Jabsco E-Toilet filling
Forum Name: 505/508
URL: http://www.myhanse.com/forum_posts.asp?TID=13007
Printed Date: 25 January 2022 at 10:53
Topic: Jabsco E-Toilet filling
Posted By: tobo2
Subject: Jabsco E-Toilet filling
Date Posted: 12 September 2021 at 09:04
On our 508 we have Jabsco Deluxe Flush E-Toilets. After use and rinsing they start filling up again after about half an hour. Does anybody know where to search for the issue? Is it a leaking valve of the blackwater tank or is it coming from the toilet gear directly? (sorry for the pic)
Posted By: Matt
Date Posted: 12 September 2021 at 13:42
I have Jabsco Liteflush but usually changing the joker valves resolves this for me.
HANSE 445 #231 "ALBION"
Posted By: Tranquillity
Date Posted: 12 September 2021 at 19:26
Normally the Jabsco toilet backing up is the joker valve which is pretty simple to change, just two screws to gain access. Lots of YouTube videos on the prcess well worth watching first. Good luck!
Posted By: Nelson01
Date Posted: 13 September 2021 at 06:44
Hi Tobo
Just lived this situation.......Joker valve.........on our electric toilet, it is part number Jabsco 29092-1000.And yes easy job.
We flushed 2-3 buckets of luke warm water to clean pipes before changing valve.
Marc
H508#11 UNEVIE
Posted By: Peter Russell
Date Posted: 13 September 2021 at 08:08
Agree it is the Joker Valve and generally easy to replace.  Just watch it when you screw it all back together as sometimes it can be a tight fit and you are only screwing into the plastic fitting so it is easy to strip the thread.
Peter Russell
Posted By: tobo2
Date Posted: 19 September 2021 at 17:25
It looks like an easy job but the bowl is fixed to the wall with Sicaflex. For a world leading company it is a shame that these valves don't hold not even two seasons. Even the fact that you have to demount the bowl to fix the screws for the toilet seat deserves the price for most unfriendly customer service solution! And if you have to flush at night you wake up the whole crew! Noise insulation is a strange word to Jabsco.
So I'm really thinking of throwing these e-toilets out (there are three of them) and exchanging them with Tecma (Osculati) types. We had it on our 470 with no issues for at least six years. What is your opinion?
Posted By: ohthetrees
Date Posted: 19 September 2021 at 20:54
Iím not a fan of Jabsco either. But all toilets with a Joker Valve arw susceptible to this kind of leak. The valve usually doesnít fail in the way you think, it usually gets mineral build up from urine and sea water, and the buildup causes it not to seal properly. This can be fixed by flushing a bit of muriatic acid (a.k.a. hydrochloric acid, available at hardware stores) down the toilet. If you have heavy buildup, it will take several rounds of treatment. I have fixed leaky joker valves this way many times.
In the future, build up can be mitigated by flushing with more water so urine does not sit against the valve, switching to freshwater flushing (seawater causes more buildup than fresh) and if if you donít want to do those things, treat with muriatic acid once a month or as required.
Posted By: Pzucchel
Date Posted: 19 September 2021 at 22:33
I have the same issue reported above. However, I could find no videos describing the replacement of the joker valve in an electric toilet. Am I wrong? Suggestions?
Hanse588#55
Posted By: Pzucchel
Date Posted: 19 September 2021 at 22:35
Won't muriatic acid damage the bowl, or other toilet parts? Do you have a suggested concentration, or you pour it pure from the bottle directly into the hole?
Hanse588#55
Date Posted: 19 September 2021 at 23:27
Muriatic Acid does not react with any of the parts in my jabsco manual toilet, plastic hoses, and plastic holding tank. I *do not* vouch for other types of toilets including your electric Jabsco.  But most ceramic and plastics are immune to this acid. I put about 0.5 liter full strength into the toilet along with about 1 L water, flush half, and wait 20 min or so, then repeat. If you have heavy build up it may take several times. Do wear goggles and gloves, it can seriously burn you.
Posted By: pap45
Date Posted: 20 September 2021 at 01:16
Here is an article you might find useful or at least interesting reading.
https://www.practical-sailor.com/systems-propulsion/joker-valves-for-marine-heads" rel="nofollow - https://www.practical-sailor.com/systems-propulsion/joker-valves-for-marine-heads
Posted By: tobo2
Date Posted: 21 September 2021 at 10:48
That's a very good tip, thanks a lot. I will ask the pros in Lagos when we go to winter hard stay.
Date Posted: 21 September 2021 at 11:02
Very useful Practical Sailor article. Thank you for sending on as have seen so many different views on this subject.
