Switch Panel
Forum Name: 430
URL: https://www.myhanse.com/forum_posts.asp?TID=14015
Topic: Switch Panel
Posted By: Greekgunner
Subject: Switch Panel
Date Posted: 15 May 2023 at 21:56
Dear all.
I just became an owner of a Hanse 430e.
At the Switch panel, which is a Calira 331 with led bars, some of the LED indicators do not lit.
Does anyone know how i can replace those LEDs. I opened the panel and saw that the LEDs are in small plaquettes that can be replaced....
Where i can find them?
Thank you in advance
Posted By: John15grob
Date Posted: 16 May 2023 at 10:37
Hi check the fuses there are 3 fuses were the battery isolators are on the inside. Access panel is above the battery on the bqck rest.
