Water tank removal
Forum Name: 350
URL: https://www.myhanse.com/forum_posts.asp?TID=13191
Topic: Water tank removal
Posted By: NK1
Subject: Water tank removal
Date Posted: 01 February 2022 at 20:21
Hi. Has anyone removed the water tank on their H350? Is it an easy job? I want to remove to see what space I have to install a bow thruster. Thanks
Posted By: Nilandhoo
Date Posted: 02 February 2022 at 12:09
Hi we have a Hanse 325 and fitted a bow thruster in 2019.
see the thread in this link https://www.myhanse.com/retractable-bow-thruster_topic11672_post96261.html?KW=bow+thruster#96261" rel="nofollow - https://www.myhanse.com/retractable-bow-thruster_topic11672_post96261.html?KW=bow+thruster#96261
Paul
Hanse 325 'One Life'
Posted By: NK1
Date Posted: 02 February 2022 at 12:41
Thanks for the link Paul. Good info and a nice install on your boat. I was thinking of the Vetus 45kgf with 125mm tunnel. Looks similar to your side power . A previous trend indicated tunnel needed to be under the water tank on the 350. Maybe not looking at your install. Thanks again.
Date Posted: 02 February 2022 at 15:02
No problem, but there is no room under the water tank to fit a bow thruster.  We used the compartment forward of the water tank having cut a hole out of the fiberglass underneath the forward bunk.  It was just big enough for the installation of the tunnel and a vertical mounting of the motor and gearbox. Good luck with the project.
