Lewmar aluminium frames
Forum Name: 445/455/458
URL: https://www.myhanse.com/forum_posts.asp?TID=13105
Topic: Lewmar aluminium frames
Posted By: Richard M
Subject: Lewmar aluminium frames
Date Posted: 17 November 2021 at 12:58
Pretty much all the Lewmar hatch frames on my 2016 455 have started to bubble; clearly corrosion has taken place beneath the powder coating. This is disappointing as I've always taken great care with washing down etc.
The issue is - at this stage - more cosmetic than anything else but will doubtless get worse.
Any warranty expired a long time ago (I did check).
Am I alone with this? I suspect that the powder coating was a deficient batch when it was carried out. Any thoughts as regards rectification? Remove hatch surrounds - have them sandblasted - then re powder coated? Altenatively just hand sand and touch-up as best as possible (although I don't think that this treatment would last very long). Or start with new hatches? Will be a big cost.....
Many thanks
Richard
------------- Richard M
Posted By: Carlosailfan
Date Posted: 17 November 2021 at 15:32
Hello, same problem on our H385 2014, had to replace already 5 of them by new. Think to recover the old hatches by sandblasting and powder coat them again. Not yet done due to lack of time and priority :).
At the early beginning you have no corrosion under the loosing paint, looks like the paint is not well glued to the metal. When i removed the peeling paint the aluminum looked brand new :).
So quality issue out of warranty :(.
------------- Best regards /C
Date Posted: 17 November 2021 at 15:44
Hi Carlosailfan
I suspected that I wouldn't be alone! The symptoms that you describe are exactly the same as mine.
I wasn't too clear - are you saying that you have already replaced 5 hatches with new ones - and in future you will sand blast and have re powder coated?
Best wishes
Richard
Posted By: 350Bob
Date Posted: 17 November 2021 at 17:27
We had similar problems about 3 years ago on our 2009 350. We were advised to get them sand blasted and chromed; three years on they are still looking good with the occasional wipe down and polish.
Bob
------------- H350 #205
Posted By: Butcherboy
Date Posted: 17 November 2021 at 23:17
Hi, our H385 from 2016 is showing signs of flaking of the powder coating, I’ve rectified the two aft cabin cockpit frames which are black by rubbing down etch priming and spraying satin black to match,no problems since. Next spring I’ll set to and do the side coach roof frames that are covered by the Perspex opening hatches, removal of the frames would be quite involved so masking up and spraying in situ (once the Perspex openers are removed) before they get to bad is the way I’m going ,if they corrode badly they may well cause leaks by not allowing the rubber to seal against the corroded area if indeed the corrosion extends far enough. Talking to a mate who’s Lewmar hatches on his Bavaria motorboat have corroded badly, he’s bought one hatch frame at an extortionate price and removed one at a time and had them re powder coated locally at a very reasonable cost £10 each! The powder coater noted that no primer was applied to the alloy originally which is why the coating breaks down ….so I’ll see how they fare in the course of time! It amazes me how many powder coated frames corrode in such a short time if it was on a car there would uproar, the salty air has it’s part to play and design esthetics has moved away from anodised frames which is much more durable or is it cost cutting? Andy .
------------- Andy 385
Posted By: 415 Singapore
Date Posted: 18 November 2021 at 01:20
Hi Andy From our experience, if the powder coating is starting to flake off the outsides of the frames, it will be flaking off the underside of the frames too. If this happens the paint sticks very nicely to the sika seal but not the frame and you will get leaks. I too was worried about removing the frames as they are quite flimsy, but it turned out to very easy as the was no bond between the frame and the sika, I took out the screws and just lifted the frames out, indeed if the boat had been upside down they would have fallen out! We then cleaned up the old sika and re-bedded the frames in new sika. No more leaks. I wouldn't recommend spraying in-situ as you will not solve the real problem that will cause leaks in the future. There are various threads on this site about this if you use the advanced search function and change the date parameters (default is last six months)
Good luck Paul
------------- Paul - Night Train - 415 #136
Posted By: Wild
Date Posted: 18 November 2021 at 08:58
hello Andy, In the search function “Lewmar painting “ in the year 2018 “I put a tread about this problem with the FLUSH HATCHES LEWMAR in 2012. A few years later the same problem with the new 2 generation one’s . Lewmar changed the Flush hatches 3 times since then : Original then 2 Generation and later the 3 generation( other frame and rubberseal)?????
A few years later the black LEWMAR MITRE PORTLIGHTS( same as they put in the Bavaria) of the 2 back cabine’s starts the same problem. No warranty. Lewmar make me a price just for the frame (900x270 custom made for Hanse they say) of 950 euro per piece????? I try to take them out .Mission impossible without destroying the frames.  I sand all the paint and dirt off in-situ and put special primer and 2comp paint on. Now after 5 years the painting start coming off again. IMO the corrosion of the alu is to deep and very difficult to sand completely out.
Date Posted: 18 November 2021 at 09:40
Hi Bob
Chrome plating is an interesting thought. May I ask how much the plating (and sanding?) cost per frame? I realise that we are in different countries.....
Many thanks
Richard
Date Posted: 18 November 2021 at 09:44
Hello Paul
When you had removed the old frames what did you do? Install new ones - or clean and powder coat or something else.
Richard
Date Posted: 18 November 2021 at 10:18
Hi Richard, no we just wire brushed what was left of the original powder coating off, sanded, cleaned and spray painted the old frames. It was quite obvious that Lewmar hadn't used any primer as what paint there was on the frames almost fell off. When we took them out, all the original paint on the bases of the frames was still neatly stuck to the sika, like powder coated mastic! All the best Paul
Posted By: Wild
Date Posted: 18 November 2021 at 11:05
Posted By: iemand
Date Posted: 18 November 2021 at 12:15
I would considering to go for pure anodization instead of this white powdercoating.
Date Posted: 18 November 2021 at 12:19
Hello Paul
I had hitherto considered Lewmar to be a reputable brand. But as so many have be affected then I'm not so sure anymore. Lewmar changed hands in 2019 - now owned by an American company - Lippert.
Best wishes
Richard
Date Posted: 18 November 2021 at 12:21
Thanks iemand.
I will look into this option.
Best wishes
Richard
Posted By: AndersOtt
Date Posted: 19 November 2021 at 20:43
Hi Bob,
Do you have a photo of the Chrome finished outcome? Im in the same boat and am planning to sandblast, prime and powder coat black. However, this may be a good alternative.
Anders
Posted By: 350Bob
Date Posted: 19 November 2021 at 20:48
Hi Anders, I am sorry but I don’t have a photograph, but they look good with no sign yet of any corrosion reoccurring. As the boat is in Greece I won’t be able to take any photographs until April next year.
Bob
Posted By: iemand
Date Posted: 19 November 2021 at 21:14
For me it is quite simple: Powdercoating never works on the long run in a marine enviroment. You can see that also e.g. on some white coated Steering columns. Anodizing is the only long time solution for aluminium. If a customer like Hanse is asking Lewmar strongly to deliver pure white or black aluminium than powdercoating it the only option. Maybe it works on anodized aluminium as well but I am not shure.
Date Posted: 19 November 2021 at 23:45
I agree fully with iemand. If going through the process of removing the aluminum frames and sandblasting, then having them anodized clear or black, is the best option. Cost will be about the same or less and they will last the life of the boat.
Posted By: Matt1
Date Posted: 16 February 2022 at 15:44
I'm now having this problem in two of my hatches, despite the boat being only 3 years old. Dissappointing! It (or potentially a different leak) have caused damage to the bowthruster, an LED light and rusted some locker hinges as well! It's getting expensive! I'm talking with a local supplier to get the frames anodized for a very reasonable £30-£40....which begs the question "Why didn't Lewmar do this in the first instance" especially now this is a widely known issue. The potential challenges with this approach appear to be:- 1) How to remove the frame without damaging them (mine have only started to fail, so are still well adhered to the deck after I remove teh screws). Because these hatches are "flush" its very hard to get access under the flange of the frame becuase of the surrounding GRP 2) How to prepare the frames for anodising. My supplier is saying that blasting will leave them too rough and I'll need to get them polished of "brushed" first Anyone with any experiences? Does chroming eliminate some of the preparation issues? If I can get them out, prepared and either anodised or chromed then I think I will have a future proof solution and better than orignal, but the meantime it's pretty frustrating to be honest. Grateful for any thoughts / experiences
------------- Hanse 418 #64 EmBer. Hamble, UK
Posted By: Tranquillity
Date Posted: 16 February 2022 at 18:01
Matt, Sorry to hear. Which of your hatches have you had the problems with and will check ours. Jon
Posted By: Matt1
Date Posted: 16 February 2022 at 19:34
Hi Jon - The two fwd ones eg just behind the chain locker and the one just ahead of the mast. Currently only the one by the chain locker is leaking, the one ahead of the mast is showing signs of the powder coat failing, but isnt leaking yet. The one aft of the mast is also showing very slight signs of the powder coating failing but again, isn't leaking. If I could fix the leak on the fwd one, I could live with it a bit until it eventually fails - this would make it easier to remove the powder coating at least ;-) but the anodizer was advising it's better to deal with it early becuase it's harder once corroision has set in. From reading these thhreads, and what I have gleaned, it looks like Lewmar made a bad choice to powder coat the frames, or didn't apply it correctly. I guess there are lots of opportunities for the coating to fail with all the screw holes. Matt
Date Posted: 16 February 2022 at 20:12
Matt, Sorry to hear. Not a problem we have seen but will double check. I always cover rubber seals in silicone every season to help seal and prevents sticking, not sure if helps? Good luck in resolution. Jon
Posted By: Matt1
Date Posted: 16 April 2022 at 20:02
Quick update on this - turns out that Lewmar do supply the frames in an anodised finish so it’s obviously Hanse’s choice to spec the problematic white finish. The anodised finish (which is clearly much more robust) is the same price, or in the bigger sizes slightly cheaper.
I’ve removed my fwd one and replaced it with a new anodised frame. The old white one had corroded underneath and there was clear evidence of where the water was getting in. The replacement won’t have that issue so hopefully no more leaks!
Posted By: Breathe
Date Posted: 18 April 2022 at 00:48
I have this problem on all the hatches on Breathe, found the problem at about 3.5 years old. The corrosion is worst on the hatch near the anchor well, and least on the one above the saloon. I decided that anodising the original frames was so difficult so have ordered new anodised frames direct from Lewmar. I plan on chancing out over a couple of years to spread the expense.
Posted By: Matt1
Date Posted: 18 April 2022 at 07:00
Hi Gordon - same here; worst on the most fwd one and progressively less corroded as you move aft. I’ve bought a replacement frame for the other one in the forecabin too but will replace that when it gets worse (despite the fwd one losing its adhesion at the corner it was still very hard to get out because the rest of the frame was well bonded still)
Posted By: Breathe
Date Posted: 18 April 2022 at 09:20
Hi Matt,
I assume that you are replacing the frames only, and keeping the glass, handles etc? Any difficulties in moving those fittings to the new frames? Gordon
Posted By: Wild
Date Posted: 18 April 2022 at 10:19
Hey Matt Where can I find the parts numbers for the anodized replacement frames for Lewmar flush hatches? Prices?
Posted By: Matt1
Date Posted: 18 April 2022 at 21:18
Hi - I only have details for the size 60 and size 70
60 in anodised is part # 361821990 and was £97 GBP before tax 70 in anodised is part # 361822990 and was £157 GBP before tax
But note that my UK dealer needed quite a few pictures of the hatch in order to correctly identify the exact frame so I’d recommend checking the above part numbers for your specific hatches
Posted By: Matt1
Date Posted: 18 April 2022 at 21:21
Hi Gordon, yes I swapped the acrylic over which was easy. The frame came with new support struts and they were easy to fit too. It was very simple ……except for removing the frame! I also sourced some screws with a much less aggressive pitch (?) so the frames should be held in better to the deck mechanically - as well as the Sikaflex
Posted By: Richard Hall
Date Posted: 19 June 2022 at 13:56
My 2015 455 has corrosion on the hatch frames as others have had. This has resulted in leaks on two of the main cabin hatches. The frames are powder coated and unsurprisingly in conditions in the central Mediterranean over time the coating has failed. It has tended to fail in the areas where water pools after the boat is washed or it rains. To prolong yours dry these areas out after making port, rain and washing.
The frames are available and to be honest having had some cleaned up and hard anodized the cost differential of refurbishment versus buying new anodized ones from Lewmar is negligible (60 x 60 frames are £112 each with plastic hinge attachment and new seal). They fit in an overhead aircraft bin even in their shipping box or you can wear them as an interesting piece of jewelry depending on how customs feel on the day.
The powder coating was specified by Hanse not Lewmar as an aesthetic. However, I went with silver anodised replacements. A quick walk round boats that are from a generation before will show up the fact that their older surrounds and frames have lasted better than powder coated ones.
Anyone who's owned a TVR sports car will know powder coating does not last forever - salt water, 40C sunshine etc... are as effective as road salt, rain, etc... at exposing the underlying frame to corrosion even if acid etch primed - the cost of the repair however, is a couple of orders of magnitude less!!
Removing is straight forward. I used thin flexible plaster scrappers - there should be some in the Hanse spares box. Remove the screws push under and break the sealant and gently pull up. Any noise that sounds like tearing is just the powder coating and sealant coming away from the frame. Use the scrappers and some acetone to clean the surface. I resealed with 3M 3200 Marine Silicone in case I have to take them out again - the screws should provide enough mechanical fastening strength (they aren't a structural element). Masking tape prevents sealant over run on the inner and external fibre glass.
Given that I was quoted €800 to fit and another €900 for 2 complete new hatches. I elected to do this myself - quite where they got the labour charge from I'm not sure as each hatch only took a couple of hours from start to finish.
One final thing to remember is to grease the stainless bolt on the hinge. Several of mine had seized and had to be cut and drilled out. (Only an issue if you intend to recycle).
Posted By: Breathe
Date Posted: 20 June 2022 at 01:26
Richard, how was Lewmar for delivery of the frames? Because my boat is a 2018 build Lewmar offered a discount on the pricing of anodised frames, so I have ordered a complete set. It is about 2 months since I ordered and I am regularly advised that the frames will be shipped in “a couple of weeks”. It is getting frustrating.
Posted By: Matt1
Date Posted: 20 June 2022 at 04:46
Hi Gordon, mine took about 6 weeks back in April (I ordered 2). I paid half price by going via my dealer. I’m a 2018 build too. I suspect they are prioritising the big boat builders. Not a surprise, they had plenty of the powder coated available ;) the delay was on anodised.
Date Posted: 20 June 2022 at 05:47
When I contacted them they had 1 in stock and that came in to the dealers in a few days. They have been coming in piecemeal, which works for me travelling down to Malta each month and Air Malta let me take them as hand luggage. They are supposed to have more stock coming after 27th June according to the dealer ordering system. I pick them up as they come in. I live in Hampshire not far from the Lewmar offices so that may be a factor. If you have someone who does hard anodizing near you they should be able to redo the old ones. I paid £60 for that but the issue then was the seized bolts each time. The hinge weld is not strong in sheer so penetrating oil and shocking the bolt generally removes the hinge! Heat had no effect and in the end I had to grind off the bolt and drill it out. If you do this the cost of the seal and the new fittings makes it about the same.
Date Posted: 27 July 2022 at 13:37
My second one showed up yesterday about a month late.
Posted By: Idle Hour
Date Posted: 23 September 2024 at 11:15
Hi Richard,
I have a 2016 hanse 455 , have you get a link to where you purchased the frames please and what model are they ?
Kind Regards
Charlie
------------- Charlie
Posted By: perry
Date Posted: 23 September 2024 at 13:01
Powder coating ?. 30 years back I did some extensive experimental work on various powder coating systems for corrosion protection. Absolutely useless for protection, thickening the coating reduced the porosity but only with thicknesses above 3mm?. No it doesnt work, If you look around at any number of products where powder coating is used eg. cheap bicyles, garden equipment barrows etc, you will see plenty of corrosion fails. Anodised aluminium is good, why anyone changed? probably the promised of powder coating companies? So do not replace failed powder coated hatch frames with more powder coated frames, they will fail, they will leak. If the frames conform to new [fashion] of flush hatches just more trouble.
In my experience Perry Cowes Isle of Wight
Date Posted: 23 September 2024 at 13:03
I agree,
I am looking fopr anodised replacements which I believe are stocked now
Posted By: pdc78
Date Posted: 23 September 2024 at 16:50
One of the side windows on my 2016 345 is leaking because of the powder coating failure, and I am waiting for an overdue replacement frame from Lewmar via the dealer. I can see that the other three have signs of coating failure and will need replacing in due course. Lewmar Tech Support acknowledged the problem, but could not supply an anodised replacement. So my strategy is to replace the current leaking one with an 'assured good' Lewmar powder coated one and then get the old one black anodised (or maybe even plywood blank a second hatch to release two for refurbishment). The cost of black anodising locally is about 1/3 of the new frame. I have been warned that the black anodisation is more shiny dark grey than jet black, but I figure it won't be that conspicuous being covered by the polycarbonate oversized windows on the outside and the folding blinds inside the saloon.
It's strange that Lewmar could not supply an anodised frame. It is just a 'standard' rectangular radiused hatch. The custom built cranked top hatch which failed last year was available in powder coated white or silver anodised - I chose that latter and it is definitely the best option.
I'm just hoping that the coach roof side frames come out as easily as the top forward hatch . . . .
Regards, Paul
------------- H345 #269
Posted By: perry
Date Posted: 23 September 2024 at 20:14
You can get anodising pretty much any colour. It is a process of first creating an anodised layer deep enough [aluminium oxide] to contain dye, then immersed in the dye, then post treated to seal the poroisity. I quote from a specialist:- "Electrochemically anodizing aluminum produces an aluminum oxide surface that has:
- Corrosion resistance
- A pleasing appearance
- Wear resistance
- Improved paint or adhesive bonding
- Improved lubricity
- Improved plating adhesion
This article will focus on anodizing aluminum. But, other metals can
be anodized, including magnesium, titanium, and aluminum alloy. There
are several types of anodized aluminum finishes, including clear
anodized aluminum, black anodized aluminum, and hard anodized aluminum.
There are also a few commonly referenced anodizing types: Type I, Type
II, and Type II.""
Posted By: pdc78
Date Posted: 23 September 2024 at 20:27
Thanks Perry. All understood. I should have said that the local to me anodising company will do hard black anodising, but have warned that it will be dark grey as described. Regards, Paul
Date Posted: 31 October 2025 at 17:37
Hi Matt,
I have the same issue with the frames, can I ask where you purchased them from please ?
Kind Regartds
Charlie
Posted By: Matt1
Date Posted: 01 November 2025 at 19:35
Idle Hour wrote:
Hi Matt,
Kind Regartds
Charlie
My dealer IMG very kindly helped me source them direct from Lewmar but you will need the relevant serial numbers off the acrylic to ensure you get the right one.
Unfortunately 3 years or so after swapping the frame I still have a leak. This time not caused by the powder coating failing but because the factory cut the aperture for the hatch oversized so I’ve now got to engage a laminator to build the opening up before fitting the frame again! That and this winters fitting of a replacement window should finally see my boat leak free!!!
Date Posted: 03 November 2025 at 15:09
Hi Matt,
Thats greatr, thanks
Yes they cut mine oversize too in the corners !
What a stupid mistake to make , so mine only sits on the outer ridge of the two at the bottom of the frame !
Kind Regards
Charlie
Posted By: Etre Jeune
Date Posted: 05 November 2025 at 23:38
You are not alone!
I believe it is something to do with the anodising not being compatible with the powder coating. The hatch frames can be fun to remove, so I am contemplating Cleaning up in situ, and then masking off and hand applying an etching primer, followed by an epoxy top coat.
------------- R Stock
