Mast light Bulb
Forum Name: 350
URL: https://www.myhanse.com/forum_posts.asp?TID=13852
Topic: Mast light Bulb
Posted By: NK1
Subject: Mast light Bulb
Date Posted: 30 January 2023 at 21:15
Hi all. I have to go up mast soon to check out ( and maybe replace) wind sensor. While there I want to change mast light bulb to a LED bulb. Does anyone know the type of bulb and wattage required? Thanks.
Date Posted: 30 January 2023 at 22:29
If you need a H320 electrical diagram or other Hanse related information, try
https://www.wesailhanse.se/320_documents/hanse_320-350-7215-010-01-electrical%20scheme.pdf" rel="nofollow - https://www.wesailhanse.se/320_documents/hanse_320-350-7215-010-01-electrical%20scheme.pdf
All the (Hella?)nav lights have the same type of  bulb.
So for starters you can check a light closer to the deck for verification of the type of bulb.
What you need is: "lantern bulb bay15d ø20x35mm 10-35vdc 1,8/20w white"
Changing the anchor light will stand up to a cost/benefit calculation. The motor lantern though will only be used when the engine is running, so here a LED or non-LED bulb will not be so important.
Posted By: NK1
Date Posted: 30 January 2023 at 22:55
That’s great. Thanks for this.
Posted By: AndyS
Date Posted: 30 January 2023 at 23:59
Replacing the bulb will probably be fine, but we chose to replace the whole assembly with a sealed LED system. It was not very expensive and has worked great. Hopefully we will never have to replace it again, but it is a boat, so "never say never." Here is the link to the Hella Marine LED lamps we used.
https://www.apexlighting.com/boat-lights/led-navigation-lights/naviled-360-led-all-round-lamps-2nm/?sku=980910121&gclid=Cj0KCQiA8t2eBhDeARIsAAVEga1T4fkpocMObhX-qOa2Sb82wSH_Kg0IrKLSH0RkB9EmgjeUTIkxCW4aAhEXEALw_wcB" rel="nofollow - https://www.apexlighting.com/boat-lights/led-navigation-lights/naviled-360-led-all-round-lamps-2nm/?sku=980910121&gclid=Cj0KCQiA8t2eBhDeARIsAAVEga1T4fkpocMObhX-qOa2Sb82wSH_Kg0IrKLSH0RkB9EmgjeUTIkxCW4aAhEXEALw_wcB )
Andy
Moonraker
River Dunes, NC
Posted By: coriolis2
Date Posted: 05 February 2023 at 17:20
Got the Aqua Signal type 34; 1:1 exchangeable with the AquaSignal base on a 2007 H350. This one is about E.220 in NL.
Agree with Cap. Cook w.r.t. the steaming light; motor is running so it makes no sense (Penny wise) to change this one for LED.
Posted By: NK1
Date Posted: 09 February 2023 at 19:13
Thanks all. Haven’t had a chance to go up mast yet but might just go for the led bulb option.
Date Posted: 11 February 2023 at 08:40
Andy, w.r.t. navigation light; yars ago I installed a 3 color multi LED bulb in teh original housing.  Two remarks:
1. The multi LED broke out of the lamp base including its fitting during a 6B wind against tide sail on the Ems estuary as it is rather heavy.
2. The combination of a (multi) LED with the standard lens results in a rather wide grey(ish) area between red and green, which I found rather disturbing and in fact is an offence.
Regards, Rob
Date Posted: 11 February 2023 at 15:23
It would help if you put your boat model in your signature.  I assume you still have a 350.
On my much older 341, I replaced the anchor light with
BAY15d replacement 18smd LED bulb from Boatlamps in the UK
https://boatlamps.co.uk/products/bay15d-18-smd-5050-led-bulbs-for-navigation-lights" rel="nofollow - https://boatlamps.co.uk/products/bay15d-18-smd-5050-led-bulbs-for-navigation-lights
Also buy the Contralube for use when fitting the bulb.
They also do an automatic sensor bulb bas well.
