Push Button Latches
Forum Name: 430
URL: https://www.myhanse.com/forum_posts.asp?TID=12515
Topic: Push Button Latches
Posted By: scott.lawson
Subject: Push Button Latches
Date Posted: 07 February 2021 at 08:31
Hi, I have a standard 2008 Hanse 430E and need to replace several push button latches. Can anyone tell me where I can get replacements. Need about 10. Cheers
Scott
Date Posted: 07 February 2021 at 09:25
Hi Scott,
some latches should be in the Hanse spares set.
If you need more, you can order them through the Boatoon Hsnse shop.
They are reasonably priced
Posted By: Dogscout
Date Posted: 07 February 2021 at 13:40
I have found that if you unscrew the knob and shoot some WD 40 into it, it stops the binding and failure.  No guarantee but some of mine were failing and it helped.
Adventure awaits
Posted By: perry
Date Posted: 07 February 2021 at 14:58
The push button draw and door catches are common on European motor homes [recreational Vehicles].
https://www.ebay.co.uk/itm/10pcs-Push-Button-Catch-Lock-Cupboard-Door-Cabinet-Camper-Caravan-Latch-Knob-UK/203078539439?hash=item2f486c98af:g:WSAAAOSwOwJfRjHN" rel="nofollow - https://www.ebay.co.uk/itm/10pcs-Push-Button-Catch-Lock-Cupboard-Door-Cabinet-Camper-Caravan-Latch-Knob-UK/203078539439?hash=item2f486c98af:g:WSAAAOSwOwJfRjHN
However I have refurbished them by simply strip and cleaning the sliding mechanism.
Current Yacht Hanse 315 2007
Posted By: Norman John
Date Posted: 07 February 2021 at 16:56
Noted that you had sailed around Britain.  That is a trip I would have been interested.  With time constraint might look to sailing from Solent up West Coast to Scotland and returning.  Did you find a detailed pilot book for your trip? Any advice would be very welcome.
Norman Payne
Posted By: perry
Date Posted: 07 February 2021 at 20:50
Hi Norman,
Check my Private message
Perry
Posted By: Yeoey
Date Posted: 11 February 2021 at 08:58
Hi Scott,
I think I have listed this in the past in 415 section but lubricating  the latches simply does not fix the problem of my wife placing too much inside our cabinets and placing pressure to lock- then the stupid Hanse fitting breaks - ring Rivierra Yachts on the Gold Coast - their base component is all you need, not the push button part. Their products is a  stronger where they break - ie better designed. It is an exact replacement and less than $20.
Peter
Sea Rambler 415 # 137
Posted By: Yeoey
Date Posted: 11 February 2021 at 09:00
Scott
Here is the link
https://rivieraparts.com/collections/latches-catches-and-locks" rel="nofollow - https://rivieraparts.com/collections/latches-catches-and-locks
Sorry Re price guidance - you will get 3 fir $$21 plus postage
Peter
Date Posted: 17 February 2021 at 07:00
Thanks for all the replies. Ended up getting an 8-pack off ebay and they have arrived and been installed. All my latches work now! Happy wife, happy life. Next job, replace the hot water heater. Looking at tha same isotherm, any views?
Posted By: 415 Singapore
Date Posted: 14 March 2021 at 10:21
Hi Yeoey
Thanks for the recommendation, I ordered 10 latches from Riviera and they arrived within 1 week. Far more robust than the original Hanse ones and half the price!
All the best
Paul
Paul - Night Train - 415 #136
Posted By: Yeoey
Date Posted: 14 March 2021 at 10:57
Hi Paul,glad that I could help-
 I am slipping Sea Rambler this week and am going to remove rudder for its first service (SR was launched in May 2014)
The Hanse support payers provide a copy of Jefa’s fact sheet and instruction that the rudder post to the blade should be inspected every 3 years - have you done yours yet? And if so was the process the same as covered in the relative Jeff video?
As an aside I have spoken with the Australian distributor (almost next door to Rivierra at Coomera) and he supports the guidance as I would expect , however he said it is a maintenance issue that many neglect with result around 10 years of total bearing replacement due to the #haft expanding via electrolysis/ rubbish build on the shaft which makes the delron ball pressuring the side rollers leading increased friction etc
Peter
Peter
Date Posted: 14 March 2021 at 11:41
Hi Peter
I wasn't aware that Jefa recommend that, it seems quite a short cycle. Night Train was slipped last May and we partially dropped the rudder (the yard we use has hydraulic trolleys rather than travel lifts so getting enough height to take the rudder out completely is an issue) All looked ok after 6 years so we just pressure washed it and put it back.
When we first got the boat there was an earth cable fixed to the rudder quadrant, on advice from Jefa and subsequently confirmed by Hanse we removed this, so I hope electrolysis isn't an issue.
All the best
Paul
Posted By: Yeoey
Date Posted: 16 March 2021 at 05:32
Hi again Paul
This is link to Jefa instructions -  https://www.jefa.com/maintenance/maintenance.htm" rel="nofollow - https://www.jefa.com/maintenance/maintenance.htm  where it mentions every 3 years
Didn’t slip Sea Rambler today due to rain forecast so have rebooked after Easter and will see how it goes - agent said it only takes about an hour to remove - be interesting if that is an hour by the clock or “about an hour “ in boat yard time
Peter
Peter
Posted By: Helios_ri
Date Posted: 01 April 2021 at 02:36
Hi, which item in the catalog are you referring to? I don't see 3 for $19?
Posted By: Yeoey
Date Posted: 01 April 2021 at 02:47
hello
Please see my 2nd or 3 posting - it clarifies price from one for less than $20 to 3 for $21 plus postage - I think it is the first item on the page.
I haven’t followed up the other matter yet related to rudder service as my slip time allocation is not until next week.
Peter
Peter
