Deck thru hull identification help
Forum Name: 461 / 470
URL: https://www.myhanse.com/forum_posts.asp?TID=13864
Topic: Deck thru hull identification help
Posted By: psousa
Subject: Deck thru hull identification help
Date Posted: 08 February 2023 at 10:59
Hi!
Anyone knows which part is this?
I need to replace it but it's not possible to take it out without cutting it, so I would like to have a replacement before move forward.
https://postimg.cc/mznfP1WT" rel="nofollow">
Posted By: MADaM
Date Posted: 10 February 2023 at 08:29
hard to see where on the boat this is, but it looks like one of the deck drains towards the stern. If you climb into the lazerette you should be able to follow to the outlet
Northern based, South bound!
Hanse 461
Posted By: psousa
Date Posted: 10 February 2023 at 09:46
Hi MADaM,
yes, it's the deck drain on the stern. It's in too bad shape to take it out in one piece. Needs to be cut to remove, identify and replace, according to the boatyard.
But I want to make sure I have a replacement before cut and remove. Should be something like this but I was wondering if someone else replaced this before and know the exact part nr Hanse have used.
Thanks.
inside conditions:
https://postimg.cc/RJdV1LGy" rel="nofollow">
Posted By: psousa
Date Posted: 10 February 2023 at 09:48
Missing URL on previous message: "Should be something like this  http://www.asap-supplies.com/products/seaflow-stainless-steel-316-flush-deck-drain-30mm-hose-511036" rel="nofollow - https://www.asap-supplies.com/products/seaflow-stainless-steel-316-flush-deck-drain-30mm-hose-511036  but I was wondering..."
Posted By: MADaM
Date Posted: 10 February 2023 at 21:18
I doubt you'll get anyone at Hanse to give you a part number! However, it looks like a pretty generic type of fitting. Search "scupper" on Groco.net, make sure you have the right dimensions. If in doubt, just contact them directly.
Hanse 461
