Problem Solving Time Next time you furl the jib, go forward and pull the rope direct from the drum. If it is a lot easier, then you need to look at the furling line route. I replaced various stanchion bullseyes with pulleys and then replaced the plastic pulleys with alloy ones turned by my elder brother. (Sometimes they do have a use!) The final turn to the cockpit definitely should be from a pulley.
Just before furling, ease the jib halyard by 5cm and see if this makes a difference. Yes, I know some furler manufacturers say do not ease the halyard as you risk a jib halyard wrap, but 5 cms should not cause a problem. If it does, then it suggests the angle between the jib halyard and the forestay is too small. It should be over 10deg and if it is not, then consider putting some shackles at the head of the jib to change the angle. Actually this is good practice as it means the jib is stored with no tension in the luff cloth.
If you have powered up the backstay in strong winds, then ease it slightly before furling the jib.
Top furlers being stiff is a well known problem. See what maintenance you can do . For some you can only flush them with water, whilst you can open some up and give them a squirt of silicone. (That is on my job list for tomorrow.)
As others have said good pulleys and thinner dyneema sheets are a big help. We have kept ours with a pulley on the jib clew, so that makes it easy for my wife to sheet the jib.
As others have said, you put a 3rd reef into the main to reduce the sail, rather than reefing the jib. The yachts are quite happy downwind with the jib completely furled.
Here is how I set up a single line 3rd reefing system.
https://www.myhanse.com/single-line-3rd-" rel="nofollow - https://www.myhanse.com/single-line-3rd- reefing-setup_topic10548_post96364.html?KW=reefing#96364%C2%A0
