Hi Sam
Quick answer: if it was my boat I'd go for a 37kg Spade or similar new generation. I'd be happy with 10mm chain provided it was genuinely high-tensile and definitely not G30/BBB. I'd check that the cleat backing plates could handle the loads and that I had a decent snubber.
Longer answer: I had exactly the same sort of concerns as you soon after I bought my H400 so I researched the likely forces that the anchoring system would have to deal with. The ABYC tables are pessimistic against other standards but they're not a bad guide if you want to take more account of other variables such as yaw, surge etc. I worked out the worst conditions I was ever likely to anchor in and sized the elements in the system accordingly. Although I've put the link out on this forum before, it might be useful to repeat it: http://alain.fraysse.free.fr/sail/rode/forces/forces.htm" rel="nofollow - Forces (free.fr)
Don't ever believe that Hanse made any great calculations when they spec'd your boat; what they provided for the H400 (15kg Delta and basic chain) would barely have been enough for flat water in a F4. "Anchor? - yeah - its got one".
10mm G43 chain has a SWL of 1800kg, MBL of 7200kg and weighs 2.3kg/m. The winch manual should tell you if its capable of hauling the combined weight of the rode. You could go to 12mm but that'll increase the weight by .5kg/m which will affect performance, even on a ship the size of yours. You'll also have to swap over the gypsy though that should be easy. 10mm G70 has similar SWL/MBLs to 12mm G40, costing you a lot more money but saving a lot of weight right where it hurts. Only you can decide on the priorities, which is where Fraysse's calculations are useful to help you make an informed judgement.
Hope this is helpful!
Iain
------------- H400 (2008) 'Wight Leopard' Gosport, UK
