Spinnaker Size
Forum Name: 350
URL: https://www.myhanse.com/forum_posts.asp?TID=14243
Printed Date: 27 March 2026 at 02:05
Topic: Spinnaker Size
Posted By: NK1
Subject: Spinnaker Size
Date Posted: 08 September 2023 at 10:25
Hi all. Looking to rig my 350 with a spinnaker. Has anyone done this and what size spinnaker do you have? Also how is it rigged? Thanks.
Date Posted: 08 September 2023 at 13:28
I think you are better off with a asymmetrical spinnaker / gennaker.
My old 311 had 65 sqm. My 370 has 105 sqm.
Cheap and efficient way is to buy a standard size from eg.  https://www.rollytasker.com/en/our-sails/downwind/ready-made-spinnaker/" rel="nofollow - https://www.rollytasker.com/en/our-sails/downwind/ready-made-spinnaker/
To get the right size you need to know the height form the bow connection point to the haleyard exit out the mast.
Getting a real spinnaker with pole and barberhaul is not very Hanse-like. Only for those who do racing/regattas.
Hanse 370#487 30HP 3-cabin
Posted By: NK1
Date Posted: 10 September 2023 at 19:53
Thanks for this. It is for club racing but might look into a Asymmetric. Any suggestions for best downwind angles?
Posted By: Mark_J1
Date Posted: 10 September 2023 at 21:48
You won’t get an asymmetric to work well dead downwind (assuming tack is on a sprit). Assymetric will usually work well from 90-160 AWA. Maybe 80-170 AWA depending on cut & wind speed.  That said, if you want an asymmetric to perform from 90-180 then attaching the tack to a pole and getting out from behind the main will work better. On the other hand, if you have the pole then a full symmetric spinnaker will give you the most ‘pull’ from 90-180 AWA.
Posted By: rubin
Date Posted: 23 December 2024 at 13:31
Ciao a tutti, vorrei montare una delfiniera per il mio gennaker, qualcuno lo ha montato? Come potrebbe essere fissato? Il gavone dell'ancora è controstampato!!!
http://album.foto.virgilio.it/rubin_bottiglieri
Posted By: alettaenmarcel
Date Posted: 23 December 2024 at 21:15
One from ORC.org
Posted By: cptgood
Date Posted: 31 December 2024 at 18:23
I believe they could help you:
https://www.sailservice.it/" rel="nofollow - https://www.sailservice.it/
