Simnet wiring
Forum Name: 350
URL: https://www.myhanse.com/forum_posts.asp?TID=13437
Topic: Simnet wiring
Posted By: NK1
Subject: Simnet wiring
Date Posted: 12 June 2022 at 22:06
Hi. Does anyone know the standard simnet wiring for a Hanse 350? ( the devices connected and where the connections are located) I have this at the fuse panel. First connection is the 12v and last connection is going to my chart plotter. I don’t know where the other 3 are going. Thanks.
Date Posted: 13 June 2022 at 09:44
The old Simnet installation manual can be found at: http://www.wesailhanse.se/Hanse370_documents/370_documents_simrad/hanse370_40_simrad_simnet_installation_manual_en.pdf" rel="nofollow - http://www.wesailhanse.se/Hanse370_documents/370_documents_simrad/hanse370_40_simrad_simnet_installation_manual_en.pdf - but 10-15 years ago the instruments were connected in series, not parallel like yours. I made a cursory search on the net for a newer manual, but no luck. The plastic numbers (1-2) on your cables will alse be found at the other end of the cables. If you need to know which cable feed which instrument, I suggest you remove one cable and check which instrument goes dark.
Posted By: Kox
Date Posted: 13 June 2022 at 10:21
Guessing here, since I have a 315, but one for piedestal, one for mast, one for depth/log/temp, maybe one for autopilot. And your 12V supply.
------------- Hanse 315, Ella, Hull# 640
Posted By: Brufan
Date Posted: 15 June 2022 at 16:50
On diagram I have : two sockets (??? why) for DST 800 thruhull sensor and one for compass FC40 or RC42
------------- Bruno
hanse 355 - 57
S/Y Spicy Ginger
Posted By: JUTTER
Date Posted: 15 June 2022 at 19:54
NK1,
on my H350 (210): - in the ceiling under the mast - in the void between the battery bank and the front of the port settee ( access via speaker) - in the void behind the calira panel - in the pedestal - in the portside void (opposite the gas bun) in the transom If you send me a PM I can mail a copy of the connections diagram on Jutter. Kind regards, Claude
------------- JUTTER, Hanse 350#0256, 2010, deep keel, Zeeland
Posted By: NK1
Date Posted: 16 June 2022 at 10:24
Great drawing. Seems to be lots of connectors. Many thanks Claude.
Posted By: NK1
Date Posted: 16 June 2022 at 16:19
Thanks for reply’s everyone
Date Posted: 18 June 2022 at 16:59
<@Brufan I believe that the DST800 triducer has separate cables for 1)Speed/temp and 2)Echo
Posted By: Donato
Date Posted: 02 February 2025 at 07:05
Cioa claudio perdona, il dannoso potrebbe se possibile inviarmi anche a me lo schema dei collegamenti su Jutter. Grazie mille
Posted By: JUTTER
Date Posted: 02 February 2025 at 09:09
Hi Donato,
I sent you a PM.
Claude
Posted By: Jabiru FL
Date Posted: 01 May 2025 at 13:32
Bonjour Jutter Je possède le Hanse 350 numéro 270. Un de mes afficheurs de girouette simrad Is20 ne s allume plus. J imagine qu il est totalement HS et cherche comment le remplacer. Il me semble que le Triton 40 pourrait faire l affaire. Mais l appareil a remplacer est "daisy-chain" mais je ne sais pas si est sur le "black bone" ou sur un drop câble. J ai compris que je pouvais "Daisy - chaine" le Triton mais uniquement sur le "black bone" . Avez vous un schéma de cablage qui pourrait m aider a y voir plus clair?
Merci par avance.
