Flex o Fold Model number
Forum Name: 505/508
URL: https://www.myhanse.com/forum_posts.asp?TID=13516
Topic: Flex o Fold Model number
Posted By: kipwrite
Subject: Flex o Fold Model number
Date Posted: 14 July 2022 at 22:42
My 2016 505 #123 was delivered with a 3 blade Flex O Fold prop.
I'm going to have it serviced shortly, and the shop asked me if I knew the model number. There's a fair amount of play in it.
Anyone know the model number for the '16 505's, with the 3 blade folding Flex O Fold prop?
My dealer had no idea, I could find no documentation aboard, and Flex O Fold is closed til August.
Further, any advice on dialing it in so I can achieve more than 2750 RPMs would also be helpful. I think these
engines should run closer to 3,000 RPMs WOT and I think mine was never set up properly.
Thanks.
Kipwrite
Kipwrite
Date Posted: 17 July 2022 at 01:38
You should be able to see the model number on the prop.  Admittedly if its in the water its more difficult, but if you have a picture.    This is from my 575
Posted By: FalParsi
Date Posted: 17 July 2022 at 08:10
My 505 was originally delivered with a fixed prop, and I replaced it with a Flexofold. In discussing this with Flexofold they suggested the 3-bl. SD hub, M16x2 nut with the 20x13-3 L bladeset.
2016 Hanse 505 #120
