Whale Gray Water Sump Box
Forum Name: 505/508
URL: https://www.myhanse.com/forum_posts.asp?TID=12778
Topic: Whale Gray Water Sump Box
Posted By: SVZara
Subject: Whale Gray Water Sump Box
Date Posted: 24 May 2021 at 23:21
I can't seem to figure out how to open up the whale gray water sump box. I have tried unscrewing it, and it just spins. I tried using a flat head screw driver to try to pop it open, but it feel like I am going to break the lid and didnt want to push too far. What am I missing?
------------- Marc S/V Zara 2016 Hanse 505, Hull #129
Date Posted: 25 May 2021 at 02:14
Hi Mark. First off, the screws don’t hold the lid on. They hold the water sensor on to the lid. Also, it does NOT pry off and will break if you try. The trick is to use the two recesses on the lid (where the screws are), to spin it counter clockwise. It may be stubborn. If it doesn’t budge, you can try to gently tap the recesses sideways ( to spin it) with a piece of wood and a small mallet to get it started.
Posted By: SVZara
Date Posted: 25 May 2021 at 03:05
Thank you! I guess I was being impatient when I didnt see progress when I was turning it. I got it off.
