Dishwasher
Forum Name: 545/548
URL: https://www.myhanse.com/forum_posts.asp?TID=14851
Printed Date: 26 March 2026 at 23:38
Topic: Dishwasher
Posted By: Hakan A
Subject: Dishwasher
Date Posted: 05 October 2024 at 19:21
Hi, I have a problem with my bosch dishwasher. Hanse 548. Is there a valf for water inlet? The machine can’t take water. I need a users manual please. I am waiting for your help.
Date Posted: 06 October 2024 at 00:23
Maybe checking the Bosch website for the manual for the model onboard would get you a result.
Posted By: Hakan A
Date Posted: 06 October 2024 at 05:58
Off course I did but I have to be sure first the water inlet is open.
Date Posted: 06 October 2024 at 21:25
 We have a 575 from 2014 and have a washing machine but not the dishwasher option but there are no fresh water isolation valves in our fresh water system. If your 548 is the same as long as your fresh water pump is running the water pressure should be getting to the dishwasher. It may be that the dishwasher is not letting the water in due to some fault. Our Miele washing machine would not let water in because there was a small water leak which was detected by a sensor on the washing machine and it therefore would not run. A Miele tech came to the boat and checked for a fault code which told him what the problem was and once the sensor was dry the machine ran normally.
Posted By: Hakan A
Date Posted: 06 October 2024 at 21:34
Posted By: Barnacle_Bill
Date Posted: 10 January 2025 at 03:11
Sorry for the late post, but we have the same dishwasher on our 588. The valve is behind the 3 drawer galley stand/counter.
If you have skinny arms, you can pull out the bottom drawer all the way and reach up and turn the valve 90° to turn on the water or turn it off.  Otherwise, you have to take out the entire middle drawer, which is a process that is not as easy as it seems. Ironically, we took new delivery of our 588.  With this water valve turned off.Nice quality control at the factory !
Posted By: Hakan A
Date Posted: 10 January 2025 at 06:29
