Cockpit table lamp socket
Category: General
Forum Name: Chit Chat
URL: https://www.myhanse.com/forum_posts.asp?TID=13863
Topic: Cockpit table lamp socket
Posted By: 415 Singapore
Subject: Cockpit table lamp socket
Date Posted: 08 February 2023 at 10:17
Hi, our fancy removable cockpit table lamp has stopped working. I took it apart today and one of the long brass contacts has broken. I have tried google as it had a manufacturer name and part number on it but no luck.
Has anyone had to replace this and if so do you know what this sort of socket is called and better still where you can get it?
Thanks in advance
All the best
Paul
Paul - Night Train - 415 #136
Date Posted: 08 February 2023 at 14:19
Paul, have you tried Boatoon the Hanse spare part shop?
I think it is Italian made.
Date Posted: 09 February 2023 at 03:17
Hi Frank
Thanks, yes I looked at Boatoon, but they only seem to have the socket for the dimmable light and mine is the earlier version.
I will try and repair it
All the best
Paul
Date Posted: 09 February 2023 at 04:36
If am not mistaken it is made by Osculati:
https://www.osculati.com/en/11397-m-025241/pull-out-table-lamp-for-cockpit-tables#prettyPhoto" rel="nofollow - https://www.osculati.com/en/11397-m-025241/pull-out-table-lamp-for-cockpit-tables#prettyPhoto
apparently they have a new (better) design now, just check the dimension of the base
BR
Date Posted: 09 February 2023 at 09:49
My 385 was commissioned in 2015 and had the fancy (and very expensive) cockpit table lamp manufactured by Halley.  The socket corroded after a few seasons.
I got a replacement socket from svb24.com:
https://www.svb24.com/en/spare-socket-for-halley-table-lamp.html" rel="nofollow - https://www.svb24.com/en/spare-socket-for-halley-table-lamp.html
Date Posted: 09 February 2023 at 11:12
Thanks Guys, it the Halley one, I will order one as the design is not good. In the meantime, some logic, a soldering iron and some superglue seems to have fixed the old one. Despite what they say this isn’t waterproof so I will find a suitable yoghurt pot lid or something to cover the whole thing when we aren’t on the boat.
Thanks again
Paul
Date Posted: 09 February 2023 at 11:40
I have to say this forum never ceases to amaze!
Ask the most obscure question you can think of and 24 hours later you get sensible answers!
Brilliant
Smile
Posted By: Ian Coverdale
Date Posted: 10 February 2023 at 01:04
Lamp is beautiful quality.
Socket is complete garbage ... our second has just failed. Plastic is very flimsy so breaks easily.
Ian & Andrea
SV Gabrielle (H445)
Date Posted: 10 February 2023 at 09:36
Brilliant
Smile
Because we've all been through the same issues at some point!  I also tried soldering the corroded socket (which held up for half a season) and even think I may have shorted mine and blown a fuse too.  I'll see if I have documentation on the fuse location.
Date Posted: 22 March 2023 at 07:02
Hi, still trying to fix my cockpit light! Thanks to S&J I got a replacement socket from SVB24. Now it seems that there is another problem, I have power to the socket but the light doesn't come on. I even tried putting the wires directly onto the light contacts in case it was a socket / light connection issue, but no joy.
Does anyone know if you can replace the bulbs on these lights?
I have tried google but not getting anything useful from that.
As always any advice would be gratefully received
Many thanks
Paul
Date Posted: 01 April 2023 at 04:48
Hi, just an update. I managed to figure out how to take the lamp apart and managed to fix it, one of the wires from the bulb come off the terminal inside the lamp base.
To avoid anyone else making the same mistake, do not unscrew the small screws in the base of the unit as this results in the thing springing apart and small pieces flying everywhere!
There is a little grub screw just above the bottom flange, take this out and then gently unscrew the whole plastic terminal block and then you have access.
Very pleased with that as a new lamp was €350! Plus delivery
Posted By: Viobivall
Date Posted: 06 December 2024 at 22:13
 I wish I read this before trying to fix it myself. Does your lamp still work? I ruined mine, but I got a cool lamp from https://www.sunmory.com/" rel="nofollow - https://www.sunmory.com/
Date Posted: 07 December 2024 at 03:02
Hi, it was still working when I sold the boat in July of this year!
All the best
Paul
