Marc,
In answer to your questions- based on our 2014 575 with 230V 50HZ system-
1. two 16A inlets are provided one for aircond and the other general systems. 2. All systems run off the generator. You may need to watch what you are running because you may have a great power requirement than the generator can supply depending on the options you have onboard. I think there are now two generator options 8KVa and 10KVa. We have the 10KVa. 3. In general, the items which run off the inverter are - GPO, Gallery, TV, wine fridge. All other items do not run off the inverter - eg Air cond, washer dryer, water heater. 4. All outlets (GPO) are supplying 230V 50HZ and the standard socket is the European 2 " round" pin. 5. Any appliances supplied as options are 230V 50HZ eg coffee machine, washer dryer, dishwasher, TV etc. 6. All items onboard can be run off shore power with the aircond having its' own 16A inlet. Again you may need to juggle what equipment you have on so you don't overload the shore power. 7. There is not an amp meter supplied for either the generator or shore power so you can see what amps you are drawing.
If you are eventually considering taking your 575 back to the US I would think your resale value would be less if your boat was 230V 50HZ. I would expect it to be much more difficult to sell. It is not a simple option to change a 230V 50HZ set up boat to be 110V 60HZ boat. The cabling, colours and sizes are different for the EU/US systems, plugs are different but easy to change, the generator could be changed over but at a substantial coast I would think, inverter/chargers would need to be changed, not sure about the aircond, certainly components like the RW supply pump would need to be changed and possibly the FCUs etc would need to be changed. Some items like the TV may be "multi voltage" and would be OK. If you were taking your 575 back to the US I would get it built to the US spec. You would need to bring any appliances with you from the US for a Europe delivery and "holiday". This way all your onbaord systems and plugs etc would be 110V 60HZ. Your only issue then would be shore power which could be handled with having a step down converter (230V to 110V) and a frequency converter 50HZ to 60 HZ) fitted. You can get a "shore power conditioner" but these seem mainly aimed at larger vessels (super yachts) and are large and heavy and expensive. These "conditioners" are designed to be able to take on any voltage/HZ/phase combination and supply your boats requirement. These do a lot more than you would be after. The pain of having to deal with the shore power issue whilst in Europe would out way the problems of having a 230V 50HZ boat back in the US. Just my 2 cents. Maybe some other US based forumites have some input!
