Volvo D55 diaphragm change 415
Forum Name: 415/418
URL: https://www.myhanse.com/forum_posts.asp?TID=14271
Topic: Volvo D55 diaphragm change 415
Posted By: Mike2145
Subject: Volvo D55 diaphragm change 415
Date Posted: 30 September 2023 at 08:08
It’s approaching that time on my 2014 415 to think about a diaphragm change.
Looking at the engine bed I’m fairly sure there’s enough room to pull the engine forward enough to clear the sail drive, the water pump can be removed for this and the back of the engine can be supported from above so this seems to be OK.
I’m wondering if anyone has done this job on a 415 as I’m not sure if there is clearance to remove the leg. It seems a bit tight for access.
Have done a search but couldn’t see any info on this specific engine boat combination.
Posted By: 415 Singapore
Date Posted: 30 September 2023 at 09:51
Hi, can’t really help as we have the D40 on which it is possible to do what you suggested. What I would say was that it was a complete waste of time and money as the diaphragm we took out looked like new! I know I am not the only one discovering this,  but Volvo are adamant that they should be replaced every 7 years.
Good luck
Paul
Paul - Night Train - 415 #136
Posted By: Mike2145
Date Posted: 30 September 2023 at 10:02
Thanks Paul
Just at the planning stage so not intending to do it this year.  This is going to be done more for a future resale value point of view as opposed to any practical need at the moment.  Like you I've seen a few diaphragms replaced that look like new!
Posted By: Yeoey
Date Posted: 13 April 2024 at 07:52
Greetings,
I paid to have mine replaced last year and as mentioned in the posts, the old unit looked like new however it was replaced as i like to rest easy that in the event of a related ,sinking” problem i have adequate insurance cover - the Hanse booklet says 7 years and I was over that time period as boat was launched  in May 2014.
It was a 2 man job to remove and reinstall the leg wth unit taken back to work shop for pressure testing and a look over, motor at the time about 460hours.
To save me an extra day yard fee i arrived at marina slip on previous evening and boat was hand moved into lifting bay as mechanics would not work in the engine bay if residue engine heat was present.
As suggested all gearbox connecting bolts/nuts were removed together with exhaust hose.
They then undone engine mounts and using timber they slowly levered the motor forward to disengage the sail drive.
Hope this helps
Peter
PS i lost me Etchells whilst it was the hard stand at Xmas as part of major wind storm (Gold coast Australia) and the lesson i learned once again, is that what ever is written in the fine print of the PDS or contract is how a claim is assessed and paid- it was written off once repair estimate was over about 65% of MV applicable at time of incident. Also as an example, another friend who had agreed specific value with his boat insurer but in a race incident where the other boat was at fault, that at fault boat insurer refused to meet the claim for new mast and mainsail on grounds that the cost was much higher than the current market value- issue then a s..t fight i guess trying to out negotiate a large company- as an ex banker i often tell friends that your Bank will lend you money to buy an umbrella “but take it away when it rains”! -all ways look at the fine print closely!
Peter
Sea Rambler 415 # 137
Posted By: maggie.scheunert
Date Posted: 26 June 2025 at 00:24
Hey! Just wondering if you ended up doing this? I also have a 2014 415 and am preparing for a long cruise. If you did it, how did it go? Would you recommend it based on how the old one looked? How long did the work take?
Thanks so much!
Posted By: Yeoey
Date Posted: 03 July 2025 at 12:11
Evening Maggie
Yes it was done as explained as part of a usual haul out process - it was done by a business and involved 2 workers for most of the process
When removed the condition was excellent and as I explained was never did ne due to any obvious problems - especially as the hour engine nos were very low - I simply do not trust insurance companies to give any cover if something occurred outside recommended replacement time - it us a personal gamble-
 as an aside one of my crew has a lagoon with sail drive(Yanmar I think) boat is similar age but has over 4000 hours on its motors - he has never changed his units - his boat is in the med and is stored on the hard during winter periods - so bottom line a personal chance or gamble realistically - also have another friend with a granger launched around 2000 - still has original units and remains comfortable with the risk although I am unaware of any conditions/coverage exclusions apply as I would have thought a surveyor would have commented
Peter
