Mainsheet travler
Forum Name: 350
URL: https://www.myhanse.com/forum_posts.asp?TID=14357
Topic: Mainsheet travler
Posted By: Snublefot
Subject: Mainsheet travler
Date Posted: 13 November 2023 at 19:29
I want to replace the fixed maisheet system with a travler.
I have taken down the celing and can see the fastning. The plan at the moment is to use an Harken R27HB High Beam Track. Get an welder to make me some fastnings that i can fasten to the eksisting fastnings and slide it in the internal slide of the track.
If someone have some tips, i will be grateful.
Posted By: PalleT
Date Posted: 25 November 2023 at 19:11
I made the same last winter. If your boat is a 350, be aware that the sprayhood base is round and the center part is between the blockbase, so you will need to place a 1 or 2 cm extra platform on top of the original base for the old blocks. I used epoxy.
Posted By: PalleT
Date Posted: 25 November 2023 at 19:16
I had also fastenings made, but decided not to use them. Instead I used two bolts in each platform. It has worked fine during the season.
Posted By: Mark Pullen
Date Posted: 12 April 2024 at 14:01
Have a look at the following post. I think this is exactly what you want. I'm considering doing the same, but have a few other items higher on the priority list. I'd be interested to hear if you go ahead.
https://www.myhanse.com/coachroof-mainsheet-traveller_topic12983.html" rel="nofollow - https://www.myhanse.com/coachroof-mainsheet-traveller_topic12983.html
