Bowthruster not thrusting
Forum Name: 505/508
URL: https://www.myhanse.com/forum_posts.asp?TID=14610
Topic: Bowthruster not thrusting
Posted By: tobo2
Subject: Bowthruster not thrusting
Date Posted: 07 May 2024 at 17:48
Our Quick bowthruster (BTR 185) isn't pushing anymore. Meaning, it opens (and closes) properly, but instead of starting the motor there is just a click sound. What we can exclude: battery is ok, connectors look fine, wheels are turning freely. Any suggestions?
(s. https:////www.sarabella.ch/wp-content/uploads/2024/05/Quick-Bowthruster-BTR185-issue.mp4" rel="nofollow - video )
Date Posted: 07 May 2024 at 18:45
Tobo2,
Did you check the fuse at the batteries? The batteries will still show good voltage but if the fuse is gone or has bad contact the thruster will not go.
Did you check the voltage at the batteries when the thruster tries to start. If one or both batteries have failed the voltage will drop  when the thruster tries to start. When the thruster is not trying to start the batteries with no drain can show good voltage especially when they are being charged all the time.
Check the battery cable connection to the thruster motor - loose? corrosion?
Posted By: tobo2
Date Posted: 07 May 2024 at 19:15
Hi Will, thanks for your tipps. So far it looked all fine and because the windlass also runs from this 24V batteries, we suspected something else. My dealer suggested to mesure the voltage at the exit of the "relais" . Anyway, the guys of our marina in Sardenia will have some homework to do, as they serviced the bowthruster just 2 weeks ago during the general winter works. Unhappy I will keep you updated, there is always something to learn ...
Date Posted: 08 May 2024 at 06:25
At least here in the US,  I've had good luck calling QUICKUSA and discussing the problem over the phone.    They talked me thru one issue, which turned out to be a blown fuse, and my initial confusion regarding controller fuses and the actual thruster fuses.   Not sure if you have someone similar to call in Sardenia.
Posted By: 32mike
Date Posted: 12 May 2024 at 13:52
I had to replace the control panel on my thruster last year. It was easy to find on-line and not hard to install - two or three wires as I recall. Quick was not very helpful with me. They even said they were short on personnel and way behind. It should have been covered under warranty but I couldn’t get them to respond and I gave up.
S/V Dulces Sueños
458 #087
Tampa, FL
Posted By: tobo2
Date Posted: 12 May 2024 at 17:58
In the meantime a Pro mechanics close to our homeport in Sardinia ( http://www.nautitec.net/" rel="nofollow - http://www.nautitec.net/ )   was aboard and measured the currents, concluding that the motor isn't responding. He will take it to his workshop the next days. Although we used it many times sailing from Germany to Greece in two seasons and visiting 120 marinas maneuvering a lot with the bowthruster, I was amazed of this verdict. Four years of use, approx 400 moves and already broken ?? Can't we expect a longer lifetime of these parts? I'll keep you updated.
Posted By: tobo2
Date Posted: 13 May 2024 at 17:12
It's definitely the motor itsself. The mechanics demounted it - a quick job of 15 minutes.
Disassembling it will show what the issue was.
Date Posted: 13 May 2024 at 17:53
One of the things I learned early on was to use the thruster in short bursts.   Long runs for the thruster would damage the motor (I was told).    This may be a myth, but I've tried to keep to it.
Not sure if that matters in this case, but thought I would pass it on.    My damage to the thruster was caused by sucking in some line.   Others have told me that long bursts hurts the motor itself.
Date Posted: 13 May 2024 at 22:47
Just curious. What is kW rating on that motor. It may be undersized. The bow motor on the 575 and 588 is 8.0 kW and does well with no issues regarding overheat.
Date Posted: 14 May 2024 at 00:05
I believe the BTR 185 was available with a 6.3  kW motor as an upgrade from the 4.3 kW.
Date Posted: 14 May 2024 at 04:06
Similar question that I have - is 4.3kW motor good for 505/508 or it feels underpowered? I am thinking of adding a bowthruster to my 458 but want to stay below 5kW, in which case I can hook it up straight to my house battery  bank
Date Posted: 14 May 2024 at 13:17
All of the Hanse installed thrusters run on a dedicated 24 volt bank very close to the thruster itself. The reason is at 24 volts the current draw will be halved and the close proximity minimizes voltage drop. Anything above 3 kW will be problematic running on the “house” bank.
Date Posted: 14 May 2024 at 13:33
My rough estimate is that Ancor 4/0 AWG should be fine to handle the needed current without significant losses, just not sure if some 4kW motor is sufficient for 46 ft boatEmbarrassed
Date Posted: 14 May 2024 at 14:28
Marsella. A 4 kW motor will draw at least 400 amps at 12 volts. 4/0 wire will have about a 20 percent voltage drop which will cause problems and eventually kill the motor. I would recommend using  a triple run of 4/0 to avoid problems with the configuration you are considering.
Date Posted: 14 May 2024 at 14:30
Also keep in mind that the 20 percent loss through the cable is only part of the total loss. The battery bank itself will surely drop 1 to 2 volts from the 400 amp demand. You’d be lucky to get 8 or 9 volts to the motor!
Date Posted: 14 May 2024 at 15:43
Hmm not sure how your math works, 4000/13=300Ams of current, the rated resistance of Ancor 4/0 AWG is 0.05 Ohms per 1000 feet, so for 10 meters or 30 feet this will produce the voltage drop of 0.5 Volts or 4% which should be fine
Date Posted: 14 May 2024 at 15:57
There are many charts and calculators  online that save us all the trouble! Not sure where you’re going wrong but voltage will not be 13 v. More like 11 v under load. Also you need to account for round trip wire resistance. I figure 50 to 60 feet including all the bends. I hope you don’t have a lithium bank because they don’t like large current draw. I have a 4.3kW on my stern thruster and it draws a solid 200 amps plus more on start up from a 24 volt bank so you can double that at 12 volt. My batteries are 3 ft from the motor.
Date Posted: 14 May 2024 at 16:19
I did noticed this effect with Hanse supplied AGMs, but Victron Lithium did not show any noticeable voltage drop when hooking 2kW loads like espresso machine. I didn't try to hook up 4kW load though, cannot comment what would happen
Date Posted: 14 May 2024 at 16:26
Yes, for 60 feet the voltage drop would be 1V for 4/0 AWG. I estimated 30 feet round trip is OK for my setup
Date Posted: 15 May 2024 at 09:53
I think many people have concern over both the voltage drop as well as the house bank usage.  If you are installing a thruster,  why not stay within a proven configuration rather than trying something for which there may be no proof points?      Why not put a 24V setup in place close to the battery and leave the house bank alone?   No place to put the battery(s)?
Unless there is someone out there who will say "this works"...??
Posted By: tobo2
Date Posted: 15 May 2024 at 12:08
Opening the motor showed the damage: broken coils/brushes (s. pics). Comment of mechanics: "Not normal for a new bowthruster  of 4 years, maybe the motor was stuck for a while and and the first start the brushes were "glued" and the rotation broke them..." Lesson learned: start the bowthruster during the winter break.
Conc. the usage of bowthruster: We don't push more than 5-10 sec. and to be honest for normal harbour maneuvres without lots of sidewind you don't really need a bowthruster. The real threat are the mooring lines which often kill the propellers. I suggest to keep a spare set aboard. With a good diver they can be exchanged easily.
Date Posted: 15 May 2024 at 13:30
I had the exact problem on my BTR 185 stern thruster. Broken brushes and a twisted bracket. I had to remove the rear assembly from the motor refurbish the bracket and new brushes. I never knew what caused it but it happened mid season so was not from sitting idle. I believe over current caused the problem so I now limit use. I will say that my 8.0 kW bow thruster has never had this problem even after periods of extended use. The 4.3 kW motor is simply not up to par.
Posted By: tobo2
Date Posted: 15 May 2024 at 13:38
My mechanics said that overheating is not really possible thanks to the thermal switch inside the motor. I think for the 508 the 4.3 kW version as a bowthruster is strong enough for 15 t yacht. We don't have a stern thruster - I never missed it. ("Simplicity is the key to success")
Date Posted: 15 May 2024 at 21:50
Yes there is a thermal switch but it won’t protect the brushes and and the commutator pads from repeatedly arcing. Thermal overload takes a bit of time. Over current can do damage quite quickly.
Posted By: tobo2
Date Posted: 17 May 2024 at 19:55
The end of the tragedy: the stator shows signs of rust, ergo new motor! Is this sh*t happens or Quick "made in China"?
Date Posted: 18 May 2024 at 03:45
Mine was in worse shape and is now running well. The pads can be resurfaced with 500 grit paper and the rest is just carbon build up from arcing. However, since yours is at the the bow, it will to never be up to the task. The 6.3 kW motor is a drop in upgrade if you can get it. My advice is refurbish the existing motor and concede to minimal use, or spend your money on the 6.3 kW unit. SVB Germany is your best source.
Posted By: tobo2
Date Posted: 18 May 2024 at 08:39
Thanks for the tipp. If we upgraded to the 6.3 Kw version the question is if the 2 batteries (each 80 Amp) would be strong enough? Of course we talk about the 24V type.
Date Posted: 18 May 2024 at 09:51
Two 80Ah batteries store about 2kWh of energy (assuming you connect them in series to get 24V) so you are looking at about 20 min of continuous run of 6.3 kW motor, not much difference from 4.3kW motor which will discharge them all the way to 0 after 30 min of continuous run. If you want to keep 50% reserve capacity, then its 10 and 15 min respectively Wink
Date Posted: 18 May 2024 at 13:44
Agreed. I have the same battery bank on my 8.0 kW and never a problem.
Posted By: lide
Date Posted: 13 June 2024 at 12:31
Very timely thread. I have a bow thruster on my new to me Hanse 385. It is showing the same kind of issue that was on the video in the first post. I have taken out the motor. Pics of the motor below.
Now that I'm looking at it I'm wondering if I can bench test it by applying 12V. Any body tried that? Any ideas?
I'm trying to figure out if the issue is in the controller at the helm, the motor or the controller board at the thruster.
Date Posted: 13 June 2024 at 12:47
I notice corrosion on the motor flange. Is the boat in the water now? You may have a leak in the shaft seal of the thruster bearing. That type of leak can find it’s way into the motor. 12 volts will spin the motor but secure it well…it packs a punch.
Posted By: lide
Date Posted: 13 June 2024 at 15:00
Thanks yes. There was some leakage earlier which has now been fixed.
So that's probably the issue. Will open it up to see what we have inside.
Posted By: Lyn
Date Posted: 13 June 2024 at 20:12
If you can, please post your results along with any pictures.  I'm getting hauled out in a few weeks to address my leak/seal & bearing replacements.  It would be helpful to know how to assess wider damage/harm before I try to float the boat again.  Thanks ... and good luck to you!
Jon
S/V Lyn
Posted By: lide
Date Posted: 24 June 2024 at 02:44
Hi. Sorry for the delayed response. I just managed to go get some photos. Here they are.
To my untrained eye, the flange looks pretty bad. I'd guess the motor shaft is corroded tight. I couldn't turn it by hand. I'd guess that a good motor mechanic may be able to fix it by replacing bearing etc. But can't be sure unless I get it done. And a bowthruster being generally needed only when things get hairy, I'm not sure I'd be comfortable with that kind of fix.
I'm getting quotations for a new motor including an upgrade to a 6.3kW. And change the circuit board and helm control while I'm at it.
How's your haul out coming along?
Posted By: Lyn
Date Posted: 30 July 2024 at 15:15
A question for sourcing thruster seals:
  • The BTR185 (used as the stern thruster on the 588) seal kits are QuickUSA part numbers: FVSGGTCC1R18A00 and FVEACBBTR185000.  These are stocked in the US.
  • The BTR250 (used as the bow thruster on the 588) seal kit is FVETCBBTR250D00.  But, the BTR250 is rarely installed in the US so they don't stock it.  And apparently not stocked in Europe either (!).  6-8 week lead time.
Anyone find another source either for the kits or the consumable components (seals/o-rings/bearings)?  Are they commonly available sizes that someone knows?  I'm not near the boat.
All of this is based upon the idea that the BTR250 uses a larger diameter shaft than the BTR185 which I can't check.
I can't believe that 9 of the 10 projects are complete, and this is the one keeping me on the hard!
Jon
S/V Lyn
Posted By: Lyn
Date Posted: 01 August 2024 at 13:29
Posting an update on this.  I was able to get a list of the components in the Quick BTR250 (Bow thruster on a 588 with an 8.0kW motor) thruster seal kit and determine the specifications for ordering.
Oil Seals: Also known in some parts of the world as "shaft seals".  You need 1 of each these 3:
  • 20mm (shaft) x 37mm (bore) x 7mm thick
  • 40mm (shaft) x 56mm (bore) x 8mm thick
  • 40mm (shaft) x 68mm (bore) x 10mm thick
Bearings (1 of each):
  • Bearing 61904
  • Bearing 61908
O-Ring (not sure if you need 1 or 2, but they generally come in packs of 10+):
  • UNI sizing it is known as 4175.  The dimensions are 44.04mm ID x 3.53mm thickness.
I found 123bearings.com had all of these in an easily searchable form and a total cost of ~$50 including shipping, but for those elsewhere, the specifications above are what you need to search.
There are 5 other components, but you should be able to salvage them from your current installation:
  • 20mm external elastic ring.  Some would know this as a external snap ring that goes onto a shaft.
  • 40mm external elastic ring.  Some would know this as a external snap ring that goes onto a shaft.
  • 37mm internal elastic ring.  Some would know this as a internal snap ring that goes into a bore.
  • 62mm internal elastic ring.  Some would know this as a internal snap ring that goes into a bore.
  • Shaft key: 5mm x 5mm x 15mm
Jon
S/V Lyn
Posted By: Lyn
Date Posted: 20 August 2024 at 20:59
Continuing saga.  I'm hauled out and they have successfully replaced the seals and bearings.  Despite asking them to check the state of the motor a month ago, they're looking at it now ... 3 days before I am to launch.  There is a slim chance we can have a replacement motor in before the launch, but if not, am I correct in understanding that you can remove and replace the motor while in the water?
That would enable me to keep to the schedule and then replace later if needed.
Jon
S/V Lyn
Date Posted: 21 August 2024 at 00:22
Yes Jon, you can replace the motor while floating. Is you motor dead for sure?
Posted By: Lyn
Date Posted: 21 August 2024 at 14:02
Thank you Leon.  The motor was working fine before I hauled out.  Their observation was largely on the bottom surface which doesn't matter and can be cleaned up.  But since I'm not there, it is hard for me to interpret their assessment when it comes to launch or don't launch.  Knowing that I can replace the motor later on the water is a huge relief.  We will test it before we launch and in the water before they release the slings.
Jon
S/V Lyn
Date Posted: 21 August 2024 at 16:22
Just a reminder Jon. If you can file a notch in the flange it will allow any water ingress that passes the seals to leak out past the motor. That way you have a visual on what’s going on with the seals and can save the motor from seawater corrosion. A dremel tool works well.
Posted By: Hdajani
Date Posted: 27 August 2024 at 10:04
We have the same Quick BTR 250 and are able to get all the parts from any Quick dealer in Europe. If they don't have in stock, they usually get them in a couple of days. In Spain, the main deal is Pro Nautic a big company that sells only to dealers. I hope this helps.
Posted By: Jean2
Date Posted: 28 February 2025 at 11:24
Hello, I am looking for the list of seals and bearings for BTR185, I bought the FVEAC1BTR185000 kit which includes
1 seal 30x42x7 (38) in the BTR 185 manual on the list of components
1 seal 15x24x7 (46)
1 internal circlip 42 (external diam 45.5) (42)
1 bearing 30x42x7 (40)
2 bearings 24x15x5 (44a)
1 machined stainless steel shaft (41)
1 key 12x4x4 stainless steel (42)
but I would like to know the references of the other seals and bearings
external circlip (50)
external circlip (47)
seals (51)
bearing (44b)
did anyone have the good idea to write it down?
JD
Posted By: Jean2
Date Posted: 04 March 2025 at 10:34
Service Quick S.p.A  answered me
external circlip (50) (47) Ø12 S1.0 INOX
oil seals (51)  PGPRL122870V - 12*28*7mm VT
bearing (44b)  MBJ619010000 - 61901
JD
Posted By: Lyn
Date Posted: 19 March 2025 at 20:32
This seems to be the best thread to build off for thoroughly diagnosing a thruster problem.  Though this thread is oriented to the bow thruster (BTR250 on a 588), my problem pertains to the stern thruster (BTR185 on a 588).
Here is what I have been able to diagnose:
1.) Activation from the helm console does cause the thruster to deploy into position.  This is a separate 12v circuit from the 24v thruster drive.
2.) I do have 24v+ at the stern battery bank.
3.) The inline fuse has continuity.
4.) I do have 24v+ at the motor starter relay.
5.) When I activate the joystick, the relay "thunks" in each direction suggesting (to me) that everything is ready to go.
6.) No activation of the motor itself.  If it spun but without propulsion, I would look at the U-joint that some have reported problems with.  Doesn't seem to be my problem.  When I was hauled out last summer, I was able to spin the thruster propellers with a load I would expect for it to be coupled to a motor rather than detached.
7.) I open the motor inspection hatch for the brushes.  No carbon build-up, commutator looks fairly shiny, and there's no other direct sign of water ingress or corrosion.  I did not pull the motor.  While I think I understand you can do so while in the water, I was nervous to do so alone.
While there's a chance the relay isn't completely performing its job by completing the circuit, I would think that's less likely to be the problem -- especially since neither direction works.  I don't know a lot about troubleshooting DC motors, are there ideas about determining which of these is my problem?
Jon
S/V Lyn
Date Posted: 19 March 2025 at 22:27
Hi Jon. You need to determine if the motor shaft can spin freely. From what you’ve tested it seems to point to a frozen shaft. This can happen when the thruster housing seal starts to leak. The water has no where to go other than up the motor shaft and past the motor bearing. It doesn’t  take much! I filed a weep pathway in the motor flange so any water will leak out and not damage the water. It also serves as a visual indication of how the seal is performing. Pulling the motor is easy. Even if the seal is leaking it will only be drops, not a flood! There is a key and key way on the motor shaft so don’t loose it.
Posted By: Lyn
Date Posted: 20 March 2025 at 12:10
Thank you, Leon, for the suggestion and the words of encouragement.  I won't be back there for a little bit, but I will update this thread with my findings.
Jon
S/V Lyn
