Port holes and hatches
Forum Name: 430
URL: https://www.myhanse.com/forum_posts.asp?TID=12926
Topic: Port holes and hatches
Posted By: AndersOtt
Subject: Port holes and hatches
Date Posted: 05 August 2021 at 15:20
Another question form a (potential) new owner.
After 12 years, the paint on the black painted stock Lewmar portholes is flaking off badly. The result is not only cosmetic. The pitting/corrosion is also creating very slow leaks in a couple of them. I either need to replace or rebuild. One of the haches too, is leaking but here I would simply get new seals.
Lewmar does not keep boat specs and will need lens codes. I did not hear back from Hanse so i am asking this forum if any one have gone through the same refit and can share the lense codes for the:
- 6 opening opening portholes
- 3 opening flush hatches
Thanks you once again,
Anders
