"ARCO DE POPA"
Forum Name: 370 / 375
URL: https://www.myhanse.com/forum_posts.asp?TID=13886
Topic: "ARCO DE POPA"
Posted By: MAJOTE
Subject: "ARCO DE POPA"
Date Posted: 28 February 2023 at 19:06
Hello everyone
I do not know what the stern arch is called, to put solar panels and hold the dinghy. But I would like to ask in the forum if someone has done it and what model has been followed for its placement.
I would not like to make holes in the bathtub, or make as few as possible. And also not spoil the aerodynamics of the boat.
Let's see if I'm lucky and find someone who can and wants to help me.
Greetings to all!!Thumbs Up
Date Posted: 28 February 2023 at 20:55
Use the search function ->advanced->any date................ and you may find for "davits":
https://www.myhanse.com/search_results_posts.asp?SearchID=20230228205320&KW=davits&PN=1" rel="nofollow - https://www.myhanse.com/search_results_posts.asp?SearchID=20230228205320&KW=davits&PN=1
Posted By: Ratbasher
Date Posted: 01 March 2023 at 06:29
Hi Majote - I'm having one made right now.  There is no standard 'pattern' and you should find someone who specialises in making them.  Ask to see other examples of their work; if they're good they should have an 'eye' for how the design should complement the lines of your boat.
I'd strongly suggest you think deeply about what effects you want to achieve and discuss this with the builder.  For me this was:
Create a 'cage' at the stern for greater security offshore in a seaway
Provide a platform for radar, solar panels and other aerials
Replace guard wires along both sides of the cockpit to the sprayhood with solid guard rails
Replace the removable guard wires across the transom with removable solid guard rails
Provide a much stronger frame for the cockpit tent
Unless you are mainly day-sailing from anchorage to anchorage, I would strongly advise you not to hang a dinghy from the back end as weight at the extreme ends has a significant effect on seaworthiness, speed and safety.  Everything is a compromise and its up the owner to decide where the balance lies; my choice suits my boat and my type of sailing but if you only sail in sheltered waters in calmer conditions you could quite safely choose differently.
My manufacturer integrated the arch into existing pushpit so no extra holes were drilled through the deck.  However, he seriously increased the strength of the backing plates below the deck.  The attached photo shows the uncompleted arch; guard rail extensions, panels etc still to be fitted.  However, it shows you how the builder has carried the natural curves of the boat into the design.
Good luck!
Posted By: andrewlambert
Date Posted: 01 March 2023 at 12:06
Ratbasher
Love the lines , looks like it will be great
They can look awful that does not
Hanse 370 #237 "Ginger Bay" UK, River Hamble
Date Posted: 01 March 2023 at 16:07
Thanks Andrew - just have to dissuade the missus from using it as a clothes line....
Posted By: MAJOTE
Date Posted: 16 May 2023 at 09:14
¡Muchas GRACIAS, Mataratas!
Agradezco tu post encarecidamente.
Pronto iniciaré un trabajo parecido al tuyo, y agradezco también tus sabios consejos acerca de la garga del arco de popa y de la navegación.
Guiño
Posted By: Pepote
Date Posted: 16 May 2023 at 09:47
Hola, buenos días, Majote:
Tengo un H345 en España y tiempo atrás le monté un arco de popa para colocar los paneles y pescantes para la neumática. No se colocar aquí fotos pero si me dices tu mail, te envío algunas. Me lo fabricaron en Cartagena.
Un abrazo.
Jesús
Jesús
Posted By: MAJOTE
Date Posted: 16 May 2023 at 10:27
Hola Jesús!!
Encantado de conocerte!!
Me interesan mucho tus fotos y hasta los planos o medidas si los tuvieses, porque por esta zona hay pocos que se dediquen a ello.
Este es mi correo, y estamos en contacto!!
Un saludo
Clap
Posted By: Pepote
Date Posted: 16 May 2023 at 11:05
Hola, Majote:
Te he contestado por privado pues no se como incluir aquí las fotografías.
Un abrazo. Jesús
Jesús
Posted By: Pepote
Date Posted: 17 May 2023 at 07:30
¿Has recibido las fotografías que te envié?.
Saludos. Jesús
Jesús
Posted By: MAJOTE
Date Posted: 17 May 2023 at 08:49
NO, Jesús.
No los he recibido, cuando puedas revisa el correo a ver si no te lo puse bie.
Te lo pongo de nuevo: jomaflor@gmail.com
y de nuevo, gracias.
