Hanse 545 Baujahr 2010
Forum Name: 545/548
URL: https://www.myhanse.com/forum_posts.asp?TID=12108
Printed Date: 27 March 2026 at 03:47
Topic: Hanse 545 Baujahr 2010
Posted By: Walter
Subject: Hanse 545 Baujahr 2010
Date Posted: 29 July 2020 at 11:47
Bitte um eure Hilfe.
2 Wassertanks.
Anzeige zeigt einen voll. Einen leer.
Muss man umschalten? Wo sind die verloren?
Schönen Dank
Walter
Posted By: Wild
Date Posted: 16 August 2020 at 19:23
hello
Stind zie muss unschalten
Die absperrventiele sind Unter den bodenplatte in mitte zwishen tisch und zweisitser sofa.
Wild and Wet
Belgium
545e#268
Posted By: Walter
Date Posted: 16 August 2020 at 22:25
Herzlichen Dank
Liebe Grüße
Walter
Posted By: Ruchacho
Date Posted: 14 March 2022 at 15:02
hello do any members have the cutlass bearing size for Hanse 545?
Thanks andy
Posted By: Wild
Date Posted: 14 March 2022 at 17:36
hello Andy
The shaft diameter is 45mm
I believe the cutlass bearing is Brass 45x65x180 MM
But you better take the old one out to be sure.
Wild and Wet
Belgium
545e#268
