Jefa DD1 screeching and fuse blown
Forum Name: 415/418
URL: https://www.myhanse.com/forum_posts.asp?TID=14695
Topic: Jefa DD1 screeching and fuse blown
Posted By: High Time
Subject: Jefa DD1 screeching and fuse blown
Date Posted: 30 June 2024 at 17:43
11 hours into a 14 hour motorsail yesterday (Yarmouth (IOW) to St Peter Port), the DD1 started making intermittent loud screeching noises and shortly after the autopilot computer went offline. I had to hand steer the last 3 hours showed me how hard the DD1 had been working!
Investigation today has identified a blown 15A fuse in the autopilot computer (not the external in-line fuse but the one on the circuit board). Replacing this fuse with a 20A has brought the autopilot system back to life but the noise remains. It sounds like dry bearings in the motor. The helm without the autopilot engaged is finger light and silent.
Question - can the top of the motor be easily removed (8 hex drive bolts) and does it reveal the suspect bearings?
Second question - can these bearings be greased to solve the immediate problem or can they be easily replaced while away from base?
Third question - any ideas who could provide the best JEFA support in Guernsey?
Roger
High Time (415 #038)
Date Posted: 30 June 2024 at 20:18
You have my sympathy.
My autopilot DD1 recently failed 8 hours into a 3 day passage.  Not wanting to hand steer for 3 days, we turned back into a building storm and then faced 8 hours of 40kts gusting 50kts before finding a sheltered anchorage.
Jefa diagnosed clutch failure and we ordered the parts, but after removing the base of the drive it was apparent that a small white plastic cog had shattered.
With crew flying in to Malta, I decided to replace the DD (€3,000). I intend to try opening from the top to get access to the damaged part, but haven't done so yet. Access from the bottom was straight forward although I needed an impact driver for a couple of reluctant bolts.  Jefa assure me the unit is designed for owner maintenance.
Jefa don't have a service network so everything has to be sent back to Denmark for repair.  You may find someone who is willing to effect a repair, but it won't be authorised by Jefa.
Note that you are unlikely to have something as simple as a bearing requiring grease.  I think you may find similar issues to mine with a gear cog badly worn or broken.
I would strongly advise you to get this fixed unless you have a crew if gorillas willing to hand steer through the night!
Posted By: engineroom
Date Posted: 07 July 2024 at 00:34
BTW, was that 20 A fuse replaced with a 15 A fuse at some point?   It is generally bad to replace a lower rated fuse with an higher value one, unless 20A  was the original spec.
Date Posted: 07 July 2024 at 06:21
In my experience, the fuse that usually blows is the online furectonthe DD1 which on my boat is in the port cockpit locker, near the NAC3 computer.  This fuse protects the DD1 in situations when the drive cannot counter the pressures on the rudder.  I had it blow in a 56kt sqall in Sardinia in my first year and it blew a couple of times on the day the autopilot failed due to broaching.  Strangely the fuse did not blow when the DD1 actually failed when I was too slow (otherwise occupied with a sandwich) to take the pilot off to hand steer through a gust resulting in the DD1 failure.
I would also advise against increasing the rating of these fuses.  I believe that Jefa recommend a 10A online fuse for the DD1.  I have never had the autopilot fuse blow on the main switchboard so not sure what rating I have there.
Date Posted: 07 July 2024 at 09:21
I stripped the DD1 a couple of days ago and found nothing broken, in fact it was all pretty clean and we'll greased. However there were 2 issues that may account for the noise. Firstly the lip seal on the output shaft was very dry and may account for the screech. Secondly there were small specks of what could be rust on the top of the motor. I carefully oiled/greased these and it now run much quieter.
I had the same thought re the fuses and put a 15A back on the board before retesting.The inline fuse to the autopilot computer was originally 10A IIRC and, on advice on this forum, changed it to 15A some years ago. The 15A board fuse must have been a quick blow.
Roger
Posted By: 32mike
Date Posted: 07 July 2024 at 15:47
I have had the one on the DC panel blow one time. There were some inexperienced sailors at the helm at the time, so I’m not exactly sure what happened there. It could have just been an instance of operator error. It hasn’t happened since and I DID NOT replace it with a bigger fuse although it was suggested. Haven’t had a problem yet with the one in the cockpit locker.
S/V Dulces Sueños
458 #087
Tampa, FL
Posted By: DJgun
Date Posted: 22 May 2025 at 14:50
I Installed a brand new DD1 Jefa, a.k.a. Simrad  DD15 in my 400e in about August 2020 after buying the boat and finding the drive was missing.
Covid was happening at that time and so the first use was in December 2020 for about 70 hours on passage from Brisbabne to Sydney, and it worked very well, in some very windy conditions.
Since then because of COVID restrictions and I'll health the boat has done a lot less sailing, and the Autopilot used for less than maybe 10 hours. Most sailing was  racing, all hand steered.
Late in 2024 the steering was a bit "lumpy" which I assumed was organic growth in the lower rudder bearing, which has happened before, but this time much worse. An inspection showed the Jefa DD1 was jumping when boat was steering manually. I removed the link arm  and immediately the hand steering was perfectly smooth. It was not possible to manually move the output level on the DD1 with the Autopilot turned off. It should move quite easily.
I removed the DD1 and checked that the drive clutch seemed to not disengage when power  was off.
I disassembled the Jefa DD1 and found a lot of corrosion, even though  it has never been directly exposed to rain, seawater or high pressure cleaning.
-Lower output bearing seized from corrision
-Clutch pins seized in housing because of rust on  iron bushes
-Planetary annulus ring could not be rotated in housing, because of rust and no lubricant used
- Pancake motor seized.. It cannot be rotated by hand.
-gearing generally in excellent condition, no sign of overload or wear.
-other bearings very rough turning
-Electrical glands not properly tighted, and no sealant used as supplied by the factory,  which they recommend for motor replacement, but don't do themselves  from new.
If there is any rust in the motor or other parts like clutch pins, planetary annulus,, bearings etc  then it will overload the pancake motor, or at least make a lot of noise and may make hand steering more difficult.
It seems Jefa design and assembly just doesn't seal the unit, so normal atmospheric  changes in barometric pressures, , temperature, and humidity causes water to be inside the drive and cause havoc with corrosion. It is very disappointing.
Cheers DJ
Rust on planetary annulus gear, no lubricant from factory
Lower bearing -failed due to corrosion
Watermarking around bottom bearing
Simrad nameplate for Jefa DD1
DJ.....Sailor Ordinaire
HIN DE-HANJ0331J708
Posted By: DJgun
Date Posted: 23 May 2025 at 14:32
Deleted duplicate post
HIN DE-HANJ0331J708
