Differences 400 vs 415; plus & minus
Forum Name: 400
URL: https://www.myhanse.com/forum_posts.asp?TID=14447
Topic: Differences 400 vs 415; plus & minus
Posted By: PSCOE
Subject: Differences 400 vs 415; plus & minus
Date Posted: 21 January 2024 at 15:57
I am in the process of deciding on a larger sailboat from my C&C 110, I have narrowed it down and I have either a Hanse 400e or 415 as one of the options and reserach I am doing.
Although 415 is a newer model, I go back to the 400 starting at 2008 and newer as a better option (and more sail trim options)
I was wondering if you could weigh in on your thoughts as owners of the 400.
My opinion as advantages and disadvantages:
Advantage for 400
- 400 has an option of a single wheel and open transom/transom bar. Although I like dual wheels, not sure why the market is pushing a dual wheel on a 40' sailboat.
- What I have seen, 400 series starting from 2008 has flush hatches
- LOA is nearly the same as the 415
- Big one for me - shrouds are on the inside of the deck, genoa tracks and additional sail option for a genoa where the 415 shourds on on the outside, only allowing the option to install tracks on the cabin top, which is not ideal as a improvement
- 415 does not have a mainsheet traveler where most of the 400 has a traveler
- 415 seems to costs about $70k more than a 400, just a few years difference - $70k difference could be nice as a refit for a 400; purchase new lam sails, upgrade running rigging, etc...
- 415 has everything running back to the helm. Trying to make it easy to sail can become a big disadvantage and limits you in providing good sail trim and with a crew.
Advantage for 415
- 415 hull seems like a slighly better design, longer LWL, slightly faster and not sure if this is a good or bad change, stern is a few inches wider.
- 415 has a full full swim platform.
- T-bulb keel
- Better interior
On the 415, seems like they made good improvements to the hull and keel but tried to simplify the sail trim / sailing part.
Patrick
Patrick
Posted By: Matt1
Date Posted: 21 January 2024 at 19:50
I have a 418, so the same hull as a 415 but the 418 has the L Keel not T
I’ve always thought the 400 looked a sweet and nicely proportioned boat. I’d imagine she has less wetted surface area and would guess she displaces less. Personally not a fan of T keels so don’t see the lack of that as a disadvantage.
You may have seen this review of the 400
https://www.yachtingmonthly.com/reviews/yacht-reviews/hanse-400-popular-modern-performance-cruiser" rel="nofollow - https://www.yachtingmonthly.com/reviews/yacht-reviews/hanse-400-popular-modern-performance-cruiser
Posted By: PSCOE
Date Posted: 21 January 2024 at 19:54
thanks - I will look at the review. I have been reading as much as I can on the two different models.
Patrick
Posted By: Ratbasher
Date Posted: 22 January 2024 at 06:42
Hi Patrick
They're reasonably close to each other in terms of purpose & build so I'd recommend having a serious think about how you like to sail: actual time likely spent living onboard, both in cockpit & salon.  Racing or cruising or both; are you a control-line tweaker or more relaxed? How long you realistically expect to own the boat.  Personal preferences; I hate dual wheels but others love them, for example.  Some folk might well prefer outside shrouds.
Small differences like the LOA are unlikely to make any difference at all in the real world except in the hands of a true expert or as a racing yardstick.  T-keels I regard as the invention of the devil if you cruise where crab-pots abound; they only became popular when the price of lead shot up and a lead keel is IMO far preferable anyway.
I know you're only just starting to whittle the choices down but the only way you're ever going to be able to decide is when you have two or more actual vessels to consider.  Given the similarities in design, I'd recommend choosing on the basis of what one feels right to you - and of course the cost.  Whatever you buy, I'd strongly advise keeping about 20% of the price back to pay for the inevitable upgrades, faults etc that you're certain to find you need.  One with recent sails, standing/running rigging and saildrive gaiter changes plus updated electronics will save you big bucks.  This forum contains a wealth of information on how people have adapted their boats to their own needs, from fridge insulation to swimming platforms so you can alter things later at your leisure.
Interestingly, I read the other day that 33% of call-outs to boats suffering engine or rig failures in the UK were to boats less than 6 months old.  Astounding statistic, which perhaps shows the value in buying a decently sorted older vessel.
Good luck whatever you choose.
Iain
Posted By: Mark_J1
Date Posted: 22 January 2024 at 22:47
As Duncan Kent quoted me in the review of the 400, I guess you’d have to call me a biased witness!  So I’ll leave you to read my broad comments in the review :).
However, picking on your Genoa comments specifically, how often are you prepared to change the sail on the foil while at sea?  How much time do you spend in light wind?  What’s your average passage duration?  The Genoa on the 400 is in its element <12kts upwind. You can certainly hold it longer (much longer!) but the cross-over point with the STJ is about there. The Genoa is the same size as the main & sail swapping on deck is an art. Especially so solo!  Clearly the logic of a Code sail on the 418 is to cater for those that don’t want this hassle.
So that said, why would I have the Genoa?  Once you get to a Reach in say 14kts the boat really starts to take off!  Broad reaching in 16kts you’ll be smiling!  And you can still turn upwind, roll some in and manage to hold 43-45 degrees to windward (with main reefed of course). Which isn’t possible with a Code 0. So it gives a lot of flexibility.
Downwind in the higher wind ranges it can be really helpful. Especially poled out. I actually have a pair of genoas and can load them both together to get 108SqM of downwind sail area for a very easy reefable sail plan. That’s not much less than the Azzie at 124SqM & the symmetric at 140SqM’ish. Makes for easy passage miles.
I race on another boat with furling Azzie & Code 0. I see the attraction. If budget & space for storage were unlimited I’d have them too. So in that sense the 400 as standard lets you do it all if you are minded too :)
Posted By: Brufan
Date Posted: 23 January 2024 at 08:30
I might be more critical...
When H400 has been designed (back in mid 2000') by J&V they made a "fast cruiser".
Then Hanse group purchase DEHLER.  This Dealer brands aim to provide "fast & light cruiser / racer"  So, by early 2010', Hanse brand made more comfy, more heavy, easy to handle.  Gadgets to sail fast disappeared (even as optional), usually one pair of winches only, masts were lower and set more backward to increase fore triangle, ... Hulls became wider (very wider at bow section) The aim was to compete with Bavaria's and Oceanis.
As for quality, since 15 years now, Hanse management has turn "penny pinching" as company religion.  Some costly to build "luxuries" disappeared (I have a H355 which is H350 minus 2 lockers, 4 hull windows, 2 hatches less and simpler interior but I still could order 2 pair of winches, sail tracks, ...).  OK, the xx5 gen yachts are roomier, bulkier, and might be more comfy but this comes at a (performance) price compared to the xx0 generation.
Bruno
hanse 355 - 57
S/Y Spicy Ginger
Date Posted: 23 January 2024 at 09:42
My 400 from 2006 is with side windows opening inward. After 18 years I still have no problems whatsoever. Later models (from 2008/9 i imagine) were delivered with different side windows in tinted acrylic glass, opening outward. If you go to the right top of this page and use "Search->Advanced search->Hanse 400->"side windows"->Any date->"
you will find that the later models had problems with leaking windows.
In 18 years my most costly repair was 2 broken engine mounts (Advanced search->"broken engine mounts"), which the Hanse yard had installed wrongly.
My boat is now of an age so I have to consider a change of the standing rigging, but otherwise the cost of maintaining the Hanse 400 has been low. As maintenence I have changed the saildrive diaphragm and the brass seacocks (Advanced search-> "seacocks"), and I believe that only the most reckless of sailors is still cruising with the old brass seacocks.
Many H400 owners have had problems with the Yanmar SD50 saildrive (Advanced search->"SD50"), but (knock on wood) my saildrive clutch still has no slip after 18 years. It is important though, to use the GL4 oil for the saildrive, NEVER GL5!
:Kjeld
Posted By: Trav
Date Posted: 23 January 2024 at 23:26
My 10 cents....
H400 is a fun, easy to sail yacht with a fairly practical layout.
Some issues you would consider...
Wiring is not tinned, it suffers from early corrosion and is difficult to access, i guess this would be the same for all models of Hanse.
The anchor winch if fitted is designed so that the chain will not fall into the chain locker on its own. I think Hanse have carried this design flaw on to most of their designs.
There was a time where the rudder was bonded to the common bonding system which caused considerable corrosion to occur to the aluminium rudder post (Hanse issued a notice to rectify this but you should pull the rudder and check for corrosion to be sure of the condition).
The under deck jib furler found in newer 400's are stiff to operate, you will find many posts on this if you search.
Outward operating portholes tend to leak and require attention as stated above.
Factory fitted hot water service was made from mild steel and quickly rusted out. I would assume that these would mostly be replaced by now, mine went 2 years ago (2008 #526).
There is considerable conversations regarding the SD50 sail drive and in particular its clutch slipping and which oil to use (search function is your friend here again).
Overall i would highly recommend the 400, If you were prepared to put the savings from a newer model into a refit you would no doubt have a quality yacht that you would enjoy for years to come. This site has been super helpful to me as i have upgraded our 400 into a super reliable cruiser/racer (albeit more slanted towards cruising).
Hope this helps.
Date Posted: 24 January 2024 at 07:24
It sounds like you have answered this for yourself.
The 415/8 carries the beam aft, hence it requires dual wheels so you can see the sails from the wheel.
All lines come back to the helm and there is no traveller or Genoa option as Hanse have gradually moved their objective for the brand from "performance" (now handled by the Dehler range) to "easy to sail".
I'm guessing if you want to tweak everything with a full crew the 415/8, and maybe even Hanse, are not right for you.
When buying my 385 (new 2015) I had also looked at 7-8 year old 370 models which were about 50k less than a new boat.
I had no regrets getting the new boat and have since traded in for a new 458.
Most of my sailing is solo or with one inexperienced crew.
There will be many owners of 370 and 400 models who would not swap for newer boats.
There are no rights or wrongs here.  All boats involve a compromise.  I love the brand and I'm certain that you will be happy with whichever Hanse you choose.
Posted By: PSCOE
Date Posted: 24 January 2024 at 23:32
Thank you. So many good posts and advice.
Very helpful.
Patrick
Posted By: Gaga
Date Posted: 04 February 2024 at 12:01
I have Hanse 400 year 2008 since 8 years Single steering wheel.
Love the selftacking jib plus furling code zero  sailing with my wife.
When sailing distance or evening regattas with crew we fly spinnaker, code zero and furling genakker depending on wind angles.  Carbon sails
T keel.
She steers with two fingers. No need to reef up to 12 m/sek.
my Biggest problem ever is the
SD50 cone clutch which needed replacement after only 1200 engine hours
Cost usd 5500. Engine needs to be moved , cooling system dismounted ans well as exhaust.. this you should check very carefully before purchase.
One of our parameters when purchase what the Schrouds  as you mention.
Easy walk on the boat was a must for us - didn’t have that on our previous boats.
If you wish confirmation of solidness you should look at the keel bolts
On 400 and compare with jeanneau - Bavaria etc. they are convincing.
So is the boat. We li love it and will keep for years to come.
My only regret is that I have 400 and not 400e
Don’t know h415.
Good luck.
Date Posted: 04 February 2024 at 13:23
Largely agree with Gaga but I'm surprised at the need to move the engine.  Before I had the upgrade done (plenty of info on this site) thus eliminating the major issue with the SD50 saildrive, I had to have the clutch removed 3 times for lapping; removal was quite straightforward.  Cost of the upgrade parts was $650 direct from Florida two years ago, while clutch removal and lapping cost £400 the year before.  I think Gaga must have been particularly unlucky as the service life of the clutch is given as 2000 hours by Yanmar.  'I'm hopeful' that the upgrade kit will extend that - but I'll find out in about another 600 hours of use....
Date Posted: 05 February 2024 at 06:52
I agree on that statement.
Last Season a friend of mine, with his B42 with T-keel, got entangled in some fishing equipment at night when He had sails up. It took him some time to get off again.
So for cruising I would prefer a L-Shaped keel.
This is also discussed in this paper about keel-designs.:
https://publications.lib.chalmers.se/records/fulltext/148387.pdf" rel="nofollow - https://publications.lib.chalmers.se/records/fulltext/148387.pdf
Intended Yacht type and hull: for an ocean crossing yacht a T-bulbed keel might be
unpractical due to the risk of nets and lines getting stuck whereas a racing yacht needs a Tkeel for the required righting arm
Hanse 370#487 30HP 3-cabin
Posted By: Rock
Date Posted: 05 February 2024 at 10:28
Interesting thesis !
Hanse 400e "M-square2" #0241
Posted By: Ggerrit
Date Posted: 05 February 2024 at 15:34
I have to agree with Gaga, We changed the sd50 in a sd60 and no problems at all.
I love the 400.
Gerard
H400 2008 2 cabin
Date Posted: 05 February 2024 at 20:44
A danish couple in a non-Hanse yacht, "Petra" lost the keel in the Atlantic Ocean some years ago. I had considered this brand before I bought my H400, but one of the items that turned me to a Hanse was the difference in the size of the keel bolts.
This photo is of the keel bolts of my H400:
Posted By: Gaga
Date Posted: 05 February 2024 at 22:08
Exactly what i ment. Rosksolid
Posted By: jeb
Date Posted: 11 February 2024 at 11:25
As many wrote the 400 should be compared with the Dehler segment while the 415 has more focus on comfort (as Bavaria’s). I have a 2006 400e and for my usecase (coastal sailing in the Baltic) it’s perfect. I have swapped the selftacker for a 107% and for me this is a perfect compromise. I have main track in the cockpit and “German sheeting”.
Sd50 is an issue but after upgrading with the kit from Florida I have no issues. The only structural thing to watch out for (except groundings) is the GRP/gel coat layer outside the epoxi that on some boats has separated.
Jesper
Hanse 400e
Posted By: Arborist
Date Posted: 10 September 2024 at 22:03
What did you get in the end??!!
hanse 400
2007
no 244
