Wayne, good thoughts.. see comments:
1.
Fit Dyneema lines in place of the SS safety lines on the aft and side
gates. This was also partly to make these lines easier to handle when in
port.
* Good idea... right now this isn't much of an issue, though
2. Fitted a per pre filter to the fuel system. This has
a glass bowl which can be easily checked for fouling . I also fitted a
drain cock to the standard Volvo pre filter which originally had a hex
screw-in plug.
* I'll lump this into the design of the dual racor/filter system mentioned above. An option.
3. Fitted a manual bilge pump in the forepeak where there was no pump.
* I like this idea. I was going to put an electric pump in, driven by the thruster batteries, but wasn't sure where to pump it out. Did you put a discharge hole in? Or send it to the anchor locker for draining that way?
4.
Upgraded the standard bilge pump in the center bilge area with a higher
capacity and high duty cycle unit. We carry a spare for the two
electric pumps on board.
* Did that. I took the 1000 Rule out of the main bilge and replaced it with a 2500. I then took the 1000 and moved it to the mast bilge which was an 800 (and didn't seem to work anyway).. I have a spare bilge pump on board.
5. We lengthened the "roaming" bilge pump suction line as the original one could not reach the forepeak.
* Interesting. it was plenty long for most of the interior needs we had
6.
For any longer trip and overnight trips we fit jack stays from the aft
cleats to the forward cleats. We also fit a "T" shaped jack stay in the
cockpit from the companion way to the aft and outboard of each steering
position.
I have jacklines for both sides as well as d-rings in the cockpit. Our life jackets have personal signal devices (AIS, not EPIRBS for now) and the boat has an EPIRB with GPS. Where do you attach the "T"jackstay in the cockpit. We just have bungee harness lines to the d-rings for rough weather.
7. We fitted the usual dive knives by each steering position and one to the vang.
* Explain this one. I usually just carry a knife on me. Attaching them to the vang and at each station has what advantage?
8.
We always wear Spinlock infaltable lifejackets/harness's when on long
trips, overnight or if the weather is strong. We have recently fitted
the RescueME MOB1 AIS beacons to each jacket. We also replaced the
"pylon" lights on these jackets as they have a bad habit of not working.
We fitted SOLAS water activated lights in place of the pylon lights. We
also fitted two of the water activated Spinlock Lume On lights which
shine through the bladder and make the wearer more visible at night in
the water.
* As said above, same beacons are on our inflatable jackets. Mine is a spinlock as well and I change the cartridges and tablets every year after testing the jacket for holding air. I have whistles tied to the jacket as well as a strobe. Its usually just myself and my wife sailing, so we go all out. I also have a 6 person, ISO certified life raft (in a bag, not on the rail) that I can haul out from the life-raft locker. I'm worried that sounds easier than it will be in an emergency, but for now its the plan.
9. We originally had the Spinlock safety tethers
but have now changed to the Kong double safety tethers (one leg normal
length and one short- both elasticated) with a quick release. The
carabiners on the Kong are much stronger and I like the idea of the
quick release rather than trying to find the pathetic safety knife on
the lifejacket.
* I saw the article on the tethers and shackles in PS. We have not upgraded our tethers to date, but I understand the issue. My tethers are single length, bungee retracted, high shock rated. That said, I know they could change for the better.
10. Again for the longer crossings where we
are out of AIS/VHF range we have fitted a Iridiun GO with auto hourly
positional updates. We could also take the Iridium Go with us in case of
abandoning ship.
* I like this idea. I was just going to get a SatPhone for general use as well when sailing offshore. That and finally get an SSB (don't have one now).
11. We of course have a 6 person liferaft on board. Recently serviced for the next crossing. *As well. Mine came from LRSE in RI. Very well known firm for survival gear.
12.
We have always had a EPIRB onboard. At home in OZ any boat of any size ,
as well as jet skis etc which go further then 2nm off the coast must
have an EPIRB.
* ACR GPS EPIRB on board. Registered beacon with another year on it before the batteries need to be serviced. Again LRSE.
13. We have an electronic flare onboard which
although does not replace the need for conventional pyrotechnic flares
would be much safer in a liferaft.
* I have a floating ditch bag in the same locker as the life raft with the following in it:
Handheld VHF and GPS combo A 25MM flare gun with 2 parachute flares and a 12GA adapter for normal flare shells Unexpired flares to meet Coast Guard regulations First aid kit Water a couple of MRE (US military term - 3 lies for the price of one)
A few bags of my old expired flares separated and labeled as "EXPIRED". What the hell.... they probably will work, so....
14. Although not strictly safety equipment we use Bluetooth headsets when anchor or more importantly when working up the mast.
* I've been thinking of this, but more for anchoring...Which ones?
15 When working up the mast I always use a second halyard with a fall arrester/desender.
* I just have a second halyard as a backup. As one is hauled up, the slack is taken up on the other. I also *NEVER* rely on the shackle. I tie a bowline for both.
16.
Training - we have both completed commercial safety at sea training
course like the STCW which included safety drills, firefighting and
liferaft use (in a indoor facility which has a wave tank, wind and can
be blacked out - so fairly realistic).
* I've gone thru the US Coast Guard courses, but not the offshore safety ones. Good idea. I've learned that all your plans can go to #%@#@# pretty quickly and you need to think about Plans B, C and D as well...
17. Apart from the
standard 3 x 2kg dry chem fire extinguishers we have also fitted 2 x 2kg
CO2 extinguishers and a fire blanket.
We have four chemical fire extinguishers on board. Different types as required for engine/cooking and different sources.
18. if it comes to
cutting a broken rig ways we have a giant pair of shears, 2 hacksaws
with 4 spare blades taped to each and a cordless 18V angle grinder
fitted with a cut off wheel. I have tried the shears and they are great
for small cable but would be difficult to use on our rigging. The
hacksaws will get the job done. The angle grinder is very quick to cut
through any size rigging.
* I originally brought over my bolt cutters from the prior boat. The heavy things could cut padlocks, chain and other seemingly indestructable objects, but then I saw the shrouds on the 575. They were not going to do the job. I have an AC grinder with carbon/diamond cut-off wheel and assumed that might be the way to go.
19. Again, mainly for the longer
crossings we have Panasonic Tough note book with GPS, nav software and
world wide charts. So if the boats normal nav equipment went entirely US
we can use the note book which is waterproof and shock proof etc to a
MIL Spec.
* I looked at the Mil-SPEC tablets on the last boat. Good idea for a backup. If you roll or take a ton of water you have to assume everything will have gotten soaked.
20. It probably goes without saying but a schedule
of replacement, servicing, testing, inspection and upgrading (where
applicable) of equipment is part of the safety on board.
* Already have a maintenance log. Most of it is tied to spring/fall commissioning/decommissioning, but others to engine or generator hours. Some, like lubricating seacocks or cleaning / rebuilding winches happens in the spring.
I
agree that the Hanse option of fitting the "plastic" through hulls with
brass valves is probably not the best I would probably opt to replace
the valves with the matching "plastic" valves rather than go back to all
metal.
* I've looked at the Marlon one piece units and I'd rather have those than what I have now. That said, most of the work in replacing these is labor. A 1 1/4" bronze seacock is about US$100 and the marlon are pretty much the same. Sometimes more. Call me a traditionalist :-) I already have the bonding system in place, so...
Thanks for the tips!
