australia, i have only had her for 5 months. And would be grateful of any information you have on wiring.
My email is stockie2@icloud.com
Currently running 2x 160 amp hour AGM
No extra batteries for the thrusters, Stern & Bow
Also have you any tips on the thrusters
My bow unit blows the small 7 amp fuse
On the unit?
Best Richard
R Stock
Posted By: Ian Coverdale
Date Posted: 29 December 2022 at 14:47
Hi Richard,
Electrical schematics sent to your email along with Quick thruster installation manual.
The schematics are full of errors especially around factory options but some information is far better than none!
Just a word of caution with the thruster. If you lower the thruster and are unable to raise it for whatever reason then you're gonna be stranded so suggest only working on thruster in safe area and be prepared that if stuck down, a haul-out may be required.
The Quick manual has a fault finding guide. There's a red LED on the control PCB that flashes to identify faults. You could also try disconnecting one end of the actuator arm to ensure it moves smoothly without additional load of thruster mechanism. You may find bow and stern thruster are identical (mine are) so you could swap parts to identify the fault. Think there is a control PCB link or DIP switch to identify whether the unit is a stern or bow thruster and of course if you swap the actuator, be aware the limit switches need setting up from scratch (see manual).
Good luck. Have to say these thruster units are my least favourite component; they are hugely expensive, complex, the GPS doors can fall off and if the thruster sticks down you're max speed is 3-knots in calm conditions. Not the greatest.
Cheers.
Ian & Andrea
SV Gabrielle (H445)
Posted By: mattplowman
Date Posted: 05 May 2025 at 03:01
Good afternoon all , I am the new owner of 445 #210 and would also like to obtain a copy of the wiring diagram if possible please?
Thanks in advance , Matt
matt.plowman@me.com
H445 #210
Posted By: Bakep
Date Posted: 09 May 2025 at 11:45
Hello
I am also a new owner of Hanse 445.
I am having lithium service batteries installed.
I will also be very interested in having the electrical diagram not having found it. The Hanse documentation is particularly poor!
Thank you for your help
I sens you my email adress
Marc
Posted By: Aniaclug
Date Posted: 28 May 2025 at 07:29
Hi, i am interested too in wiring diagram (#0023). Would be also great if such info could be shared in the manuals and drawings section.
Date Posted: 28 May 2025 at 07:38
All the 445 related manuals and documentation I have is here ...
https://www.dropbox.com/scl/fi/6rcdmyhija4jjbxgc3yz1/Hanse445manuals.zip?rlkey=nft15siyyko4jehhfqo8bb7rc&st=tolu6sm3&dl=0" rel="nofollow - https://www.dropbox.com/scl/fi/6rcdmyhija4jjbxgc3yz1/Hanse445manuals.zip?rlkey=nft15siyyko4jehhfqo8bb7rc&st=tolu6sm3&dl=0
Wiring diagram is called 'Hanse 445 Electrical drawings.pdf' in 'DC System'.
Cheers.
Ian & Andrea
SV Gabrielle (H445)
