508 Hull and Grid Connection
Forum Name: 505/508
URL: https://www.myhanse.com/forum_posts.asp?TID=14813
Topic: 508 Hull and Grid Connection
Posted By: Jegenia
Subject: 508 Hull and Grid Connection
Date Posted: 05 September 2024 at 17:26
Hi everyone, i am new here with a new Hanse 508 being build right now. As i research on equipment and boat preparation for a round the world journey with my family, i am wondering if the 508 hull and grid are adhesive bonded or laminated together? My aim is to make this boat as strong as possible for the heavy heather ocean sailing.
Same concern are with the integrity of the reinforced bulkhead and absent compression post for the mast and chainplates. I found online on a smaller Hanse that the bulkheads and grid/hull were not laminated together!
Does anyone has any info or a 508 sharing the same concerns?
Posted By: SVZara
Date Posted: 05 September 2024 at 19:45
As a datapoint, I have a 505 and the grid is glassed into the hull, not bonded.  I would like to assume the 508 is also glassed in, but I do not know.
Marc
S/V Zara
2016 Hanse 505, Hull #129
Posted By: Jegenia
Date Posted: 05 September 2024 at 20:43
Thank you, this is a great relief.
Posted By: Wild
Date Posted: 07 September 2024 at 11:11
I can not speak for the 508 model but some other Hanse’s(like our 545 2010) the grid is particularly bounded on some place’s and laminated on other places to the hull. So they aren’t laminated completely.Cry I am sorry
Wild and Wet
Belgium
545e#268
Posted By: Wild
Date Posted: 07 September 2024 at 11:19
Wild and Wet
Belgium
545e#268
Posted By: jdderijke
Date Posted: 21 September 2024 at 08:39
I own a 505, #114.
All connections in the keel area and forward of the keel between grid and hull are laminated in my Hanse. Other areas (under aft cabins etc.) i see bonded connections. Note however that the bonding is done with a substantial overlap because the grid has a flange. When doing due-diligence on my Hanse i also visited Bavaria and noticed they 'glue' their grids in place without flanges...
JD
