Is this a relay?
Forum Name: 350
URL: https://www.myhanse.com/forum_posts.asp?TID=13431
Topic: Is this a relay?
Posted By: NK1
Subject: Is this a relay?
Date Posted: 09 June 2022 at 23:46
Hi all. I have just purchased a 2008 Hanse 350 and was looking around the engine today. There is a black unit that looks like some sort of relay??. Anyone know what it is and where it should be mounted? Thanks
For
Posted By: NK1
Date Posted: 10 June 2022 at 08:03
Date Posted: 10 June 2022 at 10:20
On my yacht , which is fitted with a YANMAR engine and saildrive,  there is something that looks like that and it is the amplifier for the sail drive water sensor alarm that checks for any water between the 2 parts of the saildrive seal.  Just fasten it somewhere with a cable tie.
A Volvo engine would not have one.
Date Posted: 10 June 2022 at 21:03
It is as said an amplifier for the signal to the control panel. Has nothing to do with a loudspeaker, but might enhance the signal strength.
But I think is more likely that is it meant to suppress electronic noise from tricking the alarm unnessarary.
It has part number 196420-02812 saildrive water seal alarm amplifier
/h8jer
Hanse 370#487 30HP 3-cabin
Posted By: NK1
Date Posted: 11 June 2022 at 22:26
Many thanks for the reply’s. I will cable tie it up as suggested.
