Pedestal angle and width
Forum Name: 385/388
URL: https://www.myhanse.com/forum_posts.asp?TID=14635
Topic: Pedestal angle and width
Posted By: sv_palamut
Subject: Pedestal angle and width
Date Posted: 22 May 2024 at 20:16
I am not close to my boat right now, I was wondering if anyone knows the angle that the pedestal heels, and the width of the pedestal cross section.
Many thanks in advance,
Çağrı
Date Posted: 26 May 2024 at 07:14
To conclude: this is 18 degrees.
The reason I was asking is, I am trying to order a hand grab.
Cagri
Date Posted: 28 May 2024 at 12:45
Hi Cagri,
where will you order the handgrabs?  Any idea about the cost?
BR
Date Posted: 28 May 2024 at 12:51
I had to get them custom made by a welder in NL.
Picking them up today, let’s see how they look.
I paid 500 euros for the pair.
Cagri
Date Posted: 01 June 2024 at 18:26
These are the photos of the end product, with my sloppy design/measurements. A bit higher than I wanted, but given that this was done based on remote design based on intuition (and a lot of inspiration from  https://www.myhanse.com/grab-rails-for-steering-wheel_topic11061.html" rel="nofollow - https://www.myhanse.com/grab-rails-for-steering-wheel_topic11061.html ), I am satisfied with the result.
I tapped threads to the alu pedestal, used 20mm m6 bolts with duralac, and plastic washers between the handle-grab lips and the pedestal. The installation took 2 hours.
The welder is Paul, super friendly and accessible, I am happy working with him. Here is his instagram handle:  https://www.instagram.com/paulie_smeltman/" rel="nofollow - https://www.instagram.com/paulie_smeltman/  .
Posted By: Aussieangus
Date Posted: 03 June 2024 at 06:54
are you sure the bolts didnt go through into the area where the chain is?
Sydney Australia
GODS COUNTRY
Date Posted: 03 June 2024 at 08:19
I am pretty sure, when I drilled, I was slow and careful. But after the hole was there, I poked it thoroughly, no contact.
If you follow the link above, the same mounting approach was used before as well.
