Taylor wrote:
Huw (Bitbaltic) and I have both bought sails from Peter Saunders.
I settled on the same genoa 117% and main set up as Huw had purchased maybe a year or two earlier using cruising laminate.
I very rarely used the self tacking track with the old original east sail as I preferred the extra off wind performance with a 125% genoa which was a black laminate that finally succumbed to UV. It is possible to reef the Saunders genoa down and use it as a self tacker but I prefer to keep full genoa and reef the main.
The main is loose footed fully battened with 3 reefs. I find I can hold full sail in up to 18 knots. First reef goes takes you up to 25 knots. Third reef untested so far!
Performance is way better and ability to control sail shape with fully battened rig is a major plus.
I only had to provide Peter with two measurements and the sails fitted like a glove.
Peter will listen to your requirements and I think will offer you both a very good price and a high quality sail. I beat him up a bit as he basically had the cad design and template paid for by Huw! Steve.
Cant agree more with this Steve :)
(the spec of our boats is now so similar that we can give matching answers!)
Yes Peter has a design for the Hanse 301 which I think is based on extensive measurements of my boat which were made by Andy Freemantle ( https://themarinegroup.co.uk/marine-services/rigging/" rel="nofollow - https://themarinegroup.co.uk/marine-services/rigging/ ), although he had made sails for the 291/292/301 series before (a couple of the solent-based racing fleet). We've had ours (dimension polyant cruise lam, sized as Steve says above) now for about 8 years and they are still in perfect condition (as to be fair they haven't done mega miles). They go back every year to Sanders for wash and service and the service remains excellent. I can't recommend Sanders highly enough and wouldn't myself look elsewhere.
I also don't use the self tacker other than as a handy fitting to tie the dinghy down to. In strong winds it can be okay to put a scrap of headsail on the self tacker but the genoa isnt really built for it. Peter can of course build a sail for the system if thats what you want, but I think the boat is far better without it.
I'd recommend taking the tidesmarine sail track if you are getting a new fully battened main (much of this is probably in the email I sent last summer though!)
The other lofts mentioned will I am sure also do a good job for you if you want an alternative.
Cheers Huw
------------- Hanse 301 'Karisma' | https://sailingkarisma.wordpress.com/" rel="nofollow - https://sailingkarisma.wordpress.com/
