Rudder dimensions Hanse 370e
Forum Name: 370 / 375
URL: https://www.myhanse.com/forum_posts.asp?TID=14812
Topic: Rudder dimensions Hanse 370e
Posted By: GJBb
Subject: Rudder dimensions Hanse 370e
Date Posted: 05 September 2024 at 08:45
I require the dimensions of the Hanse 370e rudder (2009) please.
My rudder has lost some length on contact with the hard .
The repair yard needs this information
Many thanks
Greg
Date Posted: 05 September 2024 at 19:09
https://jefa.com/ftp/rudder/rudder_blade/RUD40.PDF" rel="nofollow - https://jefa.com/ftp/rudder/rudder_blade/RUD40.PDF
https://hanse.boatoon.com/en/shop/article/27215/rudder-long
Posted By: GJBb
Date Posted: 05 September 2024 at 20:18
Thanks so much
Got what I want from your link
Kind regards
Greg
Posted By: alettaenmarcel
Date Posted: 09 September 2024 at 18:02
I see on the drawing a rudderstock from 98 mm
The 370 has a rudderstock from 88 mm
Think there should be another drawing.
I have done some work on my rudder last year.
Date Posted: 09 September 2024 at 19:51
This is the specific drawing for replacement rudder RUD40 for Hanse 370+400.
RUD40 is also sold for other boats with rudder stock up to ø98mm.
The question was about the dimension of the rudder blade for repair purposes.
The RUD40 for 370+400 has an alu-stock of 88mm in ALU6082.
https://jefa.com/ftp/old_boat_spare_parts/Hanse/Hanse_400/Hanse-370-400-repl-rudder.pdf" rel="nofollow - https://jefa.com/ftp/old_boat_spare_parts/Hanse/Hanse_400/Hanse-370-400-repl-rudder.pdf
Posted By: GJBb
Date Posted: 10 November 2024 at 08:31
Good morning Captain Cook
Many thanks for the info. My rudder  has been  repaired and fitted. Looks good and new lower bearing supplied by Jefa.the boatyard did not replace this damaged “circlip?” .
Its internal diameter is 61mm, outer diameter about 67 mm and it is about 2mm thick
Jefa no longer manufacture this part so i am going to try to get a new one made.
Can i fit it without lowering the rudder ?
I don't see any groove that it fits into ? Maybe it just loose?
Is its purpose simply to create a spacer ?
Thanks so much
Greg
Posted By: GJBb
Date Posted: 10 November 2024 at 08:35
Thanks for the photo. You did a great job.
Thanks so much
Greg
Date Posted: 10 November 2024 at 09:55
Ask Jefa if it is necessary to fit a new circlip/spacer. There are a few posts about them which you may find using "advanced search-any date-spacer?). I am a little busy now so you will have to do the search yourself.
I believe that the spacer is there to keep the rudder from touching the hull. My boat has no spacer, so maybe it is only mounted on boats where the rudder is very close to the hull. There are hundreds of posts about Jefa Rudder, e.g.:
https://www.myhanse.com/buying-new-jefa-rudder-what-should-i-order_topic12371_post112992.html?KW=Rudder#112992" rel="nofollow - https://www.myhanse.com/buying-new-jefa-rudder-what-should-i-order_topic12371_post112992.html?KW=Rudder#112992
https://www.myhanse.com/342-rudder-removal-process-wheel-steering_topic13210_post108828.html?KW=Rudder#108828
:Kjeld
Posted By: GJBb
Date Posted: 10 November 2024 at 09:57
Thanks so much Captain .
Much appreciated
Greg
