Swimming platform
Forum Name: 461 / 470
URL: https://www.myhanse.com/forum_posts.asp?TID=1235
Topic: Swimming platform
Posted By: tobo
Subject: Swimming platform
Date Posted: 30 April 2007 at 18:12
The first time I wanted to close the platform I almost fell into the water trying to pull the line. If you try standing inside the open lazarette you have no chance either because the line is so carelessly twisted just through a hole in the hull that the friction is just too high. I remember one dealer on the hanseboat saying ironically that they're doing that on purpose to leave all the opportunities to the owners to do it better. Ergo: I'm thinking of placing a block at the 90 degrees turn of the line and fitting in a 2:1 transmission. To avoid opening the lazarette when lowering the plattform I'll have to drill a hole into the deck (close to the side) which doesn't intake too much water. Maybe putting on a short tube before the line meets the cleat. Any better suggestions?
------------- Thomi
Posted By: Brad McMaster
Date Posted: 30 April 2007 at 18:30
Ha ha, i know what you mean!! I feel the factory quite likes to leave it up to the owners some times!!
I had a little bit of strap attach at the top middle of the platform that helps you get it out and deployed, as that can be very difficult, but then for bring it up again. Two options and neither is ideal but:
1) standing on the platform bring the ladder vertical, pointing to the sky and the sitting on the deck, one foot on that little step pull up , fold that ladder in and close, or
2) lie on your stomach and pull on the rope!!
in both cases you really need another person to pull the rope inside the lazerette so the weight is taken up.
Those bit of rope do no more than hold the thing in place!!!
Speaking of swim platforms has, mine does not come back flush on the transom on one side, the dealer is trying to sort it out, but has anyone else had this problem??
Brad
------------- GHOST - Hanse 470e - 058
Posted By: John Heath
Date Posted: 09 May 2007 at 13:09
Hi having taken delivery of my 470 in April 07 I viewed the boat in the factory and mentioned the transom boarding platform was well out of alinement plus many other items which they assured me would be put right before it left unfortunatly this was not the case and it was delivered with all the fault un corrected and they are being sorted by the agent but the boarding platform is a big problem as it needs to be taken off and thehinges re-aliened and is a big job structruly, also sail the boat for only two days we found there was no engine vent only to the lazeret so so had to cut these in just under the aft winch positions, the mast halyard exits chaffed the outer rope casings and need to be replaces and have found that Hanse ordered the most basic mast possible from Sparcraft so does not include the stainless steel guides. to conclude there are many problems in the finnish which has upset me having brought what I thought was going to be a grat boat
Posted By: leemind
Date Posted: 09 May 2007 at 16:01
On the issue of the mast and where the halyards exit it, I was surprised to see that they just exit through a slot in the mast with no protection from the sharp-ish aluminum edge. I did query this, and Hanse said it would wear smooth. Well over the last year the rope has chafed a bit, but also the mast has smoothed out as well.
Is it the view of the forum that one should fit protectors (Stainless??) in these slots or just let it wear to a natural finish?
Date Posted: 09 May 2007 at 16:39
You can get slot protectors from Sparcraft for a couple of quid a piece. The dealer should be able to order. I haven't used them (they are on order) so can't attest to their merit, although Charlie has and is happy.
On the other manufacturing issues. Yeah i hear you. There are some things that are not sorted and its just not good enough. I too have a "not quite flush" swim platform. But in Hanse's defense this is a production boat and the value for money is a function of the factory's one eyed approach of getting boats out the door.
However, (and this is for you Michael Schmidt as i know i echo the voice of the many here) if you want to make the transition from a smaller player and increase your production numbers to a larger scale, remember what got you where you are, a focus on your customers and quality. The factory should focus on the production of yachts, but for goodness sake empower your dealers to do what they do best and don;t get petty. Empower them immediately with all parts necessary and monies if required. If you can't manage this process, employ some who can, else suffer the consequences.
Now i'll get off my soap box and say... regardless they are great yachts. Strong, powerful, with industry leading ideas and fairly good value for money. But that won't be enough in the medium-term. The after sales service must improve. The dealers are great and doing all they can, but the factory is letting them down. Your clients are demanding and this website is your greatest selling tool. Don't waste it or them.
Date Posted: 09 May 2007 at 18:20
I agree with what you say, Brad. I think it's fair that a website like this helps build a company's reputation. If a company delivers a product that meets expected standards then a forum like this should be a great selling tool for them, and vice versa.
Posted By: Rubato
Date Posted: 09 May 2007 at 18:40
John and Brad...
I agree totally and will also add this. The service one gets from the Hanse dealer depends very much on the dealer themselves, some are great others not so. I'm lucky, mine is great. However, the time and energy of the dealer shouldn't have to be spent correcting issues created in the factory!!! The dealer has enough on his plate with the basic commissioning and installing all the odds and ends that we owners dream up to make our boat uniquely ours.
In addition, I find am perplexed that the fast hull form and structural quality aren't matched by quality gear and finishing. Euro styling is fine but it still isn't that good a quality. It is clear Hanse cheaps out and comments on it are all through this forum - winch sizes, block sizes, vents, ..... As an example, I've only had my 400e a couple of months, have used it maybe a half dozen times and already pieces of wood are falling off the companion way hatch having been held on by tiny screws and a bit of glue. Personally, I'd pay another couple of percent to have the gear and finishing quality match the rest of the boat.
Date Posted: 09 May 2007 at 22:58
Hi gents sorry for my rant the dealer is great and is sorting my problems and its a shame he is gentting the brunt of my complaints the boat is fantastic and having done 1100nm it did not give me the slightest douts in its capabilities we sailed from mill pond conditions to force 7&8 with 2.5m seas and we had one great sail in 5-7s covering 240nm in 30 hrs and thought the 3rd reef would be a good idea but the grin on my face took a day to ware off, with regard the price and build yes its good value but the basics should still be correct alll I expected was that these would be right did anyone have the mast boxed in and the deckhead seal work to prevent water pouring in I supose atleast as it was not boxed in I could see it leaking all for now and post all the problem etc later one thing I designed and had built my own seats.
John
Posted By: John Allison
Date Posted: 10 May 2007 at 05:52
Re bathing platform on 461 (smaller I believe than 470) - we simply hoist by pulling on one of the wire strops - and we drop by sucking the platform to horizonal postion, then holding strop to allow it to drop under control. Never ever used the bit of string or cleat - the weight of it and forward inclination keeps it in position in every condition.
I don't want to get sucked into the quality debate as we've had super service from the UK dealers and there does appear to be recognisable differences twix 461 and 470 specifications, but it does seem sad that Hanse Germany appear to be building a reputation for either not listening or not responding to owner issues.
I've wanted to know deck thickness for weeks - and did not want to drill to get it myself. Were Dominics calls responded to? Sorry no.
We did not like the idea of the autopilot box having to be built into one aft cabin. Talks with Lewmar designers proved it could be mounted in other ways so the cabin intrusion was not required, but would Hanse agree and change the mounting brackets? Sorry to say it was not to be.
However - all that being said - I've been checking out some Oysters, Tintrellas, and other slightly bigger cruisers for longer distance stuff - and guess thay come in around double the Hanse price for same length. Guess maybe we do get what we pay for.
JOHN
PS Don't box your mast in - as at least when it leaks - you'll see it.
Our rig pressure went off during winter months, mast came straight, deck seal opened up so you could see sky from below. Trouble was I was in UK and boat in Turkey where they had an exceptionally wet winter. So loads of water into boat.
Because of boxed mast a lot of water flowed over onto headlinings, and from them even flowed across saloon headlinigs and down side walls of both main cabins. Just has side headlinings out so full extent of water seepage was obvious.
Not an issue we can't solve - but suspect if our mast was not boxed in - we'd have maybe been made aware of possible issues before it happened and avoided the clean up.
PPS Absolute bastard of a job removing side headlinings in saloon. Have had to dissassemble glass boxes in order to get headlining out and they have more glue than screws holding them together. Again - if Hanse listened and put the side headlinings up in two parts - bit bit aft of glass boxes and small bit in front - the whole job would be so much easier........
------------- No longer a Hanse owner - but loved the one we had!
Date Posted: 10 May 2007 at 07:46
Hey John,
I completely agree. Like i said great boat but yes i too feel bad that the dealer has to bear the brunt of complaints that are the factory's fault and responsibility.
We don't have the mast boxed in. The dealer is very kindly sorting an alternative out for me. To be honest i don;t wanted it boxed in but would like to see an nice fabric finish or something. The little piece of wrap around the factory supplies is a joke.
On the water pouring in. I haven;t have this around the mast. But a note to all, have your dealer silicone up the three holes in the emergency rudder stock. The screw on close mech on the stock is shocking. It requires a lot of lube around the o ring, potentially a larger o ring and most likely the slots that allow it to push and screw need to be machined to allow more than a quarter inch turn as it doesn;t create a seal. The result is water in the aft cabins. However don;t despair, fill the three holes in side the stock and apply a little silicone around the seal on the cover (it'll easily come away if you need it, lets just hope nope of us ever do!!) and you are water tight. This is a jefa issue, but the factory should have sorted it.
Brad
Posted By: Charlie
Date Posted: 10 May 2007 at 08:31
I was getting set to box my mast in, but having read johna nd brads comments I will pause for thought.
What is the alternative you are considering Brad, I have wrapped my mast in headlining, with a velcro seal so I can take it off, but need to think more on the hole in the roof if I am not going to box in now.
Charlie.
Posted By: leemind
Date Posted: 10 May 2007 at 10:17
Blimy, I thought it was just me that had a leaky boat. I've had quite a few different leaks some of which have gradually been sorted, others that haven't.
My mast is boxed in (as standard I thought on the 461) so it took me a while to realise water was coming in there. Hanse UK put a ring of Sika above the rubber seal and that seems a lots better, though I think some still comes down the inside of the mast, and there is not a lot we can do about that.
It does seem like the reduction in price from the 461 -> 470 may have been a the expense of quality though. (IMHO of course)
Oh and to keep it 'on topic' - I wish I had known the diesel overflow exited out on to the swimming platform... filled her up for the first time only to discover a few days later that diesel had overflowed all over the platform and that rope and drained over the transom... nice
Date Posted: 15 May 2007 at 15:18
Re water coming down inside mast.
If you check your's out you might find there is a foam plug across the mast section just level with the spare spinnaker exit sheave. Halyards and cables run up through it via conduit.
It may not stop all water, but it should stop most.
We simply sealed the top of the boot with self amalgamating tape and seems we're pretty watertight now.
JOHN
Date Posted: 15 May 2007 at 19:09
Hi the mast leak I have is water running down the outside I havent looked to see if its coming from the inside as well we found that the mast necking seal ie the rubber bit clamped under the aluminium upper plate leaked and you can see daylight looking up we found that the retaining cap screws have shanks and bottomed out preventing the seal to be clamped so squoshing the rubber seal we have changed the cap screws for fully threaded and this has alowed the top ring to be pulled down tight and are about to hose test it all again, I would have thought that the manufacturers could have got something as simple as this right and the guys stepping the mast should have picked this up.
Posted By: J Guthrie
Date Posted: 16 May 2007 at 13:36
I've got a new 470 and I've found it quite easy to lift the platform using a boat hook on the small bit of webbing attached to the platform As its come up past the vertical it stays in place quite happily until I pull the chord inside the lazarette to secure it. The problem I've got is that the platform does not currently go all the way down as the bottom edge and the hull meet before it gets to the horisontal - does anyone else have this issue? At the moment Hanse are being very slow to address this issue so if anyone from Hanse is reading this can you please sort the problem out pronto as I've had the boat for several weeks now and have not been able to use the platform!!
Best wishes
Jonathan
Date Posted: 16 May 2007 at 16:35
Hi Jonathon,
If you are thinking of swimming off the back with current UK weather, maybe Hanse are doing you a favour in not moving faster to fix the alignment issue...........
JOHN
Date Posted: 17 May 2007 at 08:47
Very true, but chucking my 78 old father into the dinghy from deck level is a sight to behold.
Jonathan
Posted By: tobo
Date Posted: 27 May 2007 at 17:24
Attention: plattform ladder half broken after two uses! I don't know if this happened to others too, but it is very dangerous!! (Beeing used in Croatia not UK!, Water temp. 20 C)
------------- Thomi
Date Posted: 29 May 2007 at 20:10
Oh dear, i hope this is being sorted? Has the factory admitted responsibility? Is it something that we should all expect to happen??
B
Posted By: tobo
Date Posted: 30 May 2007 at 19:38
After one week aboard I finally found a good solution to close the plattform. First of all I replaced the hole by a block (s. pic) and then I made a 4:1 transmission. Inside the lazarette the line then goes down to another block and a cleat which I placed exactly in the line when you pull it. (But you have to open the lazarette).
------------- Thomi
Posted By: ziffa
Date Posted: 31 July 2007 at 16:53
Has anyone had a problem with their swimming ladder. The crews bolting the ladder to the swimming platform have come out. My dealer is very willing to help & has offered assistance in replacing the screws in question. My view is that the design of the ladder (i.e. where the ladder is bolted to the platform) needs to be upgraded as the base is not wide enough. A person's weight, with time will dislodge the ladder.
Date Posted: 31 July 2007 at 17:40
Hi There,
Yes i agree that the ladder is not structurally sound as is. Tobo, another owner had problems with the mid pivot point on his new 470 a couple of months back and posted details. I used mine for the first time the other week in the Solent!! (first and last time I'm swimming in the solent!) But i was a little disappointed with the thought going in to the ladder. But on the other had i love the fact that it folds away. Clearly i want everything!
I think the solution is reinforce the top connection and then add some wire from the top to the bottom on the ladder, kind of like the way the platform itself is supported. This might reduce the load on the mid joints and importantly stop the ladder from swinging under the platform when you try to climb up it.
This is something I'll turn my mind to when i know I'll be in warmer climes. So note for a while yet unfortunately!
B
Posted By: ziffa
Date Posted: 31 July 2007 at 18:11
Brad thanks for your comments. My view is that the top connection should not be a simple strip with 3 bolts in it (in a vertical line), but should be in the shape of a rectangular fitting which will make the ladder far more secure & will limit the effect of a person's weight when swinging / climbing up the ladder.
ZIFFA
Date Posted: 25 August 2007 at 08:56
We've not had any issues with the way the ladder is attached to the platform - but have seen the pelican clips (as fitted on the wires holding up the platform) slowly stretch out and deform over 3 years. Guess we've had too many fatties climbing on board!
Have replaced them with regular terminal ends and shackles.
JOHN
PS Have also added a blue webbing tab (our hull is blue) that fits under the ladder when it is dropped. This prevents the blue paintwork from any rubbing PLUS when made the right length, gives us a small tab to pull the platform open with.
Posted By: leemind
Date Posted: 28 August 2007 at 10:34
I've only used the swim ladder twice, both in the last couple of weeks. Once to dive under the boat to replace the anode and the last time 2 days ago.
2 comment: 1. The Solent is *~!%* freezing - not doing that again, and 2. The ladder is wayyyy to short. It barely goes under the water. I was thinking off adding a webbing loop to make another rung, but given I'm not planning to go in again, that job might have to wait!
Oddly enough, re: Johns comment about a a little tab, I have a small webbing tab in the middle of my platform to pull it open - as fitted by the factory.
------------- Grand Cru
Hanse 461#028
Date Posted: 29 August 2007 at 10:59
Ah hah! See, the factory does listen..........sometimes
But is the webbing tab also positioned at the point where the ladder folds over the platform edge? Where it can work to protect twix paintwork and stainless ladder?
And re ladder length....our 461 ladder folds down, then has a second fold, so we've two and a bit steps below water level.........no issues even with a fattie like me getting out OK.
Maybe its another small (but in this case negative change), that's helped Hanse keep the price down?
Posted By: ziffa
Date Posted: 29 August 2007 at 13:44
I totally agree with Leemind's comments. the ladder is far too short and in my opinion it is badly designed as the base (that is screwed on to the platform) is simply not wide enough to counter balance the weight of a person using the ladder. It only has one fold not two. We swim off the boat every weekend, and the ladder has marked the edge of the platform. I have asked my agent to lodge a formal complaint to Hanse because we have tried two attempts to secure the ladder to the platform & each time it comes off.
David
Posted By: leemind
Date Posted: 30 August 2007 at 12:22
How funny are these things. The webbing strap is very small right in the middle, so nowhere near the ladder. Just helps to pull it out if you are leaning over the back -- I doubt I could reach it if I were in the water and the platform was up though (thinking back to that allegedly dreadful film 'Adrift' where those people jumped in the water from a yacht and couldn't get back on board)
2 folds!!!! What is going on... Ziffa & I have been short (literally) changed! Just one fold for us
Hanse 461#028
Date Posted: 30 August 2007 at 23:26
arrhh the webbing strapQ i think that is a hamble addition. Thanks Peter & Co as i don;t believe that is the factory's doing!!
I'm curious, have others suffered as tobo has with the welding pulling apart. I haven't yet but on the two (cold) occasions i have i have looked at these joints and wondered how long they last?
B
Date Posted: 14 September 2007 at 17:42
A weld is a weld and only as good as the guy handling the welding kit.
Our ladder shows no signs of coming apart and its possibly been used more than most others over three years - but I'd quite agree it is stupid and wrong that new owners have to worry about such quality / safety issues.
JOHN
