Buying a 371, any special checks?
Forum Name: 371
URL: https://www.myhanse.com/forum_posts.asp?TID=14150
Printed Date: 12 April 2024 at 15:10
Topic: Buying a 371, any special checks?
Posted By: Laro88dk
Subject: Buying a 371, any special checks?
Date Posted: 18 July 2023 at 21:24
Are there any particual things to check on a 371?
Deck delaminations / balsa rot, week hull spots, stearing, keel support, weak fittings etc?
Posted By: martijnvdh
Date Posted: 19 July 2023 at 15:21
Other than the usual checks when buying a second hand boat, the only thing I can think of is the aluminium rudderstock. In the original configuration it was connected by grounding wire to the keel & saildrive, causing galvanic corrosion issues. Applying copper-based antifouling in the direct vicinity of the rudderstock can also create issues. These are well-documented on this forum and can be found throughout the Hanse range (not specific to the 371) of that era.
We bought hull 297 last year, sailed her from Finland to The Netherlands and I have not been disappointed in any area. Build quality is generally good in my opinion.
Posted By: Laro88dk
Date Posted: 19 July 2023 at 20:39
Thank you - i will look for the grounding wire and corrosion.
By the way - where is the hull number located?
Kind Regards.
Date Posted: 21 July 2023 at 06:37
The HIN (hull identification number) is engraved in the gelcoat on the port stern, just under the deck level (outside) on our boat.
