Windlass Contactor
Forum Name: 430
URL: https://www.myhanse.com/forum_posts.asp?TID=13296
Topic: Windlass Contactor
Posted By: Skebiat
Subject: Windlass Contactor
Date Posted: 03 April 2022 at 02:40
I have not been able to find where the contactor for the Lewmar windlass is installed on a 430.
The contactor being the box that the wired remote operates, not the circuit breaker .
Is anyone able to offer any ideas where it's usually located?
Thanks,
Steve / 430 No.75.
Date Posted: 03 April 2022 at 15:13
Hanse usually puts it on the main DC power board. Not sure where that sits on your boat, but usually near the nav station.
Posted By: Skebiat
Date Posted: 04 April 2022 at 03:07
Thanks for the reply.
The DC panel with the 12V service and anchor circuit breakers//earth bars//chargers//auto pilot etc doesn't seem to be where it's installed on the 430.
Posted By: Festina Lente
Date Posted: 11 May 2022 at 15:32
@Steve; were you able to locate the contactor? I am also trying to find it on my 430.
Steinar/Festina Lente
430e 2008
Posted By: Dogscout
Date Posted: 12 May 2022 at 14:08
Looking at the Lewmar manual the Contactor is located within the case of the Lewmar windlass.  Hanse puts the circuit breaker behind the Nav Station seat with the other circuit breakers for Service and Winches.
Adventure awaits
Date Posted: 12 May 2022 at 14:56
Thanks for the reply. I will look inside the windlass. (I have found the circuit braker alredy.) Smile
430e 2008
Date Posted: 12 May 2022 at 21:24
Please do not start to disassemble the windlass. No contactors hidden there.
Look at the picture from my boat. From the Thermal Circuit Breaker (70A) marked ANCHOR, there is a short red cable 35 mm2 to the contactor. The contactor has the size of 2 packets of cigarettes and is black.
The contactor is basically a large relay, which is triggered by a small current (1A), and then releases a large current (50-60A). My Lewmar is the 1000/ProFish.
The smaller Lewmar 700 winch works with a smaller current, like some 35-40A, and this model is NOT equipped with a contactor, but with a toggle switch. This winch is for boats <35 ft.
uploads/729/Manual_Ankerspil-pro.pdf" rel="nofollow - uploads/729/Manual_Ankerspil-pro.pdf
Posted By: Skebiat
Date Posted: 25 May 2022 at 04:52
Sorry for the delay.
I think so.
I believe it is in a void underneath the floor in the anchor locker and is not accessible.   The best I could do was to shine a bright torch into this space from an access "hatch" in the forward cabin and to then try and direct my camera into that space.   From that, I could see where the cables from the windlass were terminated, and I think I could see a shadow of the contactor module, but I could not access the contactor.
Posted By: Dogscout
Date Posted: 25 May 2022 at 08:00
See the link to the Lewmar manual.    Page 19, Part number 63 in the picture.
https://www.lewmar.com/sites/default/files/H2-H3_horizontal%20REV%20C.pdf" rel="nofollow - H2-H3_horizontal REV C (lewmar.com)
The contactor is mounted within the case.
Adventure awaits
Posted By: Peknielsen
Date Posted: 03 June 2022 at 01:11
@Steve, @Captain Cook,
I have a 2011 430 that I am looking to install a windlass.  A windlass was not installed when she was built.  It would be very helpful if you could share a picture or two of what your factory installed windlass looks like in the anchor locker.
Paul
(Stella Maris)
Date Posted: 03 June 2022 at 20:45
https://www.myhanse.com/anchor-windlass_topic10536_post88545.html?KW=anchor+winch#88545%20" rel="nofollow - https://www.myhanse.com/anchor-windlass_topic10536_post88545.html?KW=anchor+winch#88545
Posted By: Skebiat
Date Posted: 03 June 2022 at 23:54
Ah.  That would make sense - thank you.
