Running rigging
Forum Name: 505/508
URL: https://www.myhanse.com/forum_posts.asp?TID=11867
Topic: Running rigging
Posted By: chillios
Subject: Running rigging
Date Posted: 29 March 2020 at 05:53
Hi. Has anyone replaced their running rigging (and recorded the specs of the original rigging?)
With the quarantine, we can’t get to the boat to measure.
Posted By: chillios
Date Posted: 06 April 2020 at 15:28
UPDATE:  Please see below specs:
Main Halyard - Art # 02000-1200
Liros Regatta 2000, D = 12mm
Breaking Strength daN
 - 7,200
steel blue tracer threads blue, one side spliced
Key shackle 8mm "Wichard Hiload", splice stripped 70mm
one side hot-cut
Finished length 49m - 1 pc.
Jib Halyard - Art # 02000-1200
 - 7,200
steel blue tracer threads red, one side spliced
Screw shackle 10mm, splice 70mm stripped,
hot cut one side -
Finished length 47m - 1 pc.
Boom Lift KLM - Art # 00152-0800
Liro Top Cruising, D = 8mm
 - 1,650
white, one side knotted screw shackle
8mm (import), one side hot cut
Main Sheet MB - Art # 00152-1400
Liros Top Cruising, D = 14mm
 - 3,800
white, both ends hot cut -
Finished length 50m - 1 pc.
Jib Sheet - Art # 00152-1400
3,800
white tracer thread black, one side spliced eye 40mm,
hot cut one side -
Finished length 40m - 1 pc
Posted By: Ken Haas
Date Posted: 22 August 2020 at 18:58
Can you tell me what size boat these dimensions are for?  I am looking for specs to replace the running rigging on my 341.
Thanks,
Ken
Date Posted: 22 August 2020 at 20:40
A slight mistake, you have posted this in the 505 section of the forum, rather than the 341/342 section.
If you go into advanced search and put in "halyard length"  ""any date" and select the 341/342 forum, you will find a number of answers.
I actually bought a full drum of dyneema for the halyards, as it was actually cheaper than buying the 2 separate lengths and I think the piece left over is just long enough to be a spare.  Definitely fit dyneema on the halyards.
Posted By: chillios
Date Posted: 30 May 2024 at 12:35
The specs are for a Hanse 505.
Posted By: chillios
Date Posted: 09 June 2024 at 20:48
A couple of updates to running rigging for a 505.
Vang length is 47ft.
We have fitted a 3rd reef in our main , so we have a now have a single sided Main Sheet , this reduces our main sheet to 90 feet.
