Some Water problem in 460
Forum Name: 460
URL: https://www.myhanse.com/forum_posts.asp?TID=14805
Topic: Some Water problem in 460
Posted By: Sahinsair
Subject: Some Water problem in 460
Date Posted: 01 September 2024 at 15:02
Our water problem is not over in our new 460. We had to remove the filter before to stop the flow coming from the strainer at the water inlet of the dishwasher. This time, I think there is a foamy water leak from the dishwasher or the kitchen sink again. The second problem is that we connected the water to the clean water connection from the starboard side out of fear and unfortunately we noticed that it was dripping when the rear section was filled with about 3 buckets of water. This water does not reach the bilge pump at the front either. If there is no transition between the sections, I think this is a manufacturing defect. I had to suck up these 3 buckets of water with a sponge. The other issue is that the floater in the boiler area where the bilge pump is located does not notice and work when there are 3 buckets of soapy water there. In my old boat, the floater would work even if there was 1 glass of water and let us know. Will the 460 also let us know when the boat sinks?
