As you know
by now…. I am the guy that always runs into issues with my Hanse 505.
- Replacement
of part of the flexiteek deck because of use of regular steel in stead of inox….
warranty
- Autopilot
failure (3 times and 3 costly repairs)….. expensive
- New stays
after 3 years of use….. expensive
- 3 new
B&G devices because of water inside the units…. expensive
- Sail-drive
issues with the oil drain plug… new lower shaft… expensive
- All Lewmar
deckhatches had to be replaced because of excessive corrosion…. expensive
ALL of the
above is the DIRECT result of work at the Hanse factory (I investigated every
issue in detail and this is the conclusion: Hanse did not do a good job during the
assembly of the yacht). And yes… most of that work is done by sub-contractors
and not Hanse themselves… but still.. Hanse has the ultimate responsibility to
deliver a quality product.
Lots of
these issues only show up after the warranty period has ended. And lots of
these issues are the result of lack of expertise during assembly or wrong
decisions in the engineering phase.
But this
last one is the straw that broke the camel’s back:
Since the
first day we bought the boat I had some discoloration of the sail-drive oil. It looked a little like
aluminum paint when you changed it. In 2018 (1.5 years old, 1500NM) we hauled
the boat out in Athens and had a Volvo Penta mechanic look at it… his opinion: Water
in the oil….just change the oil and water seals on the lower shaft and all will
be fine…So we had them changed that same day.
After about
1 day of use the first signs of aluminum in the oil were back. With no other
options… we decided to continue our trip to Curacao. There we took apart the
lower end and discovered that somebody had tried to remove the lower shaft
without first removing the drain plug… resulting in a broken magnet traveling
through the lower end and damaging the gear. We replaced the lower shaft and
the damaged gear and put in a new drain plug thinking this was the end of our
problems.
Whose fault
was this? It must have happened during assembly in Greifswald by the Volvo mechanic
there. It was already missing in Athens, and the Volvo machanic did not notice…..So..
production error of Hanse
(I understand
Hanse buys many VP engines/sail-drives at once and therefore some of them will
sit in storage quite some time, thereby creating the need to replace the seals
before installation….hence the need to open the lower drive part in the Hanse factory)
We sailed a
total of 12.000 more NM with that ‘repaired’ sail-drive and changed the oil 2
times per year…… and still we ended up with a bucket full of ‘aluminum’ paint
each time, but the drive continued to work properly.
This year finally
the drive started to show signs of failure (slow engage when switching from
forward to reverse….) so we asked a mechanic here to take the whole sail-drive
out and put in new clutches, bearings and shims.
When
opening the drive he found 4 loose bolts ‘traveling’ through the upper unit and
they all had found a little place where they could ‘eat’ the aluminum housing
bit by bit. The four bolts were part of a family of 8 bolts that secure the
main gear on the vertical shaft. It is a total wonder we sailed this long
without any catastrophic damage. Who did this? Don’t know…. But must have been
a mistake during assembly of the sail-drive (no locktite) at the Volvo Penta
factory. This was a very expensive repair and finally urged me to write this
post.
My Hanse
505 is like a beautiful woman, she looks great, she sails great…. As for
everything else: It’s a total disaster.
If anybody
is interested I can post pictures of this sail-drive drama or any other drama
you may be interested in. (some of them are already documented in other parts
of this forum…)
------------- JD
