Correct Propeller size
Forum Name: 371
URL: https://www.myhanse.com/forum_posts.asp?TID=13280
Topic: Correct Propeller size
Posted By: Paule70
Subject: Correct Propeller size
Date Posted: 24 March 2022 at 21:40
Dear All,
I have currently a Volvo MD 2030 29 hp @ 3.600 rpm with a MS25 reducing 2.47:1 driving a 16 inch 2 blade flexofold folding prop with unknown pitch.
I want to upgrade to a 3 blade flexofold folding prop.
As an option I will at the same time upgrade to a Volvo MD 2040 40 hp @ 3.600 rpm with same 2.47:1 MS25.
after goimg through all posts I could find but I am still a little bit confised… and even more confusing flexofold offers for the 40 hp option a 17x11 3 blade prop. I understood that some of you uses such size for 29 hp. after a longer discussions with flexofold headquarter they still confirm 17x11 for 40 hp. unfortunately I dif not ask for 29 hp to get an comparison.
Easiest for my issue would be to give your recommendations of prop sizes for
a: 29 hp
b: 40 hp
Hope to get so,e answers from your swarm intelligence.
Best regards
Robert
Hanse 371   #129
Eckernförde, Germany
Posted By: Paule70
Date Posted: 25 March 2022 at 18:20
@lucca
I saw,in your signature that you use a 3 blade folding prop with a 40 hp Volvo.
I would be happy to learn what size the prop is and whether you are happy with its characteristics.
Thank you in advance.
Greetings, Robert
Hanse 371   #129
Posted By: lucca
Date Posted: 03 April 2022 at 10:01
Hi there
I have an Volvo 18x13 3-blade folding propeller for my MD2040 40HP @3600rpm (Part no. 3581225). I am very satisfied with that. The engine does it easily.
No wind and wave:
@1800 rpm --> 5kn
@2100 rpm --> 6kn
I've never needed RPM's higher than 2600 rpm. Then the stern gets stuck in the water.
371s #171, 40HP Volvo, 3-Blade FoldProp, Jefa RP150&DD1, RMC 185 4kW, Zeus2 9, V50, NAIS400, WR10, Victron MultiPlus 1600, 180W Solar, 150l Diesel, 300l H2O, Eberspächer 4kW, freezer ... ;)
Posted By: karina
Date Posted: 20 April 2022 at 19:18
Hi all,
since 2014 I have a 17x12 2-blade flexofold propeller (MD2030, 29HP). The size was recommended by the flexofold "expert" on the Hanseboot exhibition.
I'm very happy with this prop.
approx. @2250 rpm --> 6kn
approx. @2650 rmp --> 7kn
full speed approx. @3000 rmp --> 8kn (no wind, no waves, clean hull)
From my point of view, there is no need to upgrade to MD 2040. Better spend the money for fast sails ;-)
BR,
Rainer
live slow - sail fast!
S/Y Karina
Hanse 371 #32
Hamburg / Germany
