Shower at swim platform
Forum Name: 411
URL: https://www.myhanse.com/forum_posts.asp?TID=14246
Printed Date: 26 March 2026 at 23:46
Topic: Shower at swim platform
Posted By: seanmagner
Subject: Shower at swim platform
Date Posted: 09 September 2023 at 18:12
One of the pipes going into the shower at the swim platform has fallen off. There appears to be a metal connector that has disappeared somewhere in the compartment under it. I will need to source one of those. But for now the problem is that once the water pump is on, we get a constant flow of water going into that compartment at the stern.
As a short term solution, I'm wondering if anyone knows if there is a way to isolate the stern shower and turn if off so I can put on the pump and use the other taps.
Thanks for any help
Sean
Date Posted: 09 September 2023 at 18:35
Ok. I found it. Right beside the shower top there's another compartment to control hot/cold and also switch it off
