301 Teleflex cable replacement
Forum Name: 300 / 301
URL: https://www.myhanse.com/forum_posts.asp?TID=12086
Topic: 301 Teleflex cable replacement
Posted By: DavidC
Subject: 301 Teleflex cable replacement
Date Posted: 22 July 2020 at 14:38
Have just bought a 2000 301 with 10 hp engine. TFX engine control unit. There is an issue with the throttle cable which has temporarily been sucessfully jury rigged. I have read the posts that indicate to access the control you have to cut through the side of the gas locker which seems a bit extreme. Just wondering if anyone knows of a less invasive workaround before i get the jigsaw out.
Posted By: Taylor
Date Posted: 23 July 2020 at 13:26
I was the one who has posted. I felt it should be easier to remove the gas locker than cut a hole in it. I perhaps got too impatient. It is held in by the  6 screws that fasten the three black gas bottle base blocks and a significant amount of Sikaflex. I would recommend being patient! You will then get the benefit of storing two camping gas bottles side by side at the rear of the locker once removed. A simple low bulkhead of plywood covered in epoxy has effectively replaced the single bottle box.
Hanse 301 Bluenote 11
Posted By: josefu
Date Posted: 12 January 2021 at 18:56
Hi!
I'm trying to remove the gas locker, but I don't see the screws. Are the screws screwed to the laterals or to down?
My gas locker was painted by the previous owner and I don't see it.
Best regards
Posted By: Taylor
Date Posted: 14 January 2021 at 21:44
The only screws were in the black plastic carriers under the gas bottle. The rest of the box is sika glued to the locker floor on its base and along the rear and side edges.
The base was the hardest part to cut loose.
 I believe there is a solvent that will soften Sika but I can't remember its name.
Posted By: josefu
Date Posted: 15 January 2021 at 07:55
My boat haven't the black plastic, I suppose that other owner remove  or broke it.
Thanks!
