New Whale Gulper Pump on Shower drain
Forum Name: 370 / 375
URL: https://www.myhanse.com/forum_posts.asp?TID=13788
Topic: New Whale Gulper Pump on Shower drain
Posted By: Pride of Waterford
Subject: New Whale Gulper Pump on Shower drain
Date Posted: 18 December 2022 at 18:08
We have decided to change the existing drain pump with filter in line with the Whale pump that does not need a filter.
It is a lot bigger and wondered if anyone has done this and how it was fitted.
Jon
Brod Port Lairge
Date Posted: 20 December 2022 at 08:22
I have a 2003 version of the 311. I have changed to a gulper just before covid. I removed the old pump , threw away the filter & just re conncted with a section of new hose. What I did do was fit a Hose lock fitting in the connection. I then added a 12 ft length of hose which is coiled in the engine bay. When i want to hoover up water anywhere in the boat I just disconnect the shower & hook on the hose & can move it about as required. In the end of the hose I have a 12 inch length of 8mm copper pipe so I can insert it through a hole in the cabin floor & suck up any water in the bilge that the main pump will not remove without lifting the floor boards. It also sucks up small puddles under the engine.
The shower tray in my boat does not drain to the outlet so I get the last of the water up with that as well. In fact i poke it down the drain hole & leave it there when using the shower to save connecting & re connecting it. I have a hole in the engine panel for it to come through
Posted By: Ratbasher
Date Posted: 20 December 2022 at 10:52
Hi Jon - I did exactly that on my 400 a few seasons ago, adding an expansion tank in the same area; the difference made was significant.  All I did was unscrew both the FW and the shower pump from the wooden bed and fiddle around until I could get them both side by side with the aid of some longer, flexible pipework before screwing them back down.  The expansion tank went forward of the pumps, secured with cable ties and some padding. The 400 is so similar to yours that you should be able to do the same, albeit with the necessary 'robust language' as it can be a bit fiddly. Regret am far away from the boat so can't take a picture.
I do like Samuel's added little finesse; must try that myself next year!
Posted By: landlocked
Date Posted: 20 December 2022 at 15:20
I’ve been considering changing my sump pump too. Any photos or model numbers would be appreciated, thanks!
"Kerkyra" 400e #042
Date Posted: 05 January 2023 at 08:17
Thank-you Guys these are really useful suggestions.
I will now be able to tackle the project with more confidence.
If I can work out the connections I like the idea of a tail to suck up water from other parts of the bilge.Smile
Brod Port Lairge
Date Posted: 05 January 2023 at 14:44
Hi Jon
Some years ago I changed our setup on our 370.
The boat came with two Jabsco PAR pumps. One for fresh Water and One for Shower Drain. Because these pumps are both meant for fresh water, it was obvious that I needed to do something to improve this.
Another annoying issue was that there were no accumulator tank for the Fresh Water, so every-time someone opened a tap - the pump would run (and make noise).
I changed the shower drain pump to a Jabsco diaphragm pump that does not need a filter eg.:
https://www.jabscoshop.com/marine/pumps/sink-shower-drain-pumps/50880-1000-self-priming-diaphragm-pump-12-volt-dc.htm" rel="nofollow - https://www.jabscoshop.com/marine/pumps/sink-shower-drain-pumps/50880-1000-self-priming-diaphragm-pump-12-volt-dc.htm
This was a swap-in because of the same fittings used.
I also added a 1-Litre accumulator tank to the Fresh-Water side. It was placed under the sink to the right. Again same fittings but also needed some extra hose and fitting:
https://www.svb24.com/en/jabsco-accumulator-tank-1-litre.html" rel="nofollow - https://www.svb24.com/en/jabsco-accumulator-tank-1-litre.html
(Correction update: is was only .65L  https://www.svb24.com/en/jabsco-accumulator-tank.html" rel="nofollow - https://www.svb24.com/en/jabsco-accumulator-tank.html )
This is much better than stock setup but I still need to address two Issues.
  • The Freshwater Pump is much nosier than on my old Hanse 311 where the pump and accumulator was one unit.
  • The Shower-drain pump is now so effective that it pushes waste water backwards up into the sink.
I hope that this can inspire you and others
/H8jer
Hanse 370#487 30HP 3-cabin
Date Posted: 05 January 2023 at 22:53
The picure at the bottom is the Gulper mounted in my H400
This is from 2020:
Try Search->Advanced Search->Topic: Gulper->Any Date->All Forums, and find:
If this looks like your pump, the filter is on the bottom left side. Do NOT drop the filter down in the void, because it may never reappear. Try to read the links, where a Gulper pump is recommended. This type of pump has no filter to clean.
https://www.myhanse.com/head-shower-water-pump_topic10851_post90844.html?KW=gulper#90844" rel="nofollow - https://www.myhanse.com/head-shower-water-pump_topic10851_post90844.html?KW=gulper#95344
The Gulper 220 is about €185
Whale - Whale Gulper - Duschtömnings- och länspump
Posted By: Rock
Date Posted: 06 January 2023 at 09:14
Also replaced the standard shower drain pump with a gulper.
Very happy with it, larger capacity and way less noise then the original (sounded like a jackhammer).
Cleaning the filter really became a nuisance (every 1-2 weeks, depending on use), Gulper is in since 1 year, no filter no issues, no clogging so far.
But as h8yer say, it makes the issue of backflushing grey water into the sink worse (larger capacity).
Only definitive solution I can think of is to make a dedicated thruhull for the showerpump, don’t want to do that though.
Anybody really dealt with the water in the sink issue in another/easier way ?
BR
Peter
Hanse 400e "M-square2" #0241
Date Posted: 06 January 2023 at 09:22
Just a point. I have no idea how the layout works in a 40 but in a 311 the shower outlet is in the transom so no issues with exiting via an additional hull fitting below the waterline. Perhaps you may find the length & routing not workable though.
Posted By: alidal
Date Posted: 06 January 2023 at 10:07
I have changed the check valve under the sink..
Hanse 400#655
Date Posted: 06 January 2023 at 10:16
" the water in the sink issue"
I mounted a one-way valve under the sink - the model with a gravity induced movement. The model with a spring does not work here.
Date Posted: 06 January 2023 at 17:47
Hi Again
When changing the Shower Drain pump I now remember that there was not much room to work with. There might be a huge difference between the 400 and the 370 here. The clearance between the outer and inner hull is not much.  I don't think the filter could drop into the hidden voids on a 370.
Because of the tight space, the Whale gulper/diaprahm pump suggested by Captain Cook is perhaps an easier fit than the Jabsco pump. It took me some time to adjust the best orientation. But as show on the pictures the Whale has to sit lower than the Jabsco to leave room for the hoses.
Captain Cook - Because you mentioned that the Spring-version is not usable -then a https://www.trudesign.nz/marine/products/69-non-return-valves-check-valves" rel="nofollow - TruDesign One-Value is perhaps not an option? The TruDesign has a stainless Spring and a pressure loss of 3.8psi.
Could you kindly confirm if this  https://www.vvs-eksperten.dk/ror-og-fittings-kuglehaner-og-ventiler-kontraventiler-kontraventil-med-klap-12-430380004" rel="nofollow - valve  is of the right gravity One-valve type?
/H8jer
Date Posted: 06 January 2023 at 18:42
H8jer: The non-return valves are normally used in pressurized systems. This means, that a version with a spring needs the water-pressure to press open the valve. This kind of pressure is not available when water is slowly leaving the sink.
The valve in my photo I found in my workshop. It is also manufactured for use in pressurized systems, but the mechanism is just a closing plate hung in a little bolt of which you can see the end in the top left hand side on the photo. Therefore if it is mounted right, the valve stays open (by gravity) so water from the sink  can pass. When the drain pump starts to pump pressurized water against the arrow in the valve, the valve closes, and the grey water from the drain is then routed down to the seacock.
The non-return valve must be mounted on the hose just under the sink, with the arrow pointing down, and with the Y-piece underneath the valve ( with hoses going to shower-drain and seacock).
There may be a better solution, but this was what I could find in my workshop, and it functions.
I do not believe that the Trudesign valve will work.
Update: Just drew a few lines on the valve to make things clearer.
Posted By: Wild
Date Posted: 07 January 2023 at 10:01
[QUOTE=samuel]
[/QUOTE)
In our boat 545/2010 there’s a factory installed Jabsco Water Puppy self priming pump 23680-4003 with approx 12 meters long 19mm hose with Jabsco anti return valve and at the end a 50cm long tube to pump out all the bilges compartments. I can even reach the bow thruster compartment the dinghy garage and the anchor locker to suck op water there.👍
Why Hanse don’t do this standard in all the models I don’t know!!
Wild and Wet
Belgium
545e#268
Date Posted: 07 January 2023 at 20:21
Thanks H8jer and Captain Cook for your photos and links to alternative shower pumps.   This is a future project for my H400.   I will also look for some kind of check valve arrangement that can work for a sink.
Regarding the discussion of pressure tanks, another alternative is a flow-rate controller that controls the pump based on water pressure.   I bought this one from Jabsco many years ago and it has been working fine for me https://www.westmarine.com/jabsco-smooth-flow-water-pump-controller-31777-0000-8719080.html" rel="nofollow - https://www.westmarine.com/jabsco-smooth-flow-water-pump-controller-31777-0000-8719080.html .   Another nice feature of this device is that it will shut off the pump if the flow is continuing uninterrupted for more than 20 minutes so if someone leaves a tap on or you spring a leak you won't drain the tank.   Cycling the power will reset this feature.  It is pretty compact and there is room to fit it next to the freshwater pump.   Sorry I don't have a photo of the installation, I'll take one in the spring.
"Kerkyra" 400e #042
Posted By: Rock
Date Posted: 07 January 2023 at 21:20
Very interesting solution, with the gravity based one-way valve
Never thought of.
You learn something everyday !
Thanks kjeld
Date Posted: 08 January 2023 at 11:44
Hi Again
Just went to the boat today to charge the lead batteries and also to run the dehumidifier (absorbtion-type)
Then I had some time to take pictures of my setup.
Remember that I have already stated it would perhaps be easier to install the Whale-type, because I think the picture shows that it was difficult to fit the Jabsco Gulper/Diaphram pump (50880-1000):
The accumulator tank for the fresh-water is a .65 Litre (not 1L as stated earlier) it's part-no is 30573-0003.
It is placed under the sink to the right.
Here is shown the TruDesign Truhull valves, where the left one has a Y-joint for the Sink and the Shower drain. I would not try to fit an extra truhull dedicated to the Shower drain.
From the Y-Joint the Hose is bend in a curve up to sink. So a To-Do project this season would be to fit the Non-Return Valve suggested by Captain Cook - somewhere on that hose.
/H8jer
Date Posted: 08 January 2023 at 13:34
Hi Captain Cook, great idea to use that non return, or check valve as we call it. I would, however, suggest that a lower mounting near the waterline would provide a bit more downward head pressure for the sink drain. This should make for faster draining and less restriction. Is there a reason you chose mounting near the sink? Cheers.
Date Posted: 08 January 2023 at 13:40
Perhaps I can answer on behalf of Captain Cook.
Because the hose is bend - there is only a limited position to fit the valve because it needs to be vertical for gravity to work.
From the Y-joint to the underside sink is only 25-45cm
Posted By: Wild
Date Posted: 08 January 2023 at 13:46
This type you have to place always horizontal to let the gravity work.
 Why not the Jabsco non return valve?
There’s no spring inside and you can placed in any direction( vertical and horizontal )for 19mm 25mm and 38mm hose.
Wild and Wet
Belgium
545e#268
Posted By: Wild
Date Posted: 08 January 2023 at 14:07
Wild and Wet
Belgium
545e#268
Posted By: Wild
Date Posted: 08 January 2023 at 14:13
Originally posted by Wild Wild wrote:
I’m sorry H8jer
I just see your post now.
I believe the type valve from capt Cook must always in horizontal position and only vertical when the flow go upwards.
Wild and Wet
Belgium
545e#268
Date Posted: 08 January 2023 at 14:59
Wild and Wet:
In fact the valve is meant to be mounted horizontal, but it still works in a vertikal position.
I mentioned, that there may be better solutions, because when I used the brass-valve, it was simply because I already had it in my workshop.
Obviously the Jabsco may a better solution. The photos are not showing if there is a spring mounted inside the plastic. If so, there may be a problem when the water shall leave the sink. There is almost no pressure on the grey water from the sink.
If someone has bought the Jabsco, it would be nice to get some feedback on myhanse, if it can be used for this purpose.
:Kjeld
Posted By: Wild
Date Posted: 08 January 2023 at 15:23
Capt Cook
We have one in each shower cabine of these valves under the sink to avoid shower water come in when the shower grey water pump is running.
The inside rubber flap is the same system as Jabsco use in the toilet handpomp but there’s no brass weight on the flap and the flap is mounted in a 45 degrees position in the flow direction
The acces to clean (if necessary) is easy just take out the 4 bolts.
Wild and Wet
Belgium
545e#268
Date Posted: 08 January 2023 at 15:26
I think the Jabsco Non-Return valve is meant to be always-shut except when the desired flow is present. So it will need some pressure.
The hydrostatic Pressure of standing water should be 0.433 psi pr. feet.
TruDesign Non-Return Valves need a Low ‘cracking’ (opening) pressure 0.41psi for 19mm and 0.29 psi for 25mm.
So this will not work for TruDesign. I can't find the numbers for Jabsco valves.
With the gravity valve in vertical, it should be always open, which is desired because there are no real pressure. If there is just the slightest obstruction, hair and other debris will pile up and clog the valve.
Posted By: Wild
Date Posted: 08 January 2023 at 15:33
Wild and Wet
Belgium
545e#268
Posted By: Wild
Date Posted: 08 January 2023 at 15:35
 The flap is not the same as on the picture (toiletpump) but the system is the same.
It needs just a few cm of waterpressure (water columns?)to open in the flow direction
Wild and Wet
Belgium
545e#268
Date Posted: 08 January 2023 at 15:37
So there is no spring?
It will also be easier to clean than dismantling the Brass gravity valve.
I think I will try the Jabsco valve then.
Posted By: Wild
Date Posted: 08 January 2023 at 15:42
Right! And cheap Wink
Wild and Wet
Belgium
545e#268
Date Posted: 16 January 2023 at 21:48
Thankyou all.
Smile
I have now managed to fit the Gulper by moving the existing water pump slightly to the right and extending the pipes to make it all work .
I really appreciate the support, it really gave me the confidence to go ahead !!
Brod Port Lairge
Posted By: lovind
Date Posted: 30 December 2024 at 22:33
Hi H8jer,
I'm planning to install the same jabsco gulper pump as you have. Did you do any changes on the electrical side? I see  that  the calira panel only has a 10amp  fuse for the pumps, and the gulper pump draw twice as much as the fresh water pump.
Lovinda II
Hanse 370 #505
Date Posted: 31 December 2024 at 07:51
Originally posted by lovind lovind wrote:
.... and the gulper pump draw twice as much as the fresh water pump.
Are we talking about the same gulper pump?
My version only needs a 10 amp fuse.
I did not change anything about fuse or wires.
Kind regards
Posted By: lovind
Date Posted: 31 December 2024 at 10:09
Good to hear that it hasn't caused any problems. I'm planning to install the same pump, but both the water pump and the gulper pump will be on the same fuse. My worry is that the water pump has a max draw of 4.4amp and the gulper 8amp, so this should be on the limit when they both run simultaneously.
Lovinda II
Hanse 370 #505
Date Posted: 31 December 2024 at 11:09
My boat is winterized right now. So I cant check
But I dont think they are on the same fuse at the Calira panel.
Anyways both pumps can run at the same time.
In this post you can see the Calira panel.
When showering I turn on both switches with pump icons (above the bilgepumps)
https://www.myhanse.com/howto-guide-for-inverter-for-hanse370-3cabin_topic14134_post117350.html#117350" rel="nofollow - https://www.myhanse.com/howto-guide-for-inverter-for-hanse370-3cabin_topic14134_post117350.html#117350
I will have to doublecheck if they indeed do control each a pump
Posted By: lovind
Date Posted: 31 December 2024 at 14:31
Thanks, I have two cable sets from switch 14 (10amp to the water pumps) and one from no15 (20amp). The last one ended up underneath the sink, and I've used it for the electric toilet.
Lovinda II
Hanse 370 #505
Date Posted: 31 December 2024 at 14:36
Hi again
Good work. Perhaps the no. 15 is for an optional electric toilet.
When the boat is back in the water for the next season I must check if both my pumps are on the no. 14 switch.
