Hi guys
For those who are interested, I here document how I installed a 2000w inverter.
inverter.jpg: final installation in the lower electric cabinet
My first worry was where to install the Inverter but got help for this forum ( https://myhanse.com/where-to-fit-a-2000w-inverter_topic13998.html" rel="nofollow - https://myhanse.com/where-to-fit-a-2000w-inverter_topic13998.html )
The requirement was to be able to run a 1000w kettle and other smaller 230v consumers. To be on the safe side the Inverter should be able to provide up-to 2000w.
Victron sells a 2000w Smart Inverter 485 X 219 X 125mm for 1000$ / 940 euro. But I chose: Renogy 2000w Inverter with UPS, 442 x 220 x 92mm for 240 euro (280$ for 110 volt version).
The Renogy has a smaller case, which was important because I have the 3-cabin Hanse 370, so there is no utility/storage locker. But the inverter must also be very close to the batteries.
The Inverter has a UPS function (Uninterruptible Power Supply), but I was uncertain how that could be utilized in my boat. The manual stated that the Shore-Power could pass through the Inverter. Therefore I made quick try-out connecting the Inverter to the batteries and Shore-Power. Beware the first time the Inverter is connected, a huge capacitor is rapidly charged and it made a spark.
• The Inverter does not need to be turned on, or be connected to the batteries to let Shore-Power pass through to the 2 outlets • The Inverter uses 1A (13 watt) when turned on but with no load on the 2 outlets • The Inverter uses 0A when turned off. (could not measure any consumption at all) With this knowledge I knew that it would be possible to make a fixed installation with no need to switch plugs/outlets. Also very important that the use of Shore-Power would be handled exactly as before, so the crew would not need education… (update: So the Inverter is only turned on seconds before it is needed, and then turned off after use eg. the water is boiling). When turned off, the Shore-power feeds the galley-outlet and the microwave-outlet as normal) I chose to intercept the galley outlet and the outlet in the closet above the stove( https://www.myhanse.com/220v-connector-behind-shore-power-panel_topic9770_post94486.html#94486" rel="nofollow - https://www.myhanse.com/220v-connector-behind-shore-power-panel_topic9770_post94486.html#94486 ).
The galley outlet was marked with “3”:
galley_outlet.jpg seen from within the sink-cabinet
The other end of that cable “3” was found connected to the electric Panel.
Electric_panel.jpg. Backside seen from within the cabinet. Very hard place to reach.
When removing the “3” cable it was in a harness with one other 230v cable. I was lucky because the other cable “6.” was the one for the microwave outlet!
pantry_harness.jpg. Thx. Hanse... 487 is the buildno. For my Hanse 370.
Being lucky again, it turned out the harness was quite long. long_harness.jpg
The two wires were cut and Schuko 230v male (CEE 7/4) /female (CEE 7/3) plugs installed
The female plugs were put back into the electric panel and the black wire to the right is going to be the Shore-Power feed to to the Inverter. This way it will be possible to restore the 230v to the galley if the Inverter where to be discarded.
Now it was time to look at the 12v DC side. Renogy has a guideline for calculating the Fuse-size: Fuse Recommended = Inverter Watts / Battery Bank Voltage / % Efficiency * 25% safety factor ( https://www.renogy.com/academy/accessories-wiring/Fuses-and-Wire-Gauge" rel="nofollow - https://www.renogy.com/academy/accessories-wiring/Fuses-and-Wire-Gauge ) so 2000W / 13v / 0.90 * 1.25 = 213A I chose a 200A Fuse The cable-length was measured to: 1x20cm red, 1x105cm red, 1x45cm red and 1x85cm black. The inverter black goes straight to the bus-bar. The Inverter red goes to fuse-box, then to the dedicated battery switch and lastly to a positive feed from the 3 Lifepo4 (100AH) batteries. Cable thickness can be calculated with this page https://www.12voltplanet.co.uk/cable-sizing-selection.html" rel="nofollow - https://www.12voltplanet.co.uk/cable-sizing-selection.html The length is 2.55 meters in total (even-through the Inverter sits right next to the batteries… 1.7 meters(positive is longer) and 2000w/0.90 = 171 Amps and voltage is always above 13 = 50 mm2 square equals AWG 1/0, is a good choice and voltage-drop is about 1.75%. In Scandinavia there is a Brand called 1852 with Marine Professional tinned cables. I also got fuse-box and a battery-switch that looks like all the others. With a large crimp-tool I could make the cables my-self. The Renogy comes with a remote also.
inverterkit.jpg and accessories
The Battery-switch was installed near all the other switches. But here I made a mistake. The switch requires a 23-24mm hole, and I got a 25 mm drill that I wanted to use. But somehow the 27mm drill found it’s way to the drilling machine…
The Fusebox was installed on the wall up against the head, right next to a Ground Bus-bar. fusebox.jpg
All the thick cables was installed first, then the Inverter was placed into the lower electric cabinet.
Beware that the Inverter has a large capacitor and I made a huge spark again when tightening the positive connector and hitting the Inverter Case at the same time. This capacitor must be huge, because when turning on the Inverter for the first time it draws 20 amps. I think it is much more than that but the sampling rate for my shunt is not updating fast enough to show the real instant draw.
1st try. The Inverter was turned on and and the 1L kettle (1000w) was heating the water to boiling point I 6 minutes. The kettle was measured to use 987 watts and the shunt showed it used 86A. The battery Shunt showed that 2.9% of the 300Ah battery capacity were used (approx. 8.7 AH used) The Renogy Inverter is “Pure Sine curve” but it is built in China, so just to be certain it is a good product I also measured it with a oscilloscope. The Sine curve was rock solid also when turning the 1Kw load off and on.
The Renogy states 90% efficent and the cable-loss is approx. 1.75%. So the needed power to use our kettle is 987watt / 0.90% + 1.75% = 1115w. My shunt showed 13.05 volt under load and 86 amps = 1122 watt so the 90% efficiency looks to be correct.
86 amps is a lot so all connections were inspected with a Flir-One thermal camera.
Beware the Thermal images look like the cables are red-hot glowing, but they were only 5-7 degrees Celsius above ambient temperature. I will monitor this issue so I am certain no mistakes have been done.
Battery switch backside seen from within the cabinet. It shows my crimped terminals are OK. Flir_BatterySwitch.jpg
Fuse-box seen from above. The wire has insulating tape wrapped around the terminal because it is located near the negative for the Inverter. And to avoid accidental short_circuit I used tape. But this makes this terminal the hottest part of the entire installation. Flir_Fuse-Box.jpg
The Renogy inverter has two Fans but they have not yet started spinning. The Renogy had zero to none heat generation with serving 1Kw…
Here are some of the more specialized tools I used for installing the Inverter. invertertools.jpg
Was it hard? Not really. But knowledge of high current(12v dc) and mains voltage is needed. I used 10 hours (excluding many hours cleaning up and doing long needed cable management in the electric cabinet). Do to my native language is danish, I also used 4 hours writing this post...
I hope this post can inspire others. (BTW. I am in no way sponsored except from alms from my wife :-)
/H8jer
